My engine builder recommended 20W50 and I originally used Brad Penn after the break in period. But I couldn't buy Brad Penn locally - I had to order it. I had been running Mobil 1 0W40 (also has good ZDDP numbers) in my wife's Camaro with the 350 for about 10 years. So I contacted Mobil Oil and asked them for their recommendations on oil for my 462 with a flat tappet cam - and the 15W50 is what they recommended. I liked the idea that it was rated 15 at the low end - because I actually do drive my GTO in cold weather at times. The pour point being so low is an excellent benefit. As Pontiacs run hotter than Chevy's - I like the 50W on the top end. Add the fact that I can go into most box stores and pickup a quart or a case at reasonable prices makes it a solid choice in my mind. |
That chart is very old (1998 with some 2002 updates).
But one of the best flowing oils (regardless of weight) is Mobil 1 15W50 with a rating of -50. This chart doesn't show it, but it has very good ZDDP numbers too. ![]() What I like about using Mobil 1 is that it is so readily available. I can go into most box stores and find it (NAPA, Advance, etc). Typically I find the most consistently low price to be at in my area is Fleet Farm (MN and WI). |
Yes, tons of charts and plenty of info out there. I'm only opening the door. Do the research and educate yourselves. Oils are constantly changing too, as are oil filters. It's always something to keep an eye on. Lots of good stuff out there.
thats fine if thats how you see it... my statement applies to normal oils in the normal price range, like the brands you buy at walmart or local auto parts stores that the majority of street cars use. not specialty oils that cost 2-5 times as much,. or a synthetic to a conventional... lets keep this apples to apples, not apples to watermellons!
not "boasting" about anything, im making a true statement about one weight vs another... obviously all brands will not be the same & differ in their additive packages & "yada yada yada" im not sure what that has to do with comparing weights which is what the original question was about. for the most part, a 10/30 oil will flow better than a 20/50. just trying to share good information of fair comparisons.
It's all directly related to each other and pertains to the original question.
actually no, its not directly related... the OP asked about changing oil weights, didnt mention additive packages at all. additives dont have anything to do with weights of oil.
& nobody mentioned walmart oils... i said walmart is a place many people buy common brand oils. if brad penn is being used here then lets compare brad penn 20/50 to brad penn 10/30... THAT is the only equal & fair comparison in this example. bottom line is with 2 equal oils the thinner one will pour, pump & flow better. & for most engines in this section that is what matters. thats all im trying to say, lets save the nit picking of additives & other unfair comparisons for another thread. |
You're pulling things out of context that has nothing to do with the OP, and missing the whole point of the statements and information given.
I'm officially relieving you of your man card and filing your name with the others.
This thread somehow reminds me of a camshaft thread
Sorry I crated so much controversy. I thought the OP was a simple question, but obviously, opinions run strong and varied on this subject.
I was going to inquire about oil filters, but that may create even more controversy. I've used up the AC PF31's I had, and plan to change to the Purolator L30005. Both of these are the long style, and I know the Purolator has an anti drain-back valve. My wife has an identical Tripower 434 Whitmore engine in her car, so the correct oil & filter choice is doubly important to me. That being said, I've run Brad Penn 20W50 for the 7000+ miles I've put on my engine and my wife's with about 4000 miles since Dan Whitmore built them. I wish he was still with us so I cold discuss this with him, the most knowledgeable person I've known about Pontiac engines. I do remember he provided 20W50 for the initial fill.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
I didn’t want to hijack this thread so I started one about Lucas oil stabilizer. Navy Horn 16 didn’t like it but read the question and tell me what you think
For sure Oil and Oil Filter threads get all sorts of varied opinions.
Kind of related but a lot of my friends ride Harley Davidson touring bikes, and not just occasionally, they will ride tens of thousands of miles all over the Country to ralley's and such. Most of them are very particular about lubricants for them, and insist on very expensive Harley Davidson full synthetic, and a few of them use Amsoil dedicated HD V-Twin oils, and most also use Lucas stabilizer additives in all three places. There is one of the group that is a cheap-ars so only uses the lowest price Walmart brand, and no additives whatsoever. He claims it's all "snake oil" and refuses to pay close to $100 for lubricants at service intervals. Guess what? He had ZERO issues anyplace with his motorcycles, whether it be the engine, primary or transmission. He's went thru three touring bikes (trades them out between 60,000-80,000 miles) since I meet him back in 2003 and never had the first issue once engine, primary or transmission related. I'm not quite convinced that his mentality is the right thing considering the cost of one of these motorcycles despite the perfect track record. I use dedicated primary oil, full synthetic HD engine oil with Lucas additives and Lucas 80W90 gear oil in the transmission. I also have zero issues anyplace, but my wallet is certainly lighter than my friends after service is completed. I will also comment on this: "There is sometimes good info found if you can weed through the garbage. It's comical most of the time, but also sad that some very smart people now seldom waste their time posting here". This problem has become considerably WORSE in recent years, and many very knowledgeable folks that I know REFUSE to be a part of this Forum for those reasons. I'm hanging in there despite finding myself being criticized and belittled by folks with less total direct experience with Pontiac engines as I spent on the crapper last week. For sure it's not much fun to argue with idiots, or to be chastised by folks who are trying to feed their ego's more than anything else. I come on this (and other) Forum's to help folks out. For sure I don't know everything there is about all these topics, but at this point in my learning curve I certainly know what doesn't work well and how to build and tune one of these engines. I am DIRECTLY involved with some of the fastest Pure Stock and FAST Pontiac powered cars on this planet, and not just with carb stuff. I've done distributors, intakes, camshaft selections, transmissions and torque converters for a number of them as well. Despite having to take some flack a little too often for my liking, I stick it out. Dave at SD told me years ago to quit wasting my time here, and recently I'm really beginning to understand why he doesn't post here. For now I'll keep putting some time in, but to be perfectly honest it'd really I don't like the way things are going on here and will be spending more time watching my 3 year old grand daughter and throwing sticks for my dogs instead as they are always glad to see me and appreciate my involvement in their lives........FWIW.......Cliff
Cliff,
Appreciate your sticking around. You've often been a great help to me personally. It's valued. I don't think it is just PY. I think the Facebook Twitter era has overall increased snark and shortened attention spans. There's no cure-all for that. On the flip side, I'm often impressed how very civilised a lot of the threads on PY can be. I sure do appreciate all the good manners and generously shared experience that I experience here most of the time. Sam Quote:
-- Sam Agnew Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it. Ministry - Jesus Built My Hotrod |
I for one hope that you stick around, I don't say much on here but read all the time and have always enjoyed your input. I have learned more from this forum than any other source since getting back into old cars a few years ago.
My 20W50 vs SAE30 Brad Penn question was handled for me by fate. The store that handles Brad Penn had no conventional 20W50 Racing Oil by Brad Penn. They only had 20W50 Penn Grade Partial Synthetic and Brad Penn 20W50 motorcycle oil, so I bought SAE30 Brad Penn Racing Oil. I was tempted to try the 20W50 semi-synthetic, but stuck with conventional oil.
Now, to put the Purolator L30005 filter on and I'm ready for the summer, at least with my wife's GTO. FWIW, all the newer cases were labeled Penn Grade, not Brad Penn. There must be a change in Brad Penn corporate structure.
Brad Penn was sold a few years back. Same oil,different name.
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
