Old 05-29-2018, 10:19 PM
badgto's Avatar
badgto badgto is offline
Default Excessive oil under dist.cap
Has anyone experience excessive oil inside distributor cap and know why or how to control it? I run a msd billet dist that's about 8 yrs old. With a oil feed hole for gear and also run a vacuum pump with about 14" vac at idle. I have cleaned under the cap 2 weeks in a row
With same amount there. I run a crank trigger set up too. I have taken the distributor completely apart and seem tight with no play.
Keith
Old 05-29-2018, 10:26 PM
mgarblik mgarblik is offline
With a vacuum pump system, this is a little puzzling. We had oil in the distributor issues with a Mallory distributor years ago. That distributor had a large 1/4" feed hole into the shaft area. I tapped it and screwed a .060" restrictor in that hole. That took care of it. It was fine on the drag strip. Thousands of street miles could be a problem.
Old 05-29-2018, 10:27 PM
Probird's Avatar
Probird Probird is offline
Pic of Badgto’s distributor
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
2024 Chief of the Pontiacs
Old 05-29-2018, 10:31 PM
badgto's Avatar
This distributor had never been used on the street. I have use this oil feed plug bef ore no issues.
Old 05-29-2018, 10:37 PM
There is a seal in the top of it. Could be your problem
Old 05-29-2018, 10:43 PM
badgto's Avatar
The only thing I see at the top of the dist body is brass insert and the shaft rides on 2 thin brass washers. Does the seal have any rubber lip or anything to help seal?
Old 05-29-2018, 10:46 PM
I replaced one a while back. Yes it's a lip seal. I remember there was roller.bearing in that area to.
Old 05-29-2018, 10:49 PM
badgto's Avatar
Does msd make a kit that you can buy?
Old 05-29-2018, 11:54 PM
Kevspontiacs@aol.com's Avatar
[email protected] Kevspontiacs@aol.com is offline
Keith i have one that you can borrow if needed
Old 05-30-2018, 06:56 AM
Got the parts from a local speed shop that was a msd dealer. You could more than likely get them strait from msd.
Old 05-30-2018, 06:59 AM
badgto's Avatar
Thanks for the help.
Old 06-21-2018, 08:03 AM
Gary H's Avatar
Gary H Gary H is offline
Bringing this subject back up because I have a stock Pontiac distributor in my race car that is leaking oil into the cap as well. Is there a seal in the stock distributor anywhere that could be going bad? I have a vacuum pump but it's still leaking.
Old 06-21-2018, 08:18 AM
steve25 steve25 is online now
I assume your block plug is drilled to oil the Dizzy and Cam gear, and if so to what size?
Old 06-21-2018, 08:08 PM
Gary H's Avatar
No, it's not drilled to oil the gear. Race only engine with BOP gear.
Old 06-22-2018, 06:18 AM
Big nose up lunches and no rear of pan baffle plate ,or baffle plate alone on the rear main cap studs can send a ton of oil right up into the Dizzy!
