Old 06-26-2018, 12:47 PM
Originally Posted by J.C.you View Post
Question on a air to water setup. Anyone make a inner grated unit for a carb that sets on the top of the engine like a fi NRE x Ram?
You mean like this?
I have the upper and lower box for the carb and you would just need a inter-cooler brick fabricated to sit above the carb.
At one time Vortech sold the things. See Pics below They were all made (actually) by Shelby Spearco (George Spears).
I still have some inter-cooler bricks but some good fabrication skills would be required to make one today, JC.
Name:	Vortech Carb Enclosure.jpg
ID:	486436   Click image for larger version
Name:	inter-cooler brick.jpg
ID:	486437   Click image for larger version
Name:	Hanger 18 Intercooler.jpg
ID:	486438   Click image for larger version
Name:	Potential JC IGLOO-1.jpg
  #42
Old 06-26-2018, 01:53 PM
thirdgen455's Avatar
thirdgen455 thirdgen455 is offline
You mean like this?
I wish Vortech still sold the 4150 or even better a 4500 lower. I have the top, and Shearerfabrications can make the core.
  #43
Old 06-26-2018, 04:20 PM
I have several of the Vortech Air Boxes NEW.
Send me a pm and we can talk about your project and maybe get you a lower.
I put two of the Vortech Boxes together one time for a Blow thru, Inter-cooled Tri-Power set-up using Holley special 2-BBL carbs. Had dual inlets too for a Twin Turbo Set-up.
Maybe can take some pics at some point for the board.
  #44
Old 06-28-2018, 01:44 PM
Pontiac Performance Author
Tom: have you ever seen the blow thru cooler units from R-tech? Was aimed at the marine market.
  #45
Old 06-28-2018, 04:13 PM
Have seen the owner "Tom" post on the marine engine forums a few times. He is tied in with Vortech Engineering, (dealer I think), and sells kits with his Inter-cooler and their superchargers.
When Vortech walked away from the Igloo type inter-cooler "Tom" saw a market for his inter-cooler ideas in the boat market.
Procharger had a carb box deal for the marine engines for years. Never really saw much in the way of good inter-coolers out of them.
"Tom" said his stuff was better when people switched to his stuff.
The point of all this being, IF you add inter-cooling you can run a denser intake charge and less boost and make a bunch of power.
Hope you are happy and well Ken.
