Old 07-25-2018, 01:06 PM
GTOGEORGE's Avatar
Originally Posted by Scott Roberts View Post
We ran the same type bell in ours.. the titanium bell was crazy exspensive.. even an ultra case on a glide is no where near as thick or safe as a lenco with a steel bell...
I would never do it..dont care if it was behind the same engine or not...not in a funny...
I was going to run a $7k glide until I started talking to smarter people then me ( not hard to find) .. trans companies and racers.... ended up spending the extra for the lenco... also went from a 2 to a 3 spead as the there was way too much drop in rpm from first to second...motor didnt like it..with the Lenco you just bolt another gear on between 2nd and the reverser...
Wish them the best and hope it works for them especially from a safety stand point. It's a dangerous sport and safety is not somewhere to cut corners...
Every combination is different.
GTO George
  #122
Old 07-25-2018, 01:25 PM
Stan Weiss's Avatar
One reason I keep posting my simulations is to see how close they come to actual track data.
When I ran these simulations I tried a few different PG ratios and then tries a few 3 speed ratios. From the limited number of tries the best simulation was the one I posted and that used a 1.82 1.37 1.00.
Stan
Pontiac Pump Gas List
  #123
Old 07-25-2018, 01:36 PM
GTOGEORGE's Avatar
Originally Posted by Elarson View Post
George: do you know if that car will be in the Kauffman tent at Norwalk or out in the pits?
Eric
Dunno.......last year he pitted next to me, ill ask him.
GTO George
  #124
Elarson's Avatar
Elarson Elarson is offline
Stan
Our experience is that the nitro loves being loaded. We use a 2-speed Lenco and the shift to high gear makes more power. Our 1/8th mile at Bowling Green was a bit soft (compared to running in the October air last year) but in high gear, it came alive and ran the big mph.
Hopefully the air is better at Norwalk and we're going to put a little more counterweight on the clutch to load it harder in low gear.
Eric
  #125
Old 07-25-2018, 08:48 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
Originally Posted by twooldgoats View Post
George got his seven!!!!!
Jim
LOL
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046s
1.079 4.52 155.15
3000 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
7.17 @ 188 1/4 mile (2024)
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
  #126
Old 07-25-2018, 10:23 PM
Eric
What first gear are you running Eric? Are you running sub 1.0 60's?
  #127
Old 07-26-2018, 08:02 AM
mgarblik mgarblik is offline
We run a 25% reduction in 1st gear. 4.11 rear, 60ft. average, around 1 second. I think the best is .996. Car is very heavy unfortunately for a funny car. Chassis was overbuilt some for safety, long life with lots of trailer miles and general ruggedness. We pay a little price for that. Also, the body is very heavy for the same reason. Titanium goodies and a carbon fiber body would take 200-250 lbs. off our car. Neither is in the budget.
  #128
Old 07-26-2018, 08:34 AM
Elarson's Avatar
Slight correction. Our current first gear is 1.37. We've tried several.....direct drive (wow, ate clutch disks!), the 1.25 that Mike mentioned and now 1.37. Given that we have a heavy car and 36" tires, the idea is to use a little more low gear and a little more stall spring for the initial move and then control the engine loading from there on out with clutch counterweight.
Best 60' was .992
Eric
  #129
Old 07-26-2018, 12:34 PM
I should have remembered that. I now have flashbacks of all the trouble I had changing the bearing on the planetary drum. It was really stuck in the LENCO case and then on the drum. Had to use a little heat to release it. Good thing everyone on the team has specific jobs.
  #130
Old 07-26-2018, 01:14 PM
Elarson's Avatar
Good point to let everybody in on. There's just too much going on with a nitro funny car for any one person to have it all in their head. Arnie is especially good at asking me questions where my answer has to be "I don't know...I'll have to ask Mike".
Eric
