Closed Thread
Old 09-24-2018, 04:15 AM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Originally Posted by torqhead View Post
The shim that you find on some motors between the flexplate and the crank was used when the motor was assembled with the starter and the clearance didn't make build minimum clearance spec (between flexplate and starter) is my understanding.
Makes sense. On aftermarket mini starters to get the gear to flexplate clearance the shim goes between the starter and mounting block.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
  #262
Old 09-24-2018, 10:12 AM
72LuxuryLeMansLa.'s Avatar
72LuxuryLeMansLa. 72LuxuryLeMansLa. is offline
My stock 72 350 has shims between the starter and block.
Karl
  #263
Old 09-24-2018, 10:17 AM
torqhead's Avatar
torqhead torqhead is offline
Yeah, that makes sense, effectively spaces the starter top to bottom and mesh between the gears. The flexplate shim increases space from front to back to ensure the flexplate doesn't hit the starter gear when starter isn't running.
  #264
Old 09-24-2018, 10:32 AM
Sirrotica's Avatar
It's the stack up of tolerances that would need this, the same as starter to block shims. However whenever parts are machined, or exchanged, the factory window of tolerances will no longer apply. I previously mentioned the shim is to make adjustments in lateral placement of the flexplate in relation to the crankshaft. The OP shows the shim in his pictures, so we can assume it was installed as the parts were assembled.
I have inadvertently left the shim out on the crank flange to flexplate, without negative results. Doubtful it's going to impact the noise that the thread is about.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #265
Old 09-25-2018, 08:36 PM
64speed's Avatar
64speed 64speed is offline
Has this ever been resolved?
  #266
Old 09-25-2018, 08:58 PM
Bentwheelbob's Avatar
Yank the engine and send it back. The season is over and you’ve gone above and beyond to find the problem.
Having the PY Forum solve this issue at this point is like throwing darts in a dark room with a blindfold on.. Everyone wants to be helpful, but it’s time to get serious.
  #267
Old 09-25-2018, 09:46 PM
Va68goat's Avatar
Va68goat Va68goat is offline
64speed,
No, believe it or not, it hasn't been resolved. I've put less than 200 miles on this car since I got it.
Bentwheelbob,
Yeah, I think you're right. Me and my buddy's have spent well over 60 hours of diagnosis time and replacing parts. I have about $1,600 in just parts and tools since I got the motor delivered. (Rockers, pushrods, flexplate, fluids, gaskets, I also had a shop inspect the cylinder heads and I bought a bore scope.). It's been tough. If I knew more about cars, I'd have an easier time trying to figure all this out. Since my knowledge is very limited, that why I went Paul. I may try to get the flexplate installed just to rule that out before the motor goes back to Arizona. I'd hate to send the motor back and Paul can't duplicate the knocking noise. I'll let you guys know how it turns out. Thanks for all the suggestions.
  #268
Old 09-25-2018, 10:47 PM
NeighborsComplaint's Avatar
Originally Posted by Va68goat View Post
64speed,
You got yourself a real mystery there. Change out the flexplate leaving the convertor disconnected and sorry to say, hope for best but prepare for the worst.
  #269
Old 09-26-2018, 09:16 AM
chiphead's Avatar
chiphead chiphead is offline
My money is that it's still banging on the windage tray.
  #270
Old 09-26-2018, 12:00 PM
grivera's Avatar
grivera grivera is offline
This is definitely possible but doesn't seem likely considering it's a factory style pan, factory windage tray (with spacers), factory 455 crank (4.21 stroke).
By comparison, my 461 with the longer 4.25 stroke and aftermarket Tomahawk windage tray doesn't have clearance issues.
Will Rivera
  #271
Old 09-26-2018, 12:34 PM
chiphead's Avatar
What else could it be? He tore apart the top end multiple times, which eliminates valve covers, valley pan, lifters, rockers, pushrods.
He doesn't see glitter in the oil, which would be crank endplay.
Exhaust banging on the frame? He should see that.
Cam endplay? That should destroy the lifters/lobes
Rods hitting wrist pins? It should show metal in the filter.
Piston slap Should go away when it warms up
Its a sheetmetal noise? The tray is damaged, loose or improperly spaced.
  #272
Old 09-26-2018, 01:58 PM
grivera's Avatar
The flexplate hasn't been ruled out just yet and when they installed the windage tray spacers they checked for clearance. I for one and hoping it is something as simple as the flexplate or windage tray...for Joe's sake
Will Rivera
  #273
Old 09-26-2018, 02:51 PM
jonmachota78's Avatar
jonmachota78 jonmachota78 is offline
X2 on that. Check it again before sending the engine off
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports,
3" pypes, Hooker 1 3/4" headers, hydraulic roller,
10" Continental, 3.42 gears
11.5 @117.5mph 3900lbs
([_|_] ##\|/##[_|_])
  #274
Old 09-26-2018, 03:30 PM
dataway's Avatar
dataway dataway is offline
Yep ... I still think it's a crank weight tapping gently on something.
Wanna see some slow-mo.
  #275
Old 09-26-2018, 05:13 PM
Is it possible for the Crank Counterweight to rub on the oil pump shaft? If so, I would think you could feel it through the distributor housing. When running, just get your stethoscope on it, or crank the engine by hand with your hand on the rotor?
Bill Nye.
  #276
Old 09-26-2018, 05:24 PM
grivera's Avatar
How would this be possible on a factory block with factory replacement parts? Could H-beam rods affect clearance?
Will Rivera
  #277
Old 09-26-2018, 07:00 PM
dataway's Avatar
On my bone stock engine it's close but not that close maybe 1/4" or 3/16".
  #278
Old 09-26-2018, 07:42 PM
tom s tom s is offline
On may 23rd of this year post 105 I said get it out and back to Paul,4 month gone and a summer lost.I cant say how much im bummed for you.Paul will find it IF its in the engine im sure.Tom
  #279
Old 09-26-2018, 08:41 PM
Va68goat's Avatar
NeighborsComplaint,
I may try this weekend to pull the converter back and start the car and see if the knocking noise is still there. I spoke to Paul today and we were talking about the placement of the starter as well.
chiphead,
I hope it's not the windage tray. Apparently Paul spaces the windage tray with 2 washers. When we pulled the motor, we noticed only one washer (See picture). We used a spacer that provided a little more clearance (See picture). Here is what the pan looked like when we pulled the motor (see pictures)
ID:	493680   Click image for larger version
ID:	493681   Click image for larger version
ID:	493682   Click image for larger version
ID:	493683   Click image for larger version
  #280
Old 09-26-2018, 08:52 PM
Va68goat's Avatar
jonmachota78,
I agree. I think at this point, I have to exhaust all means before the motor goes back. At the minimum I have to rule out the flexplate and verify clearance of the starter.
dataway,
I'll try to get some slow motion video this weekend. I think thats a great idea.
tom s,
Yeah after the money and time that I have in this car since it's been delivered, that may have been the right thing to do. Missing the whole season was pretty tough considering I'm so close to retirement. I haven't had a chance to enjoy this car since doing so much work to it.
TedRamAirII,
If we get a chance to mess with the car this weekend, I'll get the stethoscope out and try that!
Closed Thread
