Old 10-13-2018, 10:06 PM
G1K G1K is offline
Default 68 GTO quarter window seal/trim
Hi all, first post here.
I have a 68 GTO that is getting a little face lift. The outside seal that goes between the quarter window and the exterior is shot. Attached photo for reference.
I've looked through some of the restoration and re-pop sellers and can't find this piece. Does it come preshaped, or is it sold in a straight length and bent to fit the opening as needed?
Is there a good guide on how to refit the new piece?
Thanks for any help.
Ryan
Old 10-14-2018, 09:44 AM
Ames ought have it. Only seen Pre-curved. Must insist on "Round" not "Flat" stainless bead for Quality and correctness.
Excellent result when you CAREFULLY feed the jagged tabs during install. Then perfect the curve by hand/mallet banging the shape to get the black rubber edge to flush up with body paint. Screw at each end assures excellence.
Old 10-14-2018, 04:32 PM
Verdoro 68's Avatar
Glass channel weatherstrip aka window fuzzies. F230B in the Ames catalog for the set. You definitely get what you pay for with the replacements.
https://secure.amesperf.com/qilan/De...part_num=F230B
Ken
'74 Ventura 350
'69 AMC Javelin SST
