Old 11-07-2018, 01:04 AM
Stuart's Avatar
Stuart Stuart is offline
Originally Posted by Fullsize455 View Post
Who actually wants that car though? Sure not me..
If everyone had the same tastes the world would be pretty boring, wouldn't it? It would be better with a manual transmission, but I like that Vega.
  #6342
Old 11-07-2018, 02:16 AM
dataway's Avatar
dataway dataway is offline
I think anything that old that looks that good is worth having ... that's why I still have my wife
  #6343
Old 11-07-2018, 07:40 AM
Johnny99's Avatar
Johnny99 Johnny99 is offline
NOT a GTO. 1965 LeMans 455
  #6344
Old 11-07-2018, 07:11 PM
Simple Man's Avatar
https://southbend.craigslist.org/cto...743223536.html
"Needs complete restoration"...never would have guessed!
be a simple...kinda man.
  #6345
Old 11-07-2018, 07:34 PM
bird72's Avatar
bird72 bird72 is offline
if not Henny Youngman, could of been......
72 Bird
  #6346
Old 11-07-2018, 10:00 PM
Captainofiron's Avatar
Captainofiron Captainofiron is offline
Originally Posted by 1965gp View Post
Man I would love that car
Too bad it's probably more rust that steel at this point down there in Houston
www.fquick.com/Captainofiron
68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4
97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil
14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires
  #6347
Old 11-07-2018, 10:45 PM
Good God! You’d be better off buying one of the new bodies from Ford Racing....
Dr. Thomas Sowell
  #6348
Old 11-07-2018, 10:52 PM
"Comes with several extra parts"
Old 11-07-2018, 11:05 PM
mgarblik mgarblik is offline
The Michigan license plate is the best part in that pile of crap.
  #6350
Old 11-08-2018, 12:30 AM
Formulabruce's Avatar
Super duty!! hehe
https://boston.craigslist.org/gbs/ct...738006051.html
  #6351
Old 11-08-2018, 08:43 AM
muscle_collector's Avatar
unlikely, but you never know what someone stuffed into it. I bought a 76 50th ann 455 and it was advertised as an 455-HO I just passed it off as like so many did and referred to them as HO. but come to find out the guy had put a 72 HO top end on it including exhaust manifolds and cam early in its life.
  #6352
Old 11-08-2018, 09:44 AM
Oh wow it's been board out
Wonder if 2x4 or 2x6
  #6353
Old 11-08-2018, 10:20 AM
Missed that when I 1st read the ad.
If it was close to me I would have to check it out, a friend of mine picked up a 70 Formula that had a 74 SD 455 put into it. He talked the seller down because it was not a Numbers Matching car!!!!! Bought it for much less than the engine was worth.
So you never know.
But probably has the original 76 455 under the hood, or would that be a 462 now that's its Boared? At least it would give a convenient place to tack up all the engines paperwork!
  #6354
Old 11-08-2018, 12:00 PM
Stuart's Avatar
Saved for posterity.
76 trans am super duty 455, all types work, Morosso drive oil system cost 1000
Ansen starter shield special safety 3-500, Hurst complex shifter, headers has headers on exhaust Lakewood lift bars and a 390 poi's rear end, boared & balanced all custom Edelbrock speed equipment
Intake carb valve covers all Edelbrock speed equipment. Call For more information
  #6355
Old 11-08-2018, 03:00 PM
Originally Posted by Captainofiron View Post
Oh wow it's been boared out
nope. this guy did the machining:
he also hogged out the ports, too
/your waitress, tip her well
  #6356
Old 11-08-2018, 11:15 PM
Even the 'headers has headers'.
Old 11-09-2018, 02:37 PM
Hahaha missed the "e" even better!
Must be double horsepower then
  #6358
Old 11-10-2018, 02:03 AM
post toastie's Avatar
2FER https://sfbay.craigslist.org/pen/cto...732937372.html
  #6359
Old 11-10-2018, 06:10 AM
Simple Man's Avatar
I don't know if you would get one good car out of that mess....
  #6360
Old 11-10-2018, 08:08 AM
Heybuck's Avatar
Heybuck Heybuck is offline
I'm looking at the bigger picture in this ad. What I see there is a 4 door hardtop which maybe has the bones to be rebuilt.
To do the 2 door would cost much the same to do but what have you got when it's done? I'll tell you what you have - you have just one more 2 door LeMans. In the crudest form, a 2 door LeMans is not much different to a Mustang. And those are like ***holes - everyone seems to have one.
Build the 4 door and you will have quite a different car. As time progresses, the rarer , much less seen cars, will start to draw greater attention.
JMHO
Ian
To laugh at men of sense is the privilege of fools.
