Old 03-14-2019, 12:55 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Why would you run full synthetic oil? No need for it. Penn Grade one is great oil. Synthetics are more likely to leak and get past the rings and burn if the engine is not built for them.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
