Old 04-18-2019, 08:42 AM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
Default First Look @@ High Performance Injuns SpeedMaster Heads
First Look at the SpeedMaster Pontiac Heads. I’m impressed with the casting quality, heli-coils where they need to be, machine work looks good. Oil return looks well thought out. High Performance Injuns is offering these for the introductory price of only $1759 a pair picked up at the shop or customer pays actual shipping.
Cylinder Head Material: Aluminum
Cylinder Head Finish: Natural
Combustion Chamber Volume (cc): 72 cc
CNC-Machined Combustion Chamber: Yes
Intake Runner Volume (cc): 215 cc
Exhaust Runner Volume (cc): 175 cc
CNC-Machined Intake Runner: No
CNC-Machined Exhaust Runner: No
Intake Port Shape: Ram Air IV
Intake Port Location: Standard
Exhaust Port Shape: Ram Air IV
Exhaust Port Location: Standard
Spark Plug Style: Angled
Comp. Valve Job: Yes
Intake Valves Included: Yes
Intake Valve Diameter (in): 2.110 in.
Exhaust Valves Included: Yes
Exhaust Valve Diameter (in): 1.660 in.
Valve Springs Included: Yes
Maximum Valve Lift (in): 0.580 in.
Outside Diameter of Outer Spring (in): 1.450 in.
Damper Spring Included: Yes
Number of Springs Per Valve: Dual
Retainers Included: Yes
Retainer Material: Chromoly steel
Locks Included: Yes
Lock Style: 10 degree
Valve Stem Seals Included: Yes
Valve Stem Seal Style: Positive stop
Rocker Arm Studs Included: No
Rocker Arms Included: No
Rocker Arm Nuts Included: No
Guideplates Included: No
Valve Cover Mounting Style: Center & Perimeter Bolt
Accessory Bolt Holes Drilled: Yes
Intake Valve Angle: 14 deg.
Exhaust Valve Angle: 14 deg.
Valve Guides Included: Yes
Valve Guide Material: Bronze
Valve Seats Machined: Yes
Valve Seat Machine Style: 3-angle
Valve Seat Material: Ductile iron
Steam Holes Drilled: No
Oiling Style: Through pushrod
Machined for O-Ring: No
Heat Crossover: No
Quantity: Sold as a pair.
Assembly Specifications
Max Lift: .580"
Coil Bind: .740"
Intake Install: 135lbs @ 1.8
Exhaust Install: 135lbs @ 1.8
Closed Sear Pressure: 125lbs
Open Seat Pressure: 320lbs
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
Old 04-18-2019, 08:52 AM
First 5 Pics
ID:	510420   Click image for larger version
ID:	510421   Click image for larger version
ID:	510422   Click image for larger version
ID:	510423   Click image for larger version
Randy Repp
Old 04-18-2019, 08:54 AM
Next 5
ID:	510425   Click image for larger version
ID:	510426   Click image for larger version
ID:	510427   Click image for larger version
Randy Repp
Old 04-18-2019, 09:00 AM
Next 5
ID:	510438   Click image for larger version
ID:	510439   Click image for larger version
ID:	510440   Click image for larger version
ID:	510441   Click image for larger version
Randy Repp
Old 04-18-2019, 09:05 AM
johnta1 johnta1 is online now
Any head flow specs?
Thanks for the pics/info.
Old 04-18-2019, 10:51 AM
Working on the flow numbers now. Many more pics to come.
Randy Repp
Old 04-18-2019, 10:57 AM
Lee's Avatar
Lee Lee is offline
Interesting!
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 04-18-2019, 11:43 AM
JLMounce JLMounce is offline
Dare I say it, the casting quality looks (at least on the surface) to be as good, if not better than my KRE's.
-Jason
1969 Pontiac Firebird
Old 04-18-2019, 12:06 PM
The heck with flow numbers, lets see how well the seats are installed as lately this has been a mess on a lot of heads, to the tune of being able to get a .020" feeler gauge in between the seat and the bottom of its Bore!
Such is a snapped off valve in the waiting once enough run time gets on the heads and the seat gets yanked all the way in!
Don't get me wrong I don't mean that's the quality level of these heads , I just want to see how 50 or so pairs of them turn out!
Old 04-18-2019, 12:30 PM
gtofreek's Avatar
gtofreek gtofreek is offline
I have seen where the seats do not get set all the way down against the head. This can happen for a few reasons.
1. While installing seats, seat lubricant can get under the seat and prevent it from seating. I get the seat started and blow the lube out from under the seat before I drive it the rest of the way in.
2. More importantly, driving the seats in with a hammer other than a dead blow hammer will cause the seat to bounce up a few thousandths when it hits the bottom of the seat pocket. We tested this extensively. I put seats in aluminum heads with a minimum of .008" press-fit[.002" more than industry standard]. When I tested driving the seats in with a standard steel hammer, I could not get the seat to sit flush no matter how hard I hit it. Then using a dead blow hammer, 1 wack and seats were seated. From now on, I only use a dead blow hammer to seat the seats.
3. If the chamfer on the seat insert is not radiused[I use a Scotchbrite wheel to radius and smooth the chamfer] it can scrape aluminum off the side of the seat pocket and roll it down under the seat. In this case, you will never get it seated. This scenario usually ends up with a large gap like the .020" you mention. The seat bouncing up off the bottom of the seat pocket usually ends up with only about .003"-.005" gap.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 04-18-2019, 02:11 PM
grivera's Avatar
grivera grivera is offline
GoatZilla - thank you for taking the time to share this info.
Paul - Great info. On these mass produced heads, are the seats installed by machine/robot?
Will Rivera
Old 04-18-2019, 02:34 PM
72projectbird's Avatar
Those are pretty interesting! The price is great if they prove to be a worthy competitor to the Edelbrocks and KREs.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 04-18-2019, 02:56 PM
Two_70_Converts Two_70_Converts is offline
Flow chart from Hi-Performanc Injuns face book page
Old 04-18-2019, 03:13 PM
Stan Weiss's Avatar
Nice Numbers.
Since I don't do FaceBook. Does it say if the exhaust is with or without a pipe?
Stan
Pontiac Pump Gas List
Old 04-18-2019, 03:38 PM
Nice Numbers.
Stan
1/2 inch radius intake plate and short stack exhaust tube
Randy Repp
Old 04-18-2019, 06:48 PM
Default Eddy vs SpeedMaster Comparison
Here's a Simple Comparison of Edelbrock 72cc CNC Heads and our SpeedMaster 72cc CNC Heads.
These are as cast numbers using a Superflow SF600 @ 28". Winning Numbers are in RED.
Price Comparison is using Summit's sale price on Edelbrocks and High Performance Injuns sale price on SpeedMasters. Both include shipping.
More Flow for Less Dough. What else can you buy with your $1266 $aving$? Intake? Cam/Lifters? Headers? All of this!
Fully machined heads with seats and guides but no valves, valve springs, retainers, etc are also on sale at $1549 a pair with shipping included.
PayPal Accepted at PayPal.me/RPM.tv or send checks to:
1632 E Northfield Dr #500
Brownsburg, IN 46112
Randy Repp
Old 04-18-2019, 07:06 PM
ponjohn's Avatar
ponjohn ponjohn is offline
What bore size was used for the flow data?
Old 04-18-2019, 07:21 PM
grivera's Avatar
What brand are the valves, springs, retainers, rocker studs, etc?
Will Rivera
Old 04-18-2019, 07:38 PM
4.150. These will flow higher with a larger bore and even more once the CNC porting programs are completed.
Randy Repp
Old 04-18-2019, 07:43 PM
Everything on the complete heads comes from SpeedMaster. We will be offering these castings with various aftermarket springs, valves etc.
You can also take advantage of the machined bare castings with seats and guides but no valves, springs etc for only $1549 a pair including shipping.
Randy Repp
