Old 03-20-2019, 09:55 PM
grd777 grd777 is offline
Default need help to put back my a/c in my 75 t/a
my car is a 1975 t/a were the a/c was removed way back , try to put it back in . need to know this
the compressor has a wire harness with a black ground and a green wire ,were does the green wire hook up to
also there seems to be a black small vac hose that comes out from the firewall , were does that go
Old 03-21-2019, 05:23 AM
Black wire is a ground, usually hooks up under the bolt securing compressor to bracket.
Dark green wire is essentially the live wire from the AC controls, which runs via pressure switch on the AC drier.
There is sometimes a light green wire that runs to the carb solenoid to bump the idle up when AC is turned on. It may be a separate harness on early models.
Small black vacuum hose is likely also for heater box controls. It has one main vacuum source and the control changes where it is direct to.
Old 03-28-2019, 05:34 PM
have two of these compressor to a/c jumper harness but someone cut of some of the connectors , anyone have a photo of one that i can compare to
Old 03-28-2019, 06:49 PM
Not sure this helps much for a '75 400, this is from a '77-79.
403 Firebird AC compressor loom idle solenoid by Aus78Formula, on Flickr
Likewise, here's similar era chev but they've jumpered the wire that goes to the blower motor onto same setup.
https://www.camarocentral.com/1973_1..._p/wir-265.htm
Old 03-28-2019, 07:02 PM
ok that is great i have one like this .the other one has a thermal limiter on it would that be for my 75
Old 03-28-2019, 07:20 PM
Ignore all that, 75 used the combined compressor and heater harness as one including the thermal limiter.
Do you not have electrical diagrams or workshop manuals for it? Haven't saved every second photo you saw online thinking it might be of use one day?
8 days later no one with a 75 has bothered to chime in.
Old 03-28-2019, 07:22 PM
https://www.firebirdcentral.com/Prod...Code=HTR%2D166
https://www.firebirdcentral.com/product_p/wir-2025.htm
Old 03-28-2019, 07:39 PM
sorry have no manuals , was hoping to get info here
Old 03-28-2019, 09:22 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Wire and hose pages.
ID:	509151   Click image for larger version
So long, farewell.
Old 03-28-2019, 09:24 PM
Good one, saved.
Old 03-29-2019, 06:25 AM
very good and thanks . only nee to know now ,were does the brown wire from the thermal limiter connect to
Old 03-29-2019, 06:25 PM
Originally Posted by grd777 View Post
very good and thanks . only need to know now ,where does the brown wire from the thermal limiter connect to
It goes into the wiring harness on the driver's side. Pictures are of '74s.
ID:	509221   Click image for larger version
So long, farewell.
Old 03-30-2019, 07:25 PM
Great thanks. Looks like the po cut it off ,hope I can find it
Old 04-21-2019, 07:35 PM
is the brown wire the power source
Old 04-21-2019, 10:00 PM
I never checked. I'll try and pull a book if no one else can answer.
So long, farewell.
Old 11-13-2019, 07:26 AM
any one can help me on this brown wire
