Old 05-27-2019, 11:17 AM
Rusty4cyl's Avatar
Rusty4cyl Rusty4cyl is offline
Default Intake Gasket's
What is the best and strongest intake gasket's for an Edelbrock wide port with a Blower. Your help is greatly appreciated. Thank's Rusty
Blown 4cyl's to the front
Old 05-27-2019, 11:40 AM
GTOGEORGE's Avatar
You might have to o-ring if you are blowing intake gaskets.......Sorry I know thats not the answer you were looking for.
GTO George
Old 05-27-2019, 12:49 PM
I agree with George, I have two intakes that have a "O-Ring" style sealing system.
The NASH/Warrior intake modded for EFI being one of them.
A very good shop, machined the O-ring groves in the intakes. The O-rings I use are a "rubber" type material and .043" in diameter. I use a .060" wide groove .025" deep. Never has a leak using that system. Chris Piper is aware of the sealing system too.
Old 05-27-2019, 01:27 PM
73 TRANSAM 73 TRANSAM is offline
My engine guy told me that he uses the fiber gasket from Mcmaster Carr. I bought that material and it is a green material and that's what the blower setup uses.
Old 05-27-2019, 04:59 PM
Rusty4cyl's Avatar
I have a Hogan sheet metal intake, so I am not sure if it is wide enough between port's to o-ring the intake. Thanks Rusty
Old 05-29-2019, 09:53 PM
Drag Star Le Mans's Avatar
I'll ask Roger what he uses with his combo?
DragStarLeMans
Old 05-29-2019, 11:19 PM
Rusty4cyl's Avatar
Thank You Sir
