Old 07-08-2019, 02:23 PM
BLACK 67 GOAT's Avatar
BLACK 67 GOAT BLACK 67 GOAT is offline
Default PUSHROD SNAPPED IN HALF
Anyone ever have a pushrod snap in half? What would cause this to happen?
Old 07-08-2019, 03:31 PM
mysticmissle's Avatar
bad geometry and push rod flex. what head and rocker ratio? guide plates correct? Is this a new combo or making changes?
Old 07-08-2019, 03:42 PM
Mike Davis's Avatar
What Brand?
Wall Thickness?
Spring Pressure?
more info needed......
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 07-08-2019, 09:46 PM
69 Ram air iv heads, 1.5 ratio exhaust 1.65 intake. No guide plates, t & d shaft rockers. Only change was 1.65 rockers on the intake. Exhaust is what broke. Pushrods have about 100 passes on them. I've never seen one break like this without being bent at all.
Old 07-09-2019, 07:11 PM
Did you stack the spring? Should be straight forward as you assumed. Unless the push rd is hitting the head and forcing it out of normal geometry. Then the leverage would snap it.
Old 07-09-2019, 08:30 PM
Originally Posted by Mike Davis View Post
What Brand?
Wall Thickness?
Spring Pressure?
.116 WALL 5/16 O.D.
PAC 1243 I think 240 on the seat and around 650 open
Old 07-09-2019, 08:31 PM
I'm not sure I know what you mean. What is stack the spring?
Old 07-10-2019, 02:12 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
That's a lot of spring for 5/16" pushrods. Just sayin'.
Old 07-10-2019, 07:16 AM
Well it does not look bent at all, atleast from your photo so you might just chalk it up to a defective tube section with a internal stress point, but still 650 psi open with 5/16" Rods is not something good to do I would say!
Old 07-10-2019, 07:40 AM
Suspect a Tight Valve Guide
Old 07-10-2019, 10:03 AM
tom s tom s is online now
RA IV heads came with 11/32 pushrods as I remember.I know your 5/16 are heavy wall but as stated too much spring for them.Tom
Old 07-10-2019, 12:02 PM
unruhjonny's Avatar
wow!
I would expect to see at least some bending - but that looks like a clean snap!?
I have bent one when a valve stuck on me, and have a second bent one I pulled from a grenaded engine - but have never seen a clean break like that before!
I wonder if Steve nailed it?
EDIT: I just noticed Tom's reply...
1970 Formula 400
Old 07-10-2019, 12:28 PM
Thanks for all the replies. I agree, I need some larger pushrods. I may try to get some tapered 3/8" in there or 11/32" at the very least. I may be wrong but I think 11/32 would be around 20% to 25% stronger than the 5/16".
Old 07-10-2019, 01:28 PM
11/32 are had to find,I think I got mine from Manton?Tom
Old 07-10-2019, 02:39 PM
Steve C. Steve C. is offline
If you were to build a 5/16 pushrod and a 3/8 pushrod at the same length and same wall thickness diameter the difference in column strength is 96.7 percent different.
This according to Manton.
Old information here:
Old 07-11-2019, 07:32 AM
AG's Avatar
AG AG is offline
Do you run a stud girdle?
Old 07-11-2019, 08:25 AM
Buckling Anslyses separates the Mech Eng men from the boys.
When i lost an EXH pushrod it "Z"'d into 3 straight pieces. i think the CYL head prevented the high end from bowing.
Suppose you could end up with a clean 2- piece snap. As it bowed and broke at the place of maximal bow. But no constraint by the Head
Old 07-11-2019, 09:30 PM
No girdle, shaft rockers.
Old 07-11-2019, 09:34 PM
Talked to Al at Manton. He is very knowledgeable. He said that their 5 series 11/32 are about 42% stronger than the heavy wall 5/16 I have in there now. I ordered a set yesterday.
