What the measurement does is match the manufacturing call out for how the starter was made as per the print. When they make the starter gear they make it so that if the shaft it slides on is 1/8" from the tip of the flexplate tooth tip the gear will mesh correctly. It's how the starter is checked at quality control when they make them. The variance in the castings is why they use the gear shaft as a reference. Last edited by TAQuest; 09-01-2019 at 07:18 AM. |
The OP has an aftermarket mini starter. Probably doesn't have a shaft sticking out past the bendix. Drive end bearing on them is behind the bendix. No nose and shaft to do the measuring.
Clay |
| The Following User Says Thank You to "QUICK-SILVER" For This Useful Post: | ||
I guess you would have to use a paperclip then. Or just eyeball it and give it a try. I just went over the thread and I still don't see anything about a mini starter..... |
Clay |
I wouldn't know that because I can fit a standard starter on all of my cars including the one with Doug's Headers. No minis. |
| The Following User Says Thank You to TAQuest For This Useful Post: | ||
My understanding is, technically, the variance of tolerances is the mount pad of the block, and potentially effected by the line bore.
It can also be impacted by flywheel/flexplate runout. The pads on the mini starter are generally CNC cut, so doubtful they vary too much. I just did mine recently, and the pad of the mini starter was wider than the pad on the block, and had to bevel the edge because it was making contact with the trans bell, and not seating properly. That is a Summit mini, before anyone asks. Usually, once you've determined the stack of shims you need, you never have to do it again, just reuse the same stack on any/every starter you bolt up. (which further supports the block factor) Ask the guys who have tried to shotgun it by mounting and testing shims in use who are using IMI mini starters, see what they say. The drive gear on the starter is considered 'sacrificial', to save the ring gear, because it's much easier to swap a starter than one of those. And the IMI gears are softer than most, or is what I have found. Others too, apparently. .
| The Following User Says Thank You to HWYSTR455 For This Useful Post: | ||
And 64 Speed already posted that he was going to use the Paperclip method. Why waste people's time searching for a video link when you could have easily added it to the post AGAIN. Just a comment. Don't get upset by the suggestion. Tom V.
| The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
I had a starter on a 400 Chevy small block that was too far away with no shims. I didn't realize you could use 1/2 a shim to bring it closer. Old too soon too late smart.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
| The Following User Says Thank You to track73 For This Useful Post: | ||
Just for reference as to what you can run into;
My standard starter and 400 block uses no shims at all to mesh properly. My other Pontiac with a standard starter and 400 block uses no shims either. A standard starter on the 428 I used to own used no shims at all. The 1972 Bonneville I used to own with a 455 and standard starter used no shims at all. My 68 Firebird with a 350 block used no shims at all. None of the other Pontiacs I have owned used shims either. The 302 in my 69 Z needed shims. The 400 small block in my chevy truck uses shims. |
Flywheel/flexplate is special for the 400 also. |
I knew that was the case many years back and purchased some, but I tried to locate a nose for that starter to no avail. I put on a 350 flexplate with a balance plate. I already had a 350 starter and flexplate. But looking back I wish I knew about the half shim deal.Too soon old late too smart.
It's just just the staggered pattern that was used with the larger 168 tooth flexplate/flywheel. These tended to be viewed as "big block starters", but the truck 350s also used them.
The 400 SBC starter I had was the one with the staggered bolt pattern. I am pretty familiar with 400 SB Chevys since I used them in my stock cars in the 80’s.
Well none of these methods will work for me cause I have a mini starter. It has no shaft just the teeth stick out. I pried the bendix out and it just barely contacted the flywheel so I will shim for a little more engagement and hope for the best. Would be really nice to get this right on the stand
As for preferred testing method, same as TomV & use a paperclip here.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
| The Following User Says Thank You to krisr For This Useful Post: | ||
#38
#39
hi guys, I have a summit mini starter on my 455 74 ta. I used shims and the paper clip method. pretty easy and this was on the car. my oem starter used shims also. BLUE TA
#40
Was your TA an automatic by chance?
