Old 09-10-2019, 08:27 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Originally Posted by cgeise View Post
the boost controller was adding pressure to the back side of the waist gate in small increasing amounts very quickly -- the fuel pressure regulator added fuel based on boost pressure ie boost referenced and if I remember right timing was at about 25 degrees over 12-15 lb boost . Boost controller setup was 12lb springs in the waste gates and then every lb of c02 on the back side of the gate increased boost by aprox a lb -- data recorder will tell you exactly how much.
Yeah, we're using co2 on the dome to control boost pressure, that's under control. We're currently not ramping in the boost after launch as the chassis has been able handle the current boost level.
What I'd like to be able to do is spool up faster on the t-brake.
After retarding timing while on the t-brake, we're able to build more boost, went from 6 to 11lb. We have one run so far with the launch increase. The datalogs indicate the converter is too loose, we were out of rpm 6.6 seconds into the run.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1722
Old 09-10-2019, 12:17 PM
cgeise's Avatar
cgeise cgeise is offline
what gears in the ass end ???and what is the converter slip at the top end ??? at 185mph there should be plenty left ???
  #1723
Old 09-10-2019, 08:12 PM
RAIV-Z's Avatar
186mph
3.89 with a 33.5 tire, converter slip without tire growth is ~16.7% at 7660rpm.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1724
Old 09-14-2019, 10:07 PM
RAIV-Z's Avatar
186mph
PTC want's me to try changing the fluid from TCI-950650
Automatic Transmission Fluid to John Deere Hygard to see if it help with tightening up the converter 300-400 rpm, I'll give it a try but I expect that converter mods are going to be required.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1725
Old 09-22-2019, 09:34 PM
67'7F6'Bird's Avatar
https://www.facebook.com/ed.page.733...5220970613253/
  #1726
Old 09-22-2019, 09:46 PM
Originally Posted by 67'7F6'Bird View Post
Looks like she left hard and good!
  #1727
Old 09-22-2019, 10:03 PM
RAIV-Z's Avatar
1.222 60ft, the driver needs to get used to the added launch boost.
Name:	Raven 1.222 60ft.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1728
Old 09-22-2019, 10:12 PM
I think the drive is killing it Ed.... you guys are creeping up on the tune...when all is said and done, you will be in the history books in my opinion....you will be in the 1 teens for sure
  #1729
Old 09-23-2019, 07:11 PM
RAIV-Z's Avatar
Youtube Link
https://www.youtube.com/watch?v=UhIBaIq5kQA
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1730
Old 09-23-2019, 07:29 PM
RAIV-Z's Avatar
Thanks Scott,
We only have a few more outings up this way, one coming up Sunday and hopefully at least 2 more after that depending on the work schedule. We've been increasing the tire air pressure over the last 3 time out, all runs on Saturday were at 8 3/4lb. We still have not made any chassis adjustments.
That last run was a 7.636 @184.45mph. Between the TPS and the rev limiter, not a good run.
Name:	Raven 1.222 60ft more data.jpg
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1731
Old 09-23-2019, 10:09 PM
shaker455's Avatar
Not the same without "Pontiac Mike"
  #1732
Old 09-26-2019, 07:05 AM
grandville455's Avatar
From what I've seen it may only go 150-200 tighter, It's gonna need a an adjustment Imo, You guys get that converter right and it will scream!
Darby
M/T 275/60 ET SS Drag Radial
  #1733
Old 09-26-2019, 07:59 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
i tried this 2 summers ago with about 4 quarts of tractor fluid vs standard type f style. my converter tightened up about 300. I think Jason henessy told me its about 50-75 rpm per quart. depending on your capacity.
i think it is a cheap way to see what your converter wants to be happy. It may save a second pull and send for restall with minimal effort.
my car slowed up. but its not a 1500 hp turbo car its just a dumb bracket car. lol
  #1734
Old 09-26-2019, 10:16 PM
RAIV-Z's Avatar
I tried 4.5 quarts last week, seemed to help. Drained and replaced another 4.5 quarts today. Plan on racing Sunday. The converter changes will happen over the winter, also time to tear down and inspect the engine after ~2 racing seasons of bad tunes and abuse.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1735
Old 09-28-2019, 04:54 PM
taff2's Avatar
taff2 taff2 is offline
We switched from Amsoil ATF to the JD Hygard normal viscosity in a BBC 540 twin turbo combo - it dropped the finish line rpm by nearly 500, but it also affected the launch rpm . We ended up at approx. 50/50 JD and Amsoil ATF, launch was back where we wanted it but finish line rpm dropped from 7100 to 6800. The JD is very good oil-we use it in our U4 trans builds but you must use a screen filter.
  #1736
Old 09-28-2019, 08:12 PM
Have you considered a bolt together converter you can change? I ran a coan billet bolt together... stators are only a few hundred bucks...
At your level I would say go that route..upfront cost is high but worth it over a season or 2..
  #1737
Old 09-29-2019, 10:48 AM
JSPONT's Avatar
JSPONT JSPONT is offline
X2^^^^^^
  #1738
Old 09-29-2019, 04:50 PM
RAIV-Z's Avatar
Originally Posted by JSPONT View Post
X2^^^^^^
I do have a PTC bolt together converter
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1739
Old 09-29-2019, 09:08 PM
JSPONT's Avatar
Cool very easy then. Just messy! lol I just changed my stator this weekend. I have a 9.5 ptc bolt together.
  #1740
Old 10-04-2019, 01:42 PM
cgeise's Avatar
be careful about getting the convertor to tight -- it will destroy the tire on launch -- graphs are hard to read but looks like your in the ball park -- BTW all those knobs on shocks and all the holes in the 4 link are there for a reason -- play with them. you want controlled wheel speed at the launch and then keep it planted after.
