Old 11-07-2019, 08:01 AM
Hillard's Avatar
Hillard Hillard is offline
Default Which fuel do you prefer? Gas, E-85, or Methanol?
Working on a new build. Shooting for a low 10 second 1/4 mile bracket car. I was originally going to build a good street car and purchased a Magnafuel 300 pump and an E-85 dominator. I'm not against selling those and purchasing better stuff. I've always used race gas, but think I'd like to switch to E-85 or methanol. What's your opinion?
Old 11-07-2019, 08:12 AM
Mark G Mark G is offline
91 pump gas street driven 8 secs dot tire
Old 11-07-2019, 08:31 AM
Hillard's Avatar
12.5: compression. Not going to run pump gas.
I like the idea of the power and added consistency of alcohol, but not sure of the downsides.
Old 11-07-2019, 08:50 AM
firechickenman's Avatar
firechickenman firechickenman is offline
I run 91 pump gas but if I had a 12.5:1 engine in a dedicated bracket car, I'd be running E85 without a doubt. I would be running it in my Firebird except it would require hauling fuel on Drag Week.
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
Old 11-07-2019, 09:00 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
if you have access to quality e85 and do not already own a methanol carb, e85 FTW. I have a 4150 BG 950 cfm sullens carb availalbe if you do not need a domi.
Old 11-07-2019, 09:46 AM
Hillard's Avatar
I figured I would buy a drum. There's a local distributor for Renegade race fuels. who stocks race E-85. I think the dominator will be just fine.
Old 11-07-2019, 10:36 AM
JSPONT's Avatar
JSPONT JSPONT is offline
E85 where I live is popular and very available for about 1.85 per gallon. A friend of mine runs 30 psi in a bbc and goes 7.00@203 on E85. Street car he can drive all over. My other friend run a 13.5 to 1 Ford motor 9 second street car E85.
It would be the most cost effective that works if you have access.
Old 11-07-2019, 11:56 AM
If you're buying by the barrel, I'd go straight alcohol. (methanol)
It would have more consistency and probably make more power than the E85. Cost may be cheaper also. (it was when I was buying it anyway)
Old 11-07-2019, 12:06 PM
JSPONT's Avatar
Then you have very frequent oil changes also, it's a catch 22. Is it just a drag car or street duty too?
Old 11-07-2019, 01:19 PM
Bill Eveland's Avatar
I can get 110 for 5.99 a gallon here so its an easy choice. I can get 112 for 7.59 a gallon.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 11-07-2019, 03:37 PM
Hillard's Avatar
Drag only.
A VP rep told me to go to methanol also. More power, better cooling, and more consistent.
Old 11-07-2019, 04:17 PM
Hillard's Avatar
Who here is running methanol and what are the down sides to it? Just more oil changes? Do you go all season without worrying about the corrosive nature of it? Just clean things out before storing it for the winter????
Old 11-07-2019, 04:45 PM
lakefect lakefect is offline
there is no down side if you know what your doing. i change my oil twice a season [vac pump helps] just get your tune up right and get it good and hot when your done for the night. drain everything at the end of the season and put some atf in the pump and your done. oh and i run a qt. of klotz lube in a 55ga. drum of alky
Old 11-07-2019, 04:58 PM
GTOGEORGE's Avatar
Ditto............... No problems, even starting in 39 degree temps, i just clean the carbs every few races. I also so drain the oil every few races and separate the bad from the good oil and put it back in (normally maybe a quart.....also use Brad Penn) with new.
GTO George
Old 11-07-2019, 05:05 PM
so i coinicidentally had this conversation with a friend tuesday night. Div 1 Pro champ a few years ago. Multi track champion travels to big foot brake races. Runsc arb on alky. mid to low ten sec car that he slows way down to race 1150-1200 range instreet and pro. He says he has a little trouble keeping enoiugh heat in the motor and uses alot of fuel over a weekend. as in barrels. He double enters and usually goes rounds. He went to a big foot break race last weekend in SC and won the larger money event and runner upped in the secondary race last friday. went 4-5 rounds in each class saturday and sunday. he made 48 runs over the weekend and used 60 gallons @ $3/g of fuel.
he says he picked up a ton of torque over pump fuel. his 60s are about .1 quicker. He says he considered running e85 but was worried about finding a consistent source of quality fuel. In NE we have it but it is usually in the e75 range. When i go to Norwalk i come back with a barrel of e85 because its so much better than wht i have around here. In the 12:1 range you will be fine with E70+ lots of factors to consider.
Old 11-07-2019, 06:28 PM
I just drive my 8 sec street car to the local gas bar ...
Old 11-07-2019, 09:46 PM
wolfs63's Avatar
wolfs63 wolfs63 is offline
E 85, 13 to 1 compression, at 2 dollars a gallon it can't be beat.
Old 11-08-2019, 06:50 AM
Hillard's Avatar
I appreciate all the input. To be clear I'm not concerned with cost as much as pros/cons concerning the affects of the different fuels. This is a purpose built bracket car. It will not be licensed and driven on the street. I intend on purchasing fuel by the drum. The VP rep told me that methanol has the best cooling properties, makes the most power, and the car is more consistent. E-85 is a close 2nd and race gas behind that. Downsides of methanol being more oil changes, but is that all? Again, I appreciate the input. I've only ran race gas before. I've never run alcohol.
Old 11-08-2019, 09:45 AM
ok again ,there are no need to be changing your oil any more than on gas [as long as your tune up is correct]
are you looking at carb or injection?
Old 11-08-2019, 12:07 PM
Hillard's Avatar
Carb
and I will be running a vacuum pump.
I was just quoting what the VP guy said...and I've heard others say to change the oil a little more often.
