Old 11-08-2019, 12:32 PM
Usually the idling or slow driving causes too much alky in the oil.
Many use a system to drive up to the lanes and back on gasoline.
This will save alky also.
Probird uses a system like this on his car. (or did anyway)
Old 11-08-2019, 01:02 PM
Bill Eveland's Avatar
The 2nd system on gasoline could be helpful in colder weather to help warm up the engine also
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 11-08-2019, 02:26 PM
Hillard's Avatar
Hillard Hillard is offline
That sounds very interesting. I'm curious how this 2nd system is setup and how one would switch back and forth. Even though it's a methanol carb it will drive around the pits just fine I assume??
I'm feeling kinda stupid right now, but like I said I've never ran alky before and have never even looked into what people are doing for fuel systems to run it.
Old 11-08-2019, 03:03 PM
GTOGEORGE's Avatar
I'm pretty sure the gas doesn't go thru the carb, it would never work. I tried running gas through my carbs and it ran richer then heck, has to be delivered in another way.
GTO George
Old 11-08-2019, 03:13 PM
Correct, most are a system where a separate little pump that pumps gas from a separate tank to spray into the top of the carb/throttle body.
The alky pump is usually off if electric pump.
The gas setup privides just enough to keep the engine running, so no jack rabbit starts etc.
Old 11-08-2019, 05:34 PM
Hillard's Avatar
Got it. Makes sense.
Old 11-08-2019, 08:54 PM
ejw's Avatar
ejw ejw is offline
I had bad luck w sullen carb and e85 from gas station, never ran right, sent same carb to Rupert and never looked back, runs great no issues, runs cool in Midwest heat, cheap, I change oil twice a year, only thing added was vacuum pump and lean out valve. Drag race only. I by in 55 gal drum and distributor takes drum back when empty
