Old 12-22-2019, 06:10 PM
grd777 grd777 is offline
Default odd date code on my 72 steering box
i am pretty sure that this is the original steering box with all the crude on it . the date code is odd 4a298 it does not have the big S on it . anyone can help
Name:	IMG_2523 (002).jpg
Old 12-23-2019, 02:28 PM
any way i can check what ratio i have with the box off the car
Old 12-23-2019, 11:45 PM
FunctionalShaker FunctionalShaker is offline
Your cover is marked with part # 7812145. Parts manual says it should be 7812147 for 67-72. Don't see that number used on any up to 81.
Old 12-24-2019, 08:19 AM
77 Canamman's Avatar
I surmise that the box is from a later vehicle. The date code for an original box from this era is a simple Julian date code.
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
Old 12-24-2019, 09:29 AM
thanks for the info , that is weird that this is not the original steering box . there was so much grease on it ,it must of been on the car for many , many years .
i have another box off a 71 car but not sure of the gear ratio , were they all the same boxes used in 1971
Old 12-24-2019, 04:52 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
Because usually the cover PN will be more than just the cover casting number (bushing added, etc.).
So long, farewell.
Old 12-26-2019, 08:31 PM
If someone has an original 72 cover they can show, that will resolve the issue.
Old 12-26-2019, 09:40 PM
Plan on ck'ing the cover on my '72's box on Sun.
Both grd777's & my '72 are built the same week of '72.
Old 12-26-2019, 11:46 PM
ladytata's Avatar
ladytata ladytata is offline
I can snap a pic off the 71 tomorrow too
Old 12-26-2019, 11:57 PM
ladytata's Avatar
Had one in phone
Old 12-27-2019, 12:20 PM
Originally Posted by ladytata View Post
Had one in phone
This must be fo a 1971 car
Old 12-27-2019, 03:45 PM
Yes, it was from her '71. The casting number of hers shows the later '71/early '72 casting number. Later '72 would have used the '145 casting number, but my '74s probably used the same number. Are you sure this isn't from your '75?
So long, farewell.
Old 12-27-2019, 04:11 PM
I took this of my 72. I was cover in a lot of grease and dirt which to me looks like it was original to the car. But who know what was done over the years. Just can not figure why it has a weird date code number
Old 12-29-2019, 12:28 AM
ladytata's Avatar
I have a lot!,,,, more. I’ll see if I can dig some out, but hfr is right
Old 12-29-2019, 12:11 PM
I hear you. This was on one of my '74s. Shipping date was 2-23-74. As you can see, the assembly date is way past the ship date. But, the cast date of cover (if that's what it is) may have been close (19 may have been the mold number though).
So long, farewell.
Old 12-29-2019, 12:44 PM
Do you read my date code 4A298 or 44298
Old 12-29-2019, 02:34 PM
I read it as 298, missing the year. The 4A, is like the 1A on the one I posted (assembler or inspector stamp). I also see a 2 stamped on the cover, maybe it was the year. Being that yours was built right before the strike, maybe it was fixed under warranty early on after purchase. I would read the cast date of cover as 83 2 (March 25th, 1972), but again, I could be wrong.
So long, farewell.
Old 12-30-2019, 12:47 AM
ladytata's Avatar
I’ll dig a few years out tomorrow as long as it doesn’t snow
Old 12-30-2019, 07:10 PM
necdb3's Avatar
necdb3 necdb3 is offline
My 3/20 built 72 TA has 063 2. I tried to get a picture but it didn't turn out well. March 3rd. 17 days before assembly.
Old 12-30-2019, 10:31 PM
Transamric's Avatar
I'm reading that date a bit differently. I'm seeing it as 4 298 with that second character not as an 'A' but as a triangle which likely was an accidental "place holder". I've seen those triangle characters on other stamped in cast parts from GM cars often placed in the second position.
So 4 298 would simply be the 298th day of 1974, for early 1975 model year production.
