Old 12-29-2019, 07:25 PM
grahamp grahamp is offline
Default 1969 Judge Engine block
Am I right in thinking that the early 1969 Judges used the two bolt 9790071 block which was later changed to a four bolt set up, the 9799914 block? Appreciate any information on this. Many thanks
Old 12-29-2019, 07:52 PM
thepontiacman's Avatar
69 RA3 are 2 bolt main. RA4 is 4 bolt main. 9792506
0071 block for 69
9799914 used in 70. both 70 RA3 and 4 are 4 bolt main. 9799915 RA4
Old 12-29-2019, 08:37 PM
Pontiacman, many thanks
Old 01-02-2020, 06:23 PM
Default 1969 GTO Ignition upgrade
I recently installed a Pertronix Ignitor in the distributor and threw out the points! Works perfectly except that the hood tach no longer works. Has anyone been able to solve this problem
Old 01-03-2020, 03:49 AM
kyle_blake's Avatar
kyle_blake kyle_blake is offline
i think the manual says you need a resistor wire in series on the tax lead?
69 Gto, 390 posi gears,th400 w/jim hand converter/406 pontiac/#64 HEADS/ 10:1 compression/ 190 PSI with/ TRW 160 thou domes / hooker headers 1 7/8, PRW 1.5 rockers, 405 Crower Springs, Holley 750 vac with proform upgrade, Performer RPM on points / 284 H Single Pattern Crane
