Old 04-17-2019, 09:11 AM
62cat's Avatar
62cat 62cat is offline
Default Acquired 66 GTO
I recently acquired a 66 GTO. On the fence on what to do with it. Its pretty much all there body wise. Interior is from a 67. No drivetrain. PHS says its a 335hp wide ratio 4sp 3:55 safe-t-track. Console and not much else. Barrier blue, black gut. I will post some pics later. I always wanted to build a gasser style car straight axle and all or I have been toying with building it pro-touring style LS or modern HEMI with a manual. What would you do with it.
Old 04-17-2019, 10:38 AM
wbnapier wbnapier is offline
Pro-touring, but with a Pontiac driveline. 5-speed, rebuild the rear end, AC, quick ratio steering, upgraded suspension, front discs, etc.
Return the body, trim, glass, and interior to stock. 15" '66 GTO Rallye wheels. Staggered tread width, so you have a little more meat in the back.
I'd keep it carbureted. Was it a tri-power originally?
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 04-18-2019, 07:56 AM
62cat's Avatar
Default GTO
Heres how it sits right now. Still on the trailer.
ID:	510417   Click image for larger version
The Following User Says Thank You to 62cat For This Useful Post:
Old 04-18-2019, 08:14 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Wow you have your work cut out for you! Barrier Blue is a great color and you have a clean slate to start with. Endless options and I would keep a traditional Pontiac engine under the hood above all else.
Chris D
Old 04-18-2019, 10:58 AM
You're in deep! Looks like a good project. Yes, 100% Pontiac power plant.
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
Old 04-18-2019, 10:58 PM
RedDirtRoad RedDirtRoad is offline
I just bought this rusty 66 GTO Barrier blue car cause I needed a donor frame . No title but at the time I didn't care
After I bought it I decided to get the PHS for it to see if it had Posi
Turns out the car is an original 4sp, 3:55 posi rear and true tri power car too
At this point I rather sell what I have rather then
Take the frame and scrap it
The Following User Says Thank You to RedDirtRoad For This Useful Post:
Old 04-19-2019, 02:08 PM
geeteeohguy's Avatar
I would keep it Barrier Blue (you never see that color anymore) and put a parchment interior in it. Do the drivetrain and suspension like you want. I would keep it Pontiac, add AC, and add a 5 speed. Make it a comfortable car that can eat up the road on long trips.
Jeff
Old 04-19-2019, 11:14 PM
77 TRASHCAN's Avatar
An LS or a hemi???? Really?
It's still a free country, do what you want to do. Both those engines will cost more to make respectably turn key power plants than a Pontiac will.
A Pontiac GTO was like a revered car in its day. A stock 66 GTO is a crazy cool car.
There's still Pontiac engines and transmissions around, especially in your neck of the woods.
I wish you well on your endeviour!!!
Shut it off
Shut it off
Old 04-22-2019, 08:01 PM
GT182's Avatar
GT182 GT182 is offline
Do the LED tail lights and parking lights, plus rear sequential signal lights.
www.webelectricproducts.com
STS-1 Sequential Turn Signals, $69 - For cars with 3 lamps on each side. Guaranteed for as long as you own the car. If they stop working just send the modules back and they will be replaced.
And congrats on getting a 66 GTO.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
The Following User Says Thank You to GT182 For This Useful Post:
Old 02-13-2020, 10:55 AM
62cat's Avatar
Default 66 GTO Progress
Got the front end rebuilt and installed with BMR 2" lowering springs and polygraphite bushings. Want it to handle and brake well so we can drive the crap out of it. Boxed and repaired the rear part of the chassis. Going to box the center frame and get the body bolted up with the new mounts. its just laying on the chassis in the photo.
ID:	531797   Click image for larger version
Old 02-13-2020, 04:40 PM
SR-71 SR-71 is offline
Very nice color that is hardly even seen. Personally I would restore it and find a 389 in the date range of production and build it with roller cam and rockers. As for the tail lights I'm definitely not a fan of the Mercury Cougar lights on a GTO they look out of place. If you sell plan on selling it later it will command a far better price than a custom with a Chevy or Dodge engine in it.
The Following User Says Thank You to SR-71 For This Useful Post:
Old 02-14-2020, 11:17 AM
62cat's Avatar
Its going to be Barrier Blue. Haven't decided on drivetrain yet. That depends on budget. Somebody mentioned sequential taillights i wouldn't change the housings though. I have a rebuildable 428 & 455. It will get the stick probably a 5 speed o/d.
Old 02-28-2020, 11:15 AM
62cat's Avatar
Default Progress on chassis
Boxed the chassis and sprayed it with Eastwood chassis black. Built a body dolly so i can roll it around. Received sheet metal to begin body. Rockers, driver floor section and rear window and package shelf sheet metal. Follow the build and our others on Instagram @Grumpy_German_Garage
ID:	533216   Click image for larger version
ID:	533217   Click image for larger version
ID:	533218   Click image for larger version
Old 02-28-2020, 11:56 AM
ZeGermanHam's Avatar
Nice progress. I just went through the same process of boxing in the frame on my '66. Interesting to see that your frame differs from mine in the area where the front section is welded to the side rails in the mid section.
1998 BMW 328is (track rat)
Old 03-06-2020, 09:26 AM
62cat's Avatar
Default Update
Tackled the inner and outer rockers this past weekend. Drivers side so many spot welds were never penetrated from day one. Passenger side they made sure that was on. Goodmark products. Very good quality in shape and metal thickness. Floor pan was also a really nice piece.
ID:	533933   Click image for larger version
ID:	533934   Click image for larger version
ID:	533935   Click image for larger version
Old 03-06-2020, 09:32 AM
62cat's Avatar
Default Update 2
Passenger side pics. Also the UMI shocks we installed. I'm building this one to handle. Not pro-touring just an all around well balanced driver.
ID:	533937   Click image for larger version
ID:	533938   Click image for larger version
ID:	533939   Click image for larger version
Old 04-09-2020, 09:41 AM
62cat's Avatar
Default Covid-19 GTO
A little update on my 66 GTO. Welded some holes up and straightened previous butchery on firewall. Decided to see what was hiding on the 1/4 panels. Replace right with the partial and an outer wheelhouse. Fit was pretty good. I also broke out the TIG for this one.
ID:	536786   Click image for larger version
ID:	536787   Click image for larger version
ID:	536788   Click image for larger version
Old 04-09-2020, 09:53 AM
62cat's Avatar
Default Update 4/9/2020
Rear window panel was extreme butchery. Whoever pop riveted a used section right over the old and let the inner panel flop around. I made it right with a new inner and outer panel. Inner is a lengthened Chevelle. Screws and sheet metal are just there for mock up. A piece was fabricated and fully welded to fill the void. So much better.
ID:	536790   Click image for larger version
ID:	536791   Click image for larger version
Old 04-09-2020, 09:59 AM
62cat's Avatar
Default Next
Left 1/4 panel carnage. I knew it was bad. It doesn't even look like they tried. Next order should be here in a few days. Left full 67 1/4, wheelhouse, full trunk assembly, left trunk drop down and the rear taillight panel which just arrived. All from Ames Performance. So im hoping to have it in primer by the end of 4/20.
ID:	536793   Click image for larger version
Old 04-09-2020, 04:32 PM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
That's some great metal work you're doing! Keep the pic's coming. Luv watching here at a distance.
Have you decided on the 428 or 455 yet?
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
