Old 04-29-2020, 09:16 AM
spectramitch's Avatar
spectramitch spectramitch is offline
Default Dominator Rebuild
I am going to be rebuilding my first dominator carb and was told it was a 1050cfm. I looked up the number L80186 and said it was a 750cfm. I read that the boosters can be changed to create a 1050. Can anyone tell me by looking visually if the boosters look 1050? How can I tell if this is a 2 circuit or 3? What rebuild kits do you guys like to use?
ID:	538681   Click image for larger version
Old 04-29-2020, 09:30 AM
If your using the Carb mainly for racing and the car set up lets the motor during shifts drop out of the converter ( very bottom of the power band ) then your better off with a 2 circuit Carb.
Old 04-29-2020, 09:51 AM
The carb is a 2 circuit carb.
Normally the 3 circuit carbs would have threaded in Air Bleeds (6 on the Primary Side and 6 on the Secondary Side with a 3 circuit carb.
With a 2 Circuit carb you will have 4 Air Bleeds that are threaded for brass jets.
But the easiest way to check for 2 circuit vs 3 circuit carbs is to open the throttles completely (and by looking thru the bottom of the carb) look for 4 little brass pipes. (One in each bore) cut off at an angle above the Transfer Slots.
The deal is you have to look in both places as some carbs have been modded from 3 circuit to 2 circuit and the builder left the brass angled tubes in the bores. If it is a true 3 circuit carb all 6 spots on each side will have a air bleed with an opening you can put a small drill bit thru.
Again, this is a carb question not a race car question so I am answering the post.
Old 04-29-2020, 10:47 AM
Mark G Mark G is offline
I let Bob Book do the rebuilding that's just me...
Old 04-29-2020, 04:41 PM
Dragncar Dragncar is offline
You can turn the 750 into a 1050. Some skirts you can remove to get it done I believe. Call Performance Carb and Speed. 909-673-1180. He can explain it all to you.
Its 375$ to have him set up your carb IF you have the right metering blocks. They are another 200$ if you need to buy them. He can turn a 3 circuit into a 2 circuit if thats what you want. Bought the parts from him to get one done for me.
Nothing wrong with learning and doing it yourself if you can. Most of us are not after every single HP available and you can get close doing it yourself.
Old 04-29-2020, 05:26 PM
PAUL K's Avatar
PAUL K PAUL K is offline
The booster will have a skirt at the bottom of the OD. You can carefully remove the skirt and turn it into a 1050. I can't tell from the picture you posted but take a close up and I'm sure we can ID them.
Go fast, see Elvis!
Old 04-29-2020, 05:28 PM
PAUL K's Avatar
My buddy runs the dyno at Book. They build nice carbs and some screaming high RPM engines!
Go fast, see Elvis!
Old 04-29-2020, 06:23 PM
slowbird's Avatar
slowbird slowbird is offline
Ya they're mighty proud of those carbs
Old 04-29-2020, 07:24 PM
Im thinking these are the 1050 boosters.
Old 04-29-2020, 08:11 PM
PAUL K's Avatar
They look like the 1050 boosters also. Should be a good carburetor for you. Save all the old gaskets and make sure they match up with the new ones.... Dominator are a pretty simple carb to rebuild.
Go fast, see Elvis!
Old 04-29-2020, 08:12 PM
PAUL K's Avatar
Yes! Also proud of their high rpm small blocks.
Go fast, see Elvis!
Old 04-30-2020, 07:59 AM
BDHABT's Avatar
BDHABT BDHABT is offline
Send it to Shaker455 on this forum.He`s one of the best.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
Old 04-30-2020, 09:10 AM
Agree, Jeff has modded a bunch of the dominator style carbs over the years.
Old 04-30-2020, 10:23 AM
Scott Stoneburg's Avatar
I will also say that Jeff did a great job on my 1050. Converted it from 3 circuit to 2. If you decide not to do the work yourself he is a great resource.
Old 04-30-2020, 10:40 AM
Bill Eveland's Avatar
I got a couple metering plates from BLP to convert mine to a 2 circuit. They set everything up and drilled the angle passage for me as well. Just a matter of swapping those and that's it. was under 150 for everything.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 04-30-2020, 11:13 AM
Fastest n/a engines on the planet run a Book Carb ..
https://www.dragzine.com/news/book-r...ock-na-record/
Old 04-30-2020, 11:20 AM
Should be proud nothing better ..IMO
https://www.yellowbullet.com/threads...ators.1730914/
Old 04-30-2020, 03:14 PM
Thanks for all the builder suggestions but I think im going to tackle it myself. The carb runs pretty good on the car it just looks really nasty, so im really wondering of I should mess with it...ya know how those things go. Anyone ever use the AED rebuild kit?
https://www.summitracing.com/parts/aed-4500
Old 04-30-2020, 04:11 PM
I think a interesting dyno challenge would a carburetor one with a Pontiac. Fuel curve is different. Get one from Book, Brasswell, Cubic ect and show who is the best on a high end Pontiac test mule.
Old 04-30-2020, 07:43 PM
slowbird's Avatar
Why do you think Pontiacs have a different fuel curve?
