Closed Thread
Old 05-18-2020, 12:44 PM
GTOGEORGE's Avatar
I'll call ARP and see what they suggest for the ARP2000 studs. I was 115lb cold with the 8740.
115 lbs. with 8740.....seems like a lot I had problems with the threads on the studs and nuts. I tried to help the problem with different nuts, i use to use the standard 12 point 9/16" head ARP nut but the threads keep messing up, i would have to clean the threads on the studs all the time
7 get new nuts (I'm assuming they were stretching, at that time I couldn't find a better grade stud). So I changed to ARP 12 pointed nuts but with the larger 11/16" head for more thread engagement to help, so when I found a better stud I changed. I will have pics on the nuts later today.
GTO George
  #102
Old 05-18-2020, 02:07 PM
GTOGEORGE's Avatar
The 2 nuts I’m using (on the right) on my head studs and the old 8740 nut!
GTO George
  #103
Old 05-20-2020, 03:33 PM
GTOGEORGE's Avatar
Well I’m still waiting on my head gaskets I decided to rewire the front (engine compartment) of the car.......I hate it! I’m just not that type of guy but since I’m adding my fuel level sender gauge I figured it was time well spent!
GTO George
  #104
Old 05-31-2020, 06:33 PM
GTOGEORGE's Avatar
Well I got my engine in Friday but still no head gasket, they are coming Monday. Before I bolted up convertor to flywheel I had to grind the heads of the (3) - 1/2” grade 9 bolts.....pain in the butt. Clearance between engine diaper and flywheel is almost non-existent, so I need to thin the head of the bolts down.
GTO George
ID:	541479   Click image for larger version
  #105
Old 05-31-2020, 10:07 PM
73 TRANSAM 73 TRANSAM is offline
Who made that timing cover? Thanks George.
  #106
Old 05-31-2020, 10:28 PM
GTOGEORGE's Avatar
KRE........it use a sb Chevy water pump.
GTO George
  #107
Old 05-31-2020, 11:17 PM
Stan Weiss's Avatar
GTO George
How much do you torque those bolts to?
Stan
Pontiac Pump Gas List
  #108
Old 06-01-2020, 12:00 AM
GTOGEORGE's Avatar
Stan
That’s a good question! I normally just hit them with my cordless 1/2” impact with blue loctite. I tried looking for the torque numbers for them but couldn’t find it, so I just did the above again. I’ve never had a problem, just wanted to torque them this time.
GTO George
  #109
Old 06-01-2020, 12:07 AM
GTOGEORGE's Avatar
Grade 9 bolts are good for 180,000 tensile strength same as standard ARP 8740 bolts.
GTO George
  #110
Old 06-02-2020, 07:35 AM
taff2's Avatar
taff2 taff2 is offline
Usual torque is about 35-40 lb ft.
  #111
Old 06-02-2020, 10:40 AM
GTOGEORGE's Avatar
Wouldn’t it matter what size the bolts are?
GTO George
  #112
Old 06-02-2020, 11:48 AM
Stan Weiss's Avatar
I show that for a grade 2 (1/2") and around 90 for a grade 8 (1/2"). Chart doesn't have grade 9
Stan
  #113
Old 06-02-2020, 12:57 PM
GTOGEORGE's Avatar
GTO George
Stan Grade 9 is the same as a ARP 8740 bolt......tensil strength.
Actually i think mine would be torque to about 80 lbs. with my impact and 6" extension.
GTO George
  #114
Old 06-02-2020, 01:05 PM
GTOGEORGE's Avatar
I sent my carbs to APD to get redone so they can flow more fuel, I'm getting them back tomorrow. I also just ordered new jets for them 218 & 226.....talk about BIG! I have 212 jets in the carbs now.
GTO George
  #115
Old 06-02-2020, 02:13 PM
twooldgoats's Avatar
twooldgoats twooldgoats is offline
Stan
I use grade 8 and 90 sounds about right. FWIW, I would be a little concerned about grinding the heads of the bolts, George.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft)
7.75 @ 178 pass:
https://www.youtube.com/watch?v=Iez3...ature=youtu.be
First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be
Thanks to Paul Carter @ Koerner Racing Engines
  #116
Old 06-02-2020, 02:41 PM
GTOGEORGE's Avatar
Jim
I’ve been using them this way for at least a decade. I don’t have a choice I have no room between my flywheel and diaper. Right now I have Velcro to keep my diaper close to the oil pan, it (bolts) still rubs. It’s not great but it helps!
GTO George
  #117
Old 06-02-2020, 02:54 PM
GTOGEORGE's Avatar
Jim
If you look at a ARP flywheel bolt the heads are about or the same thickness.
GTO George
  #118
Old 06-02-2020, 03:28 PM
GTO George
It's the grinding that bothers me, not the thickness----heat, loss of strength, etc.
Jim
7.75 @ 178 pass:
  #119
Old 06-03-2020, 04:01 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I'm not getting the picture George. How could an engine diaper be near the head of a flywheel bolt?
  #120
Old 06-03-2020, 05:44 AM
taff2's Avatar
"Wouldn’t it matter what size the bolts are?"
Yes, the specs I gave are factory torque/bolt sizes
Closed Thread
