Old 06-02-2020, 02:25 PM
Gary H's Avatar
Gary H Gary H is offline
Default Bell housing dowel Pin puller
I have been looking for a bell housing dowel pin puller and haven't had any luck. I find plenty of pullers, but they don't go up past 1/2". GM dowel pins are 5/8". Does anyone know of a source? I need to install some offset pins for bell housing alignment.
Old 06-02-2020, 02:50 PM
Hole open on the back side to tap them out?
Old 06-02-2020, 03:09 PM
Bill Eveland's Avatar
I drilled and tapped mine for a 3/8 bolt and used a slide hammer
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 06-02-2020, 04:18 PM
If its a blind hole - sometimes you can use a thread tap.
Just keep on turning it as it bottoms out in the hole and the dowel will thread its way up the tap, and out.
Use some PB Blaster spray ahead of time, to start with.
Its one of the ways we get old starter bushings out of bellhousings on older model VW Diesels.
They are a pressed fit into a blind hole of an aluminum casting.
Old 06-02-2020, 04:28 PM
ErikW's Avatar
ErikW ErikW is offline
Weld a bolt to it and slide hammer it out.
1964 GTO
9.76 @ 137mph
2009 G8 GT
Old 06-02-2020, 08:01 PM
Richie Hoffman's Avatar
goodson makes a puller with a 5/8 arbor
i just drill a hole down center and tap 1/4 or 5/16
use a threaded rod and a nut and a spacer that fits over pin and is longer than pin and turn nut and they pull right out
2008KRE Q16 Winner
Old 06-02-2020, 08:39 PM
i was thinking of a hollow dowel
- my fault if its not a hollow one.
Been so long since i held a Pontiac bellhousing i can't even remember what type of dowels are in them.
Some really good suggestions by these other guys.
Old 06-03-2020, 06:21 AM
cdrookie cdrookie is offline
Put a nut over it and weld it on, put some heat on it, then hit it with some WD40 or the like, it will twist right out.
Old 06-03-2020, 07:44 AM
Gary H's Avatar
Thanks guys for all the tips. I appreciate them but I really would like to buy an actual puller if possible. My machine shop has one made by Snap On that work's on 5/8" pins but it's really pricey. I'm always having to pull the pins and replace them with longer ones when we dyno engines, or I use an adapter or mid-plate. All the suggestions above to get the pins out destroys them or is fairly time consuming.
Still looking for an actual reasonably priced puller if anyone knows or has one.
Old 06-03-2020, 10:10 AM
Bnick166's Avatar
Bnick166 Bnick166 is offline
Gary,
Procure a cheap slide hammer w/ 1/2" threads. Use the attached conversion coupling nut. drill the 5/8" side out to fit over dowel. drill one (or2) sides for set screw (s). I you need a longer one, you could weld one 1/2" coupling nut to a 5/8" coupling nut. Drill 5/8 coupling nut and tap for set screw (s)...
Whallachinga….cheap dowel pin puller!
https://www.mcmaster.com/91072A333
The Following User Says Thank You to Bnick166 For This Useful Post:
Old 06-03-2020, 03:19 PM
Gary H's Avatar
Originally Posted by Bnick166 View Post
Gary,
This is a pretty cool idea! Sounds like it will work, and be usable multible times. I think I'll try it. Thanks to everyone for the responses!
Old 06-03-2020, 04:38 PM
It is a blind hole, no access from the other side (as the oil passages are on the passenger side) and the drivers side has casting material supporting the bellhousing bolt hole on that side as well as the Starter Mount ear of the block.
The dowels on the 3 blocks I looked at all had a very short exposed length before the taper so getting a gripping tool on the dowel would be very difficult.
Drilling/Tapping the dowels is the only choice. I personally would prefer to use a drilled and tapped dowel and then a circular ring larger than the dowel to allow the dowel to be pulled from the block using a washer, bolt and breaker bar/socket.
Too many chances to break the block using the bottom of the dowel hole as the "force point" to force the dowel from the block bore.
Richie H. has the right method.
Old 06-03-2020, 08:34 PM
Gary H's Avatar
No Tom, you're wrong. You CAN use a puller to pull the pins. My machine shop has one made by Snap On that will work on the GM 5/8" pins. When we dyno engines at his shop he uses it to replace the stock pins with the longer ones. Works great! I just don't want to spend Snap On type money to buy a puller that I only use 2 -3 times a year
The Following User Says Thank You to Gary H For This Useful Post:
Old 06-03-2020, 10:13 PM
Just post up the number of Pontiac Engines, not chevy, ford, etc that he has used this puller on in the last 6 months.
Not saying that the snap on puller will not pull the dowel pins on GM engines.
So how many Pontiac engines has he dynoed in the last 6 months.
Then you can say I am wrong. One or two isn't a representative size as the dowels may have already been removed at least once prior to your dyno session.
Old 06-04-2020, 06:11 AM
taff2's Avatar
taff2 taff2 is offline
I usually use a length of 1/4" steel strap with a hole drilled into it and MIG weld it over the dowel, the heat from the welding makes it easy to just twist and pry the dowel out.
Old 06-04-2020, 07:50 AM
Gary H's Avatar
Good grief, I've had 10 or more Pontiac engines dyno'd or needed mid plates or adapters installed that we've pulled the pins for. It's not even debatable.......but you will.
Old 06-04-2020, 08:19 AM
Happy for you, good day
Old 06-04-2020, 04:28 PM
Dragncar Dragncar is offline
Question, installing a .100 mid plate. Can I leave the stock dowel pins as is ?
Old 06-04-2020, 05:11 PM
firechicken's Avatar
firechicken firechicken is offline
I would say maybe...when I went to a Lakewood scatter shield with a .125 block plate I had to change to longer dowels but it was close.
Old 06-04-2020, 05:34 PM
Gary H's Avatar
I agree, I just installed a .100 adapter plate for a Pontiac to 700 R-4 conversion and I decided to go ahead and put the longer dowels in. It's a customers car and I'd rather be safe than sorry with it.
