Anyway, I set the one piece(uncut) in the block and then the rear main. It was up a good 1/32 off the block. So, I could sand the side of the seal that goes in the cap ? The Best seal is pretty cheap, 20$ |
I've used the rope seal that comes with the FelPro kits great results. It just takes time to do it 'right'. Neoprene seals, polish the crank. Since it's not an issue with any clearance per-se, you can use a piece of strip sandpaper to work it. .
![]() From what I've seen in my experience, the factory cranks are the ones with the serrations, and I've had to polish those down for the conventional seals. The aftermarket cranks, least the one dad is running, doesn't have any serrations in it and it's perfect for this type of thing. Last edited by Formulajones; 06-22-2020 at 11:28 AM. |
Yeah i had to raise mine alot when i got to port matching... The way Wade told me was look at each half of the seal like it was a clock. So with the block upside down the block side would be the bottom half and the cap would be the top half. The block side would be 3 4 5 6 7 8 9. So to sand it you will sand mostly at 6 - 5 and 7 O'clock.Then from there you will taper the rest of the sanding past 8 an 9 and 3 an 4 . This sounds more confusing then it is. Haha.. If i was you i would call Wade and he will walk you through it . He is a real nice guy ...
My Half AN Injun..... |
For me it was the opposite, the OE cranks are fine with the rope seals, only with the neoprene seals the hash marks required attention, or at least checked.
Depending on the brand aftermarket crank, where the hash marks are more pronounced, require attention, with neoprene seals, but I can't say for rope seals, because I personally have not tried a rope on an aftermarket crank. I think Eagle cranks have serrations, and Ohio ones don't, but don't quote me on that. .
I am confusing myself......... I will call Wade. BTW, I expect this engine to run very strong. The ring seal should be excellent. Dan cured the block fill with a tq plate torqued down for months each side with the same 1016 head gasket I will use. Its the last engine Dan ever did, RIP my friend. Our friend in R.I. is helping pick out the cam. Sending out a 1050 to get calibrated for the first time in my life for this engine. It should be a beast. Last edited by Dragncar; 06-22-2020 at 02:59 PM. |
Those seals are designed to work on a smooth surface, as seen in other applications like axle seals, timing cover seals etc..... Doesn't take a lot of thought to figure out those serrations might not be a good idea when switching to a conventional seal. But some people feel otherwise. Dad's is an Ohio Crank. It's a smooth surface. I have pictures of the crank but nothing that shows the seal area at the moment. Going to do the rear main in it soon. Going with the 2 piece BOP as that's what I've always used with excellent results. Not pulling the crank out of this one. Oddly Bischoff had trouble with this rear main when building the engine, and the BOP seal was replaced 3 times while on the dyno. Within a couple pulls it would leak horribly (another reason everyone should dyno their engines) Turned out the MR1 block didn't have venting back there and oil was trapped in that area. Tony relieved the block and cap around the seal and the rest of the dyno pulls went leak free. Been a few years now and it's leaking again. Don't know what his install procedures are so I'll be curious to see what I find when I pull it apart. I've got my suspicions. |
Thats a good idea . The rings are everything. I did mine different this time around and im very happy .. Yes our friend knows his cams. Good choice for determining that . Im sure that you will be more then happy...
Sorry, carry on...
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 Catalina Safari Wagon. Last edited by lust4speed; 06-22-2020 at 04:14 PM. |
Just trying to answer a question the best i can..
Actually, I have done a few seals with the engine in the car, on a lift, in cases where the oil pan can be removed and no need to drop the crank.
That's how flat rate mechanics did it all the time back in the day. |
Am I “missrembering”, I thought there was a service manual procedure for replacement in chassis. Using that Chinese finger trap type tool. I’m old so I’m probably wrong.
![]() Sent from my iPhone using Tapatalk Pro |
REAR MAIN OIL SEAL (REMOVE AND REPLACE)
1) Remove the Oil Pan 2) Remove the Oil Pump and Windage Baffle 3) Remove the Rear Main Bearing Cap 4) Using the Rear Mail Bearing Oil Seal BRASS Tool remove the original oil seal located in the block 5) Install the new rear main oil seal by first cutting one rope seal into two sections. 6) Insert one portion of the seal into the seal cavity of the block until 1 inch of seal is remaining. 7) Repeat step 6 on the opposite side of the crankshaft in that portion of the block cavity. 8) when you have firmly seated the rope seal around the crankshaft in the block (the rope seals should be 3/8 inches lower that the block surface. Proceed to step 9 9) Using tool J7588 install the second rope seal in the rear main bearing cap. 10) Remove the seal from the rear main cap and cut 4 pieces 3/8" long in that rope seal. 11) Work two of the 3/8" seal pieces into the rope seal cavities in the block 12) Work the remaining two 3/8" pieces into the cavities (around THE CRANK and compress those seals to where they are flush with the parting line of the block. NO SEAL MATERIAL SHOULD BE ON THE SURFACE OF THE BLOCK 13) Repeat the steps for the main cap using tool J-7588 14) Once all 4 sections of the seal material is located properly tighten the main cap to 120 +/- 10 lbs ft. This is the procedure that was given to me by the World War II Mechanic who was Head mechanic at my uncle's Pontiac Dealership. It somewhat resembles the basic Shop Manual instructions but is hand written and it more detail. Tom V. ps One of our PY members (Suntuned) and his dad made me a very nice J-7588 tool years and years ago.
| The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
During my last build, I tried one of the 1-piece double lip seals because it seemed like they just had to be "the answer". I followed meticulously the instructions from BOP, even the ones I got on a phone call with regard to measuring the "crush" (difference between crank diameter and seal inner diameter, sanding the outside to get the difference in spec, making sure that there wasn't any 'pucker' at the cut). I put it all together using my hoist to lower the crank into the block so I could make sure it all stayed lined up correctly, filled it with 2 gallons of oil and hung it butt down from my hoist for a week to make sure it was leak-free. It was.
In the car and running, it leaked. Several weeks ago I pulled it again to do some other work, and this is what I found. Yes, I filled the space between the seal lips with high quality grease. Eagle forged crank, with serrations - I didn't have it polished because I was advised "it would be ok" - and it didn't feel rough to the touch. I run main studs instead of bolts so the block was align honed for that. This time, I'll be using the graphite rope. |
Jeff |
Good luck..
#38
I've seen it. You'll have better luck with a rope seal as long as you keep those serrations. They are there to lubricate the rope seals and keep them from drying out.
If you want to go back to a more conventional seal, those serrations will have to be polished down. |
#39
i like my old cars to have a few leaks, that is how i know they haven’t run dry!
#40
That's how we mark territory
