Old 06-22-2020, 08:00 AM
...U-Pull-It stock seems best. Have not bought a T-Stat since 1981.
The Steel Band Hose Clamps are Superior versus the Stainless Ideal Screw-TQ design. 95 Lincoln Clamps fit the PMD Rad Hoses ( pretty sure).
Old 06-22-2020, 11:09 AM
i82much's Avatar
i82much i82much is offline
I like the Summit thermostats. I know, I know ... but I've had good luck with them.
Old 06-22-2020, 11:22 AM
I go with what I can find locally in the temp I'm looking for. Haven't used Stant in a long time due to no where to be found locally and their temp choices got very limited on the older cars.
Most often then not I get a premium from Napa and can vary the temps from 160-170-180 etc... on most applications.
https://youtu.be/XqEydRRRwqE
Old 06-22-2020, 12:26 PM
It would be interesting to note at what temperature they actually function at.
Many related videos on the subject of testing them.
Old information here:
Old 06-22-2020, 01:06 PM
Default Stant Superstat is our 1st choice. NAPA is 2nd.
Part number 45356 for 160* and 45358 for 180*.
We normally buy them ten at a time from Rockauto. With shipping, sales tax and 5% discount they are just under $4 each.
We also drill two 1/8" holes in them to bleed out any trapped air.
The Following User Says Thank You to Joe's Garage For This Useful Post:
Old 06-22-2020, 02:25 PM
Dragncar Dragncar is offline
Years ago when I first did the old 455 Dan W. told me to test my thermostat in a pan on the stove with a thermometer because they can vary. I did, started opening at 160 deg like it was supposed to. Drilled a hole in it and it has been in use ever since.
Do they ever wear out ? Maybe the spring gives up over time.
Old 06-22-2020, 02:43 PM
I did that years ago with a handful of stats I was playing with.
I found more times than not, they start to just crack open about 3-4 degrees before their rated temp and they weren't fully open until about 5 degrees above their rated temp on average.
I did this because on a cool day with an accurate gauge I was wondering why the car would run 155 degrees with a 160 stat. Found out that the stat just barely cracking open was circulating enough coolant to hold the temp just below 160. As ambient temps went up (usually above 80 degrees) The engine would run 170-175 and stay there, and by then the stat is fully open. It really depended on ambient temp and how efficient the rest of the cooling system was in a particular car as to where the temp would settle in.
I further verified what I found on the stove top when testing a 170 stat on an LS engine. Using the laptop computer, I could watch and log what was happening and was almost identical to the "hot water in a pot" test.
Old 06-22-2020, 02:47 PM
I do the water on the stove routine, just like Mr Dan W told you, except I have a digital Steak Temperature Checker that is right in my kitchen and I can plot the temp curve easily as the water is calm as that opening temp is below the boiling temperature.
Stant Thermostats seem very consistent when I have checked them for friends, and I
need to check one for my 455 E-Head build in process.
Old 06-22-2020, 07:29 PM
Formulabruce's Avatar
I run Delco 170 degree Thermostats in all old Pontiacs now.
Old 06-23-2020, 03:10 PM
Pontiac Performance Author
Thanks to all !
