As I said,those are rod bearings!I can't find narrow mains.Tom
Reminds me of the guy at the swap meet selling secret oil sauce. He had an old I-6 running without the oil pan. Onlookers were amazed
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
I shouted out to the vendor once, who was giving a demonstration with a microphone hanging around his neck plugged into a small amplifier. "What are the spark plugs gapped to?!" The look on that guys face LOL.
Buick made a 2 lb. oil pressure switch because they had too many warranty complaints about the V6s flickering oil pressure light at 5 lbs. An engine at idle doesn't need much oil pressure to keep running.
According to the universal yardstick of 10 lbs. per 1000 RPM, at 700 RPM 7 lbs is sufficient, but buick wrote their own rules that 2 lbs is sufficient. A guy I went to HS with had an old 57 235 CI chevy 6 that they laid a brick on the gas pedal for 1/2 hour and it just sat there and screamed. They first drained the radiator, still running, drained the oil, still running, so they started dropping rocks down the carb, and it finally blew up. Another 235 chevy in a tow truck, threw a rod towing his race car to our Vo Tech to work on it during class. Windowed the block, rod bolts sheared off. He reached through the hole in the block and shoved the piston, and what was left of the rod all the way to the top of the cylinder so they didn't hit the crank on the drive home. The oil pressure is near zero because with the rod missing there's a huge leak in the oil system. With the race car on the back he drove it nearly 20 miles back to his house, it stayed together, but it shook like hell because of the imbalance, he said 20 MPH was as fast as he dared drive it, still towing his race car. I saw a 305 chevy that ran so long with a spin bearing in a daily driver that roughly half of the rod throw was worn away. Imagine how hard the piston was hammering the head with roughly 3/4 of an inch of the crank was worn away. Rod clearance .750, they don't make plastigage that big................LOL You never know the limits of how far you can push an engine until you run it until it won't go any further. When it quits completely, you found it's ultimate limit.
[QUOTE=Sirrotica;
You never know the limits of how far you can push an engine until you run it until it won't go any further. When it quits completely, you found it's ultimate limit. [/QUOTE]My kids 2.8 V6...He called me and said the clutch sounded "funny" ! LOL I went over, drove it to my house to pull it!
Jimmy M 68 GTO |
Speaking of 301's and the image, years ago I inherited my aunts 79 Bonneville with a 301. and about 90K on the clock. It was essentially a gift to me as it developed a knock; still drivable though and a nice coupe to boot. Car was in Southern New Jersey, me in Flemington, NJ; about 70 miles apart. Decided, the closer I get to home, the less the towing charge will be so I struck out on the road with the 301 & its knock. Actually made it within 2 miles of home before one loud knock & then she's gone. inspection showed #3 crank web completely busted out of the block followed by the crank breaking..so close to home. They took too much iron out of those engines; at least the early ones.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
Back when I was riding Harleys I went to a local meet, one of the celebrations was taking a "Jap" bike and blowing it up. It was some kind of 70's Honda. Pinned the throttle wide open and let it run ... as per stories above people got tired waiting... so they pile wood around it and set it on fire, still ran another ten minutes or so before dying (no explosions) .... long enough that many people walked away dejected at how long the Japanese "garbage" ran .... then after burning for 20 minutes .... it began trying to start ... some wire had burned through and energized the starter, the crowd got even sadder
Tom, I think if you ask the sales rep for 'H' series clevites they will be correct?
Here is a link to some on Jeg's: Main Bearings Just noticed they are for 455 size mains. May have to ask for the smaller ones. I think Butler (and others probably) have them?
At our school before they became all politically correct, every spring for ten years or more we had the "brick test". The marginal students with D- and F+ grades were given the "Option to improve their grade by 1 letter grade". They would have to line up their cars and drain the oil and coolant, start them up and put a brick on the gas pedal. Last one running got the letter grade bump. Some years we had 4-5 cars in the contest. The smart students, (among the dummies), would intentionally have extra poor running engines that would not rev too high. Their were many memorable engine epic failures. One that just wouldn't die was an iron duke 4-cyl in a Sunbird. It must have run wide open, no oil, no coolant for 20 minutes then just slowly seized up and stalled. After cooling for an hour or so, it started right back up and ran another 10 minutes before finally tossing a connecting rod. Good times!!
| The Following User Says Thank You to mgarblik For This Useful Post: | ||
Dayum
that should have been worth at least a 2 letter grade bump
The iron duke is a reworked 153 CI four cylinder chevy 4 with two cylinders removed from their straight 194 straight 6. It was used as the economy option in the early chevy II/X body platform that began in 1962. I had a disagreement with a friend of mine that they were built on the same parameters, and it was just an updated design that Pontiac massaged to update it. We drug out the parts books, and sure enough the timing gears and bearings are the same part numbers as the 153 4 cylinder, and the 194 straight 6, as the 151 iron duke. The 301 Pontiac also shared parts and dimensions with the iron duke. Just divide 301 in half and you get 150.5 displacement. Kinda like 389 divided in half equals 194.5 early on, no slant on the 151 blocks though. Midget racers used the early 153 4 cylinder, as was the iron duke 151 design adopted later on by the midget racers. It had to be a durable design to make it a favorite in the midget ranks. The midget ranks also grafted a crossflow SBC head to the 153 to improve power. Pontiac made their own crossflow head, with staggered valves to up the power of the early iron duke mid 70s. Way off topic, now, sorry to the OP ......................
A "long stroke"153 crank drops right into an early 151 Iron Duke, if you have suitable pistons to go with the stroker crank. The Iron Duke got over 200 revisions during it's production life; they changed EVERYTHING on that piece of crap trying to make an engine out of it. Same bore and stroke, I'm not aware of any interchangeable parts. |
Tom,
If the #5 bearing tangs are 20 thous off, compared to what? The saddle center? The crank main journal? An original GM 455 bearing? Or another aftermarket bearing? Thank you for helping QB this. Brent
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
I hope the OP gets his engine squared away soon... but not before another engine story. 6-7 years ago, I bought an 84 cutlass g-body "sedan" out of cincinnati, off of CL. Mint body, low miles, but "leaked oil heavily from everywhere". I bought it, towed it home, and to my surprise, he was exactly right. as soon as you started it, oil seemed to come from every gasket surface. When I wiped off the dipstick, it seemed to always show too much. I drained just shy of 4 gallons of oil out of it. It then ran like a top, but I couldnt give away that little 3.8 buick V6 and TH200C. I was doing a 350/350/3.73 swap into the car, so I thought I'd blow the damn thing up. Put a brick on the gas pedal, headed to the house for lunch. It wouldnt rev high enough to blow itself up. It did manage to run out of the old gas eventually, so i just gave up and pulled it, and sold it by the pound. I think I got $25. I was hoping for spectacular mechanical carnage and fire, but sadly got nothing too soothe my cold, heartless soul.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400 pontiac 72 4-4-2 Mondello's VO Twister II 1964 F-85 Home of the 700hp small-block Olds **Still wanting a 64 Bonneville or Catalina** |
Back to the OP.Mike got the bearings and confirmed they dont make a narrow main bearing.The H is for high performance and the X is for 1 thou more clearance.The new Clevite bearings dont have the little reliefs on the #4 bearing?Also he said it looks like the tangs for the #5 bearing are about 20 thou off moving it toward the back.The crank is out having the mains cut 10 and he will confirm when it is done and he can put it in the block.More answers promote more questions.The rep confirmed the bearings are being made in 3 diff factory's.Tom
they were std on std.The crank is now getting cut to 10 under.The issue looks like the rear bearing was sitting too far back toward the radius!If the tangs are indeed 20 thou off that could have been the issue.AGAIN!ALL other bearings were good!Mike has made it his mission to get to the bottom of it.Tom
The last coupe of sets of Clevite mains I have gotten I have had to lap with plate glass and sand paper as they were wider than other sets. The Federal Moguls measure .937 wide on 1-3 mains and 1.590 on the rear width. The Clevites were anywhere from .018 to .050 wider on a few sets I checked. Could make a big difference if there is a heavy radius.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135 66 GTO (Retired race car) 421 CID Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
