Old 09-17-2020, 05:49 PM
Tom is right. Only disassembly will show the issue here.
  #162
Old 09-17-2020, 06:01 PM
wbnapier wbnapier is offline
I've got the preliminary diagnosis from the machinist. Further tear down and diagnosis will be done tomorrow morning by the machinist and Tom S will be there to help as well. Many thanks to him.
I will refrain from comment here until the machinist is satisfied with his conclusion. Should be tomorrow.
If the prelim is confirmed, it will be a good lesson for all of us. It hasn't been touched on in this thread yet.
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
  #163
Old 09-17-2020, 06:31 PM
mgarblik mgarblik is offline
You mentioning nobody has touched on this reminded me of a "locked-up" situation I had with a student's engine about 15 years ago. It was a Buick 455 stage 1 engine and the student assembled it at home. It ran about 10 minutes and then locked-up solid. He had mistakenly installed all the main bearing shells, (1/2 grooved) with the oil hole half in the caps and the solid half in the block. We took it apart, re-line honed it, had the crankshaft re-ground, and cleaned up everything really good. Put it back together and it ran just fine.
  #164
Old 09-17-2020, 10:36 PM
Talking
You mentioning nobody has touched on this reminded me of a "locked-up" situation I had with a student's engine about 15 years ago. It was a Buick 455 stage 1 engine and the student assembled it at home. It ran about 10 minutes and then locked-up solid. He had mistakenly installed all the main bearing shells, (1/2 grooved) with the oil hole half in the caps and the solid half in the block......
Inconceivable!
  #165
Old 09-18-2020, 07:22 AM
Wow! 10 minutes of main Bearing run time on just assembly oil is a bit more then I would have thought.
  #166
Old 09-18-2020, 09:22 AM
The ten minutes was an estimate, I was not there. Could have been 6-7 minutes. It ran at steady speed breaking in the new camshaft. I guess break-in lube, no to little load, and some splash lube kept it going for a while.
  #167
Old 09-18-2020, 09:38 AM
MarkS57's Avatar
MarkS57 MarkS57 is offline
65 Tempest, 400, TH400
86 Fiero SE 2.8
The Following User Says Thank You to MarkS57 For This Useful Post:
  #168
Old 09-18-2020, 12:07 PM
GTOEARL GTOEARL is offline
Been following your post and your issues here. My heart goes out for you buddy. Waiting patiently for the results. I hope it’s not too bad. I admire your courage in putting the motor together.
  #169
Old 09-18-2020, 03:37 PM
tom s tom s is offline
Pics
ID:	549848   Click image for larger version
  #170
Old 09-18-2020, 04:02 PM
Formulas's Avatar
Formulas Formulas is offline
Is the oil groove restricted by foreign material?
Local bearing starvation?
Doesn't seem to be located in the block properly wheres the tang at cant see it on me cell phone
One thing I do on assy is after every addition to the engine assy every bearing cap every rod cap I spin it to make sure there is no large increase of torque or binding
  #171
Old 09-18-2020, 04:23 PM
tooski tooski is offline
Looks to me like a chunk missing at the red circle. Perhaps that's where the tang sits. Also the grooves on this side looks to me to be a bit shorter than the grooves on the other side; as if the saddle was bored too much to one side
Name:	Main 5A .jpg
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
  #172
Old 09-18-2020, 04:30 PM
the bearing was tight at the very rear and as it heated up the heat transferred to the front of the bearing where the very front still has coating.The autopsy has just begun as the radius on the crank really does not look wider than a stock 455 crank.As said before the owner supplied all the parts from a 3rd party and did the assm himself.Mike was a little concerned as the engine did not look like it was assm in a very clean room.So far nothing has been found that the owner did anything wrong.I think the issue has something to do with the after market crank and the Clevite bearing.I had a engine with a little copper showing at the very back edge of the rear bearing but nothing like this.Tom
  #173
Old 09-18-2020, 04:59 PM
I forgot to ask about the spark plugs!Tom
  #174
Old 09-18-2020, 05:07 PM
Why would the crank be heat blued at the oil feed grooves?
Would a foreign substance heat up if pumped into the oil grooves? Did the rod bearings show the same thing?
  #175
Old 09-18-2020, 05:37 PM
Bearing was welded to the crank,had spun.Tom
  #176
Old 09-18-2020, 05:41 PM
I will go back first of the week to see what else Mike finds.Tom
  #177
Old 09-18-2020, 06:02 PM
Pontiac Performance Author
What about my favorite, #4 ?
  #178
Old 09-18-2020, 06:09 PM
MarkS57's Avatar
I can honestly say I've never heard of a rear main spinning like that...ever; but there are others here who have seen way way more things than me. Isn't the rear main bearing the 1st in the oiling circuit? Anyway, if nothing else is found, then a new block maybe the extent of what he would need; assuming the crank could be saved with some machining? Its still in 4 digit territory but could be worse. Deep breath, think of what that few seconds of acceleration felt like and imagine getting back there...over and over.
86 Fiero SE 2.8
  #179
Old 09-18-2020, 06:10 PM
Ken,the bearing looks fine,did not take a close look at the F&R thrust side of it,will take a look next week.The only bearing that looked bad was the rear main.Tom
  #180
Old 09-18-2020, 06:13 PM
Thrust bearing
ID:	549852   Click image for larger version
