Industry Stuff new repro's, updates, other info.
Old 09-25-2019, 11:56 AM
OG68 OG68 is offline
For the 68 Lemans/GTO;
Upper radiator support rubbers for the big four row radiators,(PA/PC etc)
Part # 9790389
ID:	520892   Click image for larger version
ID:	520895   Click image for larger version
  #1662
Old 10-22-2019, 12:34 PM
dataway's Avatar
dataway dataway is offline
How about some 68 GTO hideaway actuator rod seals ... ones that work. The seals that come with the repop cans last about a year.
  #1663
Old 11-28-2019, 03:02 PM
dataway's Avatar
Correct 68 lower radiator saddles for the four core radiators. Left and Right.
  #1664
Old 12-02-2019, 12:27 PM
Gastiresandoil's Avatar
Part # 9790389
Have you tried these? I'm not sure what application the part number coincides with, but might be worth looking into. They appear to be wide enough for a 4 row radiator, but don't know if they'll fit the upper support.
https://www.amazon.com/Parts-Place-P.../dp/B00H87CRHC
  #1665
Old 12-02-2019, 04:19 PM
Thanks for responding but they do not have the necessary offset to fit right
  #1666
Old 08-27-2020, 02:08 PM
Region Warrior's Avatar
If not already brought up, a 67-72 style aluminum stock intake for q-jets.
Not factory part numbered or anything like that. Like an aftermarket replacement.
Even better if had enough material to port RAIV size...
  #1667
Old 08-27-2020, 03:12 PM
FrankieT/A's Avatar
Already exists
  #1668
Old 08-27-2020, 04:06 PM
Standard port size, or the POS RAIV repop?
  #1669
Old 08-27-2020, 04:16 PM
FrankieT/A's Avatar
POS RAIV repop,
So what you are saying is you want a better quality knock off.
  #1670
Old 08-27-2020, 05:27 PM
Originally Posted by FrankieT/A View Post
POS RAIV repop,
Good luck with that! Joe @ Parts Place did the two piece repro. Seem to have used a late '72 HO intake with it's slightly more shallow plenum floor as the sample to pattern off of. We've all seen the poor intake port alignment.
  #1671
Old 08-27-2020, 05:36 PM
Small circular rubber for the top of the rear bumper bracket.
Part # 9790141
ID:	548045   Click image for larger version
  #1672
Old 08-27-2020, 06:23 PM
POS RAIV repop,
Do a search on eBay.
There is a seller (i believe in Texas, maybe) that is doing them, and they don't have all the blunders. aka they fit / aka bolt-on.
He had several various offerings last time i checked,
its been a couple/few months
  #1673
Old 08-27-2020, 07:16 PM
FrankieT/A's Avatar
On top of that...They reproduced the one year only cast iron cross over. Right? It fits 72 and later heads. If he reproduced the 69 to 71 crossover it have fit just about all heads.
  #1674
Old 08-28-2020, 01:32 PM
POS RAIV repop,
Ya guess should of worded that way.
Aluminum repo standard port would be nice too. Back get'n to old for lifting stock intake over the fender.
Never under stood why no companies could at least make an equal flowing dual plane intake.
  #1675
Old 09-03-2020, 07:39 AM
Drop-Base Air Cleaner stamped for Holley 1050
  #1676
Old 09-03-2020, 08:18 AM
hgiv hgiv is offline
A 350 piston and a correct 350 gasket that isn't a piece of crap or cost $$$
  #1677
Old 09-23-2020, 05:14 PM
chief2k chief2k is offline
'66 Lemans taillight gaskets
  #1678
Old 09-23-2020, 05:26 PM
Default Plastic Emblem Nut
The tan plastic emblem nut for the '66 LeMans quarter letters (24 per car) They look just like J101L in your catalog, but are smaller to fit the letter's studs
  #1679
Old 09-24-2020, 08:01 PM
JUDGE3 JUDGE3 is offline
Default 15" cast honeycombs
15" cast honeycombs like the oversized ones. please! would be the only wheel that would make me not go cragar ss. originals are to heavy, oversized ones to big!
The Following User Says Thank You to JUDGE3 For This Useful Post:
  #1680
Old 09-24-2020, 09:36 PM
I agree with all that.
Would be in for a set of them too ! (15")
