Old 10-19-2020, 05:39 AM
dataway's Avatar
dataway dataway is offline
Default 2K clear coat overspray on windshield
What would be the best method/solvent etc. for removing 2k clearcoat overspray from a windshield.
Thanks.
Old 10-19-2020, 08:54 AM
73 TRANSAM 73 TRANSAM is offline
I would use lacquer paint thinner. This is what u use to clean your spray gun.
Old 10-19-2020, 11:11 AM
Tim66 Tim66 is offline
Send a message via ICQ to Tim66
Default overspray
You can use a razor blade first,and then go over it with the thinners.
Old 10-19-2020, 12:19 PM
ZeGermanHam's Avatar
I'd probably take the approach of using lacquer thinner first to see how much will come off without a razor, then remove the more stubborn stuff with a razor, then do a final cleanup with another pass of lacquer thinner.
1998 BMW 328is (track rat)
Old 10-19-2020, 12:23 PM
dataway's Avatar
Thanks guys.
Old 10-19-2020, 12:42 PM
400 4spd.'s Avatar
NEW razor blade! After you try it dry, spray some glass cleaner on it and try it that way. Let me know which you prefer.
Old 10-19-2020, 02:12 PM
dataway's Avatar
Luckily I have a pack of 100 new blades. Would imagine it would work better with the glass cleaner as lube ... raining right now, so it may be a day or so.
Old 10-20-2020, 08:17 AM
Razor on face or razor on glass...I'm thinking either way some lube is a good thing!
Old 10-20-2020, 08:55 AM
62cat's Avatar
62cat 62cat is offline
000 steel wool. I use it on glass and brightwork.
Old 10-24-2020, 06:21 AM
RedDirtRoad RedDirtRoad is offline
I prefer a Clay bar if it’s new glass
Old 10-25-2020, 05:47 PM
gary bennett's Avatar
gary bennett gary bennett is offline
I use 0000 steel wool with lacquer thinner.
DBANDGB
Old 11-12-2020, 09:19 PM
killakev's Avatar
killakev killakev is offline
Where do you get this type of steel wool?
Old 11-12-2020, 09:28 PM
Any hardware store, Home Depot, Lowes, etc.
Old 11-13-2020, 12:39 AM
dataway's Avatar
I ended up using the razor blade method, worked great. This over spray was so light you couldn't see it except when the sun hit it at an angle, or at night. If I dragged the blade backwards you could hear a popping noise as it skipped over the dots of overspray .. then scrape forward in the area until the sound goes away.
In the past I've used the super fine steel wool also.
