Old 11-04-2020, 11:17 AM
The Champ's Avatar
The Champ The Champ is online now
Originally Posted by 64speed View Post
The only thing on my car that are Chinese knock offs are the front control arms which Summit now sells. I have all top grade **** everywhere else.
Your own post from June 2017 contradicts this:
US wheel
Anybody ever use this brand? I just bought a set of torque thrust knockoffs on summit for 121 dollars a wheel. That's a lot better than the 600 bucks I was being quoted for custom back spacing American Racing wheels. I went with an 1&x8 with 235/45/18 all around on an 18x8 rim.
So, you went with Torque Thrust knockoffs with less then optimal BS instead of AR Torque Thrusts with the correct BS.
Per your own words above, you bought 235/45/18's, yet now you claim they are 255/45/18's. When you purchased the 235's - you told us that was the biggest tire that Tire Rack said would fit with your knockoff rims with the wrong BS.
Why did you need to have Black's Tire measure tires that you already purchased from Tire Rack to see if they would fit? If Mr. Black is such a wonderful person, why didn't you buy your tires from him?
I said I never do personal attacks...
You need to look back at your own posts. You make personal attacks all the time - even on this thread.
Many people have tried to help you, but you refuse to take their advice if it isn't what you want to hear.
  #62
Old 11-04-2020, 01:10 PM
Suggestion:
The issue is you make 27 posts in 8 threads that are related to the same subject.
Concentrate on one subject until you have received an answer you can live with.
Then move to the next step in the process with a new different thread.
Except for getting your post count up, all of those duplicate posts (related to the same subject) just confuse you and the people trying to help you.
At some point people get frustrated with this behavior, then they point out your obvious contradictory posts on the same subject. That is because you can't remember what you posted in the past 27 posts for that day.
Your problem is not that you are stupid or retarded, your problem is that you are completely disorganized and when stuff goes wrong then you bad mouth the vendors and the people who tried to help you. Obviously everything that goes wrong, does not fit, etc, is someone's fault (but never your fault).
All of above is the truth. When you ask to close a thread like this one because you don't like people pointing out YOUR mistakes, you just wasted everyone's time AGAIN.
  #63
Old 11-04-2020, 01:15 PM
NeighborsComplaint's Avatar
really? hey you racist half wit, you are not in the clubhouse.
Nice. Someone needs a timeout if the mods have any balls.
https://blackstire.com/
Triple Black 1971 GTO
  #64
Old 11-04-2020, 01:45 PM
64speed's Avatar
64speed 64speed is offline
As soon as I get home I’ll get out my invoice for Blacks and post you a pic. The 18x8 I initially bought were from US Mags and they were indeed cheap. The lip on one of them had a chunk out of it where a tire had obviously been mounted then taken off. That was a lesson learned about buying wheels offbrand. Thank god for American Express but I digress cause that’s another story about summit. 235 was all Tire Rack would sell me because that was all they would guarantee with a wheel tire package.
I dont like going to Blacks because they are high, period. I just had a TPS sensor installed there and he charged me to install it and program it in a separate charge but.....he has the thing from Eastwood that you bolt to the studs and stick the tire on. I sucked it up and took the raping in the name of expediency as I needed rolling stock. 99% of the time I buy tires from Tirerack, take the wheels off the car, take them to the tire shop and have them mounted and bring them home. In this case I didn’t do that.
  #65
Old 11-04-2020, 01:55 PM
64speed's Avatar
Suggestion:
I own my mistakes Tom and I take all advice that is inline with my vision for the car. When I first started talking about suspension/braking/wheels I of course got all kinds of advice. I don’t take the advice that calls for Z06 brakes and a 2000 wheel just like I don’t take the advice that a nearly 600 hp engine will be fine with stock brakes. People get agitated when you don’t take THEIR advice. It’s only wrong or a mistake if it’s not their vision. I wanted the thread closed because it started to devolve into being called a racist by people who think I don’t have better sense than to use the the term “blacks” disparagingly in a post.
  #66
Old 11-04-2020, 01:58 PM
64speed's Avatar
All I wanted out of this was real world input on the best box not the best bang for your buck box, the best box period. I got it from good people who had experience and I now have the Borgeson. Case closed
  #67
Old 11-04-2020, 03:02 PM
242177P's Avatar
242177P 242177P is offline
That's NOT the shop he used!!!
According to 'speed, this makes you... *checking my notes* ...an ignorant know-it-all prick.
Welcome to the club?
Oh, and Scarebird and Tomslemans67 were absolutely right to call out a potentially racist
comment. "This is what Blacks put on"... can easily be construed as racist. On the other
hand, "This is what Black's put on" wouldn't be. Neither of them deserve a timeout. But
telling moderators how to do their jobs can earn you one. Careful what you wish for...
  #68
Old 11-04-2020, 03:31 PM
Yeah, call a guy a racist halfwit without knowing the facts .and you stick up for that BS There must be more dimwits here than I thought. I never once took that comment as racist, especially since he capitalized "Blacks" making it a Proper Noun as in the name of the shop. Yes I googled another "Blacks Tire Shop" but my point was made and anyone with 6th grade education should know the difference between a Proper Noun and a noun. Here, I'll make it easy for you, Proper Nouns are capitalized.
  #69
Old 11-04-2020, 03:39 PM
64speed's Avatar
This is ridiculous
  #70
Old 11-04-2020, 03:58 PM
242177P's Avatar
... but my point was made and anyone with 6th grade education should know the difference between a Proper Noun and a noun. Here, I'll make it easy for you, Proper Nouns are capitalized.
LOL. Welcome to 2020. The Associated Press and other news organizations went on record
about capitalizing Black like back in June or July. You clearly haven't been keeping up with
current events...
  #71
Old 11-04-2020, 06:29 PM
The Champ's Avatar
The 18x8 I initially bought were from US Mags and they were indeed cheap..
Thanks for proving to everyone that I did know what I was talking about.
This is the second set of rims and tires you've bought for this car.
I dont like going to Blacks because they are high, period. I just had a TPS sensor installed there and he charged me to install it and program it in a separate charge but.....he has the thing from Eastwood that you bolt to the studs and stick the tire on. I sucked it up and took the raping...
Funny, earlier in this thread, you posted the following in reference to Black's:
I have never been screwed by them.
Once again, your own words, in the same thread, contradicting yourself.
  #72
Old 11-04-2020, 06:50 PM
64speed's Avatar
They don’t screw me they are just high. They don’t have a personal vendetta, they gouge everyone. This is a tiny town and they have nobody to compete with. Man seriously you’re right, the car doesn’t even exist. I’ve been making it up for years. Will you let it go now?
  #73
Old 11-04-2020, 07:53 PM
current events...
Did he say "the Blacks"? He said "Blacks", a proper noun and name of an individual and a business of the same name. Had he used the article "the" before blacks, the article signals the word is a noun. It was not used so 'Blacks" is a proper noun, the name of a person, place or organization. As there is no organization with the name "Blacks", you are wrong.
You do not understand the English language at all and thanks so much for your lesson in political correctness, but Miriam Webster trumps political correctness and being trendy. Also, note the lower case "t" in trumps. It is a vowel, not a noun in this usage and has no political connotation.
Scarebird was way off base. I thought personal attacks were not allowed on this board.
  #74
Old 11-04-2020, 08:32 PM
64speed's Avatar
Hello everyone let’s do this. My name is David and I have a 64 Tempest that I hope to have fully restored one day. I want it to be a really nice car so I have amassed a truckload of high end parts I have a Ford 9 inch rear with an aluminum thru bolt center section and 31 spline moser axles. The rear has Ford Explorer disc brakes. I had a 468 built using an all forged rotating assembly and topped it off by a custom roller cam and Edelbrock round port heads ported to 315 CFM by Butler. I have a Torker II intake. I am running the Holley sniper fuel injection setup with hyper spark distributor and MSD 6al box for timing control. I bought the extreme TKO600 transmission kit from American Powertrain. I have had every piece of brightwork on the car chromed at S&H plating in Madison Tennessee. I have a Borgeson steering box and UMI sway bar and frame brace on the front. I am running hotchkis springs on the front lowered 1 inch. I am using Wilwood brakes on the front. I have full UMI suspension in the rear with and aluminum driveshaft hooking it all up. I am converting it to hydroboost. I have a pipes x pipe 3 inch exhaust kit with black widow venom 250 mufflers. I have power windows from Nu Relics. I have wheels that resemble torq thrusts but have a smooth magnesium center in 18x8 on all four corners. They may rub when the car is back on the road they may scrub but we will see. I am sure I left some things like the Bluetooth converted factory radio but I think you get the gist. Now that we have started off on a better foot and you know a little about my car maybe you can help me pick a color or even suggest some other upgrades without me having to ask. I really need help with paint color. Interior is black.
  #75
Old 11-04-2020, 08:47 PM
tom s tom s is offline
Again!Why not ask the wife as she we'll have to look at it and if it's not right you will be getting a repainted!Tom
  #76
Old 11-04-2020, 08:55 PM
Tomslemans67 Tomslemans67 is offline
I just don’t get it! Pick the color you and the wife wants. Hell with everyone else. You are just going to get mixed opinions. Do what you want to do. Damn! I glad I can make up my own mind instead of having people influence me! And I regrets it
  #77
Old 11-04-2020, 10:08 PM
64speed's Avatar
I will make up my mind when I have seen some examples. I’m not just gonna say red for example and drop it off. I want to see people’s red cars. Does it look good? Is it a factory color? Does it have metal flake in it? I saw a copper color someone sent me today. I would have NEVER thought of copper but now it’s on the list. Nothing wrong with getting ideas. I will pick the color ultimately but I want to see some examples besides google images. Nobody is gonna make up my mind
  #78
Old 11-04-2020, 10:16 PM
Unless your getting a regular non metallic color it will be very hard to tell what it will look like.Metallic almost HAS to be seen in sunlight.Tom
  #79
Old 11-04-2020, 10:33 PM
242177P's Avatar
... As there is no organization with the name "Blacks", you are wrong.
You do not understand the English language at all ...
A little reading comprehension goes a long way. "The Associated Press and other news organizations".
News organizations. Clearly I wasn't talking about an organization named Blacks.
... and thanks so much for your lesson in political correctness, but Miriam Webster trumps political correctness and being trendy.
Right... That's why Merriam-Webster literally changed the definition of "racism" in June, and "sexual
preference" in October.
Not when it's viewed it IN CONTEXT. And he has since apologized. Seems that neither of us has much
say in the matter, but it really looks like you're calling for retribution. Either you're opposed to calling
out racism (not a good look), OR you have some personal beef with him? There were two people that
reacted in the same manner, and you continue to single him out. Why?
For the record, Scarebird and I don't see eye to eye when it comes to politics, and I'm defending his
decision. It was the right thing to do (even if it was technically wrong).
  #80
Old 11-04-2020, 10:41 PM
242177P's Avatar
What he said. Even in person, Mazda's "Soul Red" has an amazing range. It's like moving two feet in
any direction makes a dramatic change. And I'm not even a fan of red, LOL. Weather and shadows
also play a role, if the shady side leaves a "meh" impression...
