Old 01-19-2021, 07:52 PM
JD's Avatar
JD JD is offline
Originally Posted by gogtogo View Post
Thank you for input. I’m currently using the Hi-Tack. Car is 3220lbs and I’m 210 so 3430lbs race wt. 748hp & 633ft. lbs. with a TH-400 w/ no break.
The track I was on was terrible at best and I’m worried about a real track like Norwalk. The last thing I wanna do is add more rotating wt. and drop $2,600 + on wheels.
In your first post you said you think the tires moved an inch on the rim with no transbrake and Hi-Tack? That seems a little strange. You are running 18 psi?
Jim
71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas
