************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude |
Posted for interest..........
"Wheels: How big is too big? The general rule is to only use as big a wheel as you need to clear brakes and suspension components. The weight of an average car for road racing usually requires brakes that are too big to fit inside 15-inch wheels, so larger ones are used. So the question becomes what is the best size wheel to use ? It's natural for us to think that bigger is better, and it's true that the general public prefers the look of larger wheels, but don't let that trick you. Oversized wheels will slow you down. It all comes down to moment of inertia. The excess weight of a larger wheel is an important issue, but the diameter of it is a much more important factor. The effect of a 10-pound weight at the end of a 12-inch string is much less than a 10-pound weight at the end of a 36-inch string. The larger-diameter wheels are not only heavier, but are much harder to control the rate of rotation like the weight at the end of the string. Now let's look at overall tire diameter and the effects of sidewall flex. Let's say you've decided on a tire diameter and are looking at what combination of wheel diameter and sidewall height to run. The taller the sidewall, the more flex it can have. This is a good and a bad thing, but mostly a bad thing. When the sidewall id tall, it can deflect quite a bit, throwing away any sense of your suspension alignment settings. Too short of a sidewall a sidewall can be oversensitive to surface conditions, and gives you far less warning before traction is lost. The trick is to find the right balance. The sweet spot for most of our muscle cars and track cars is 17- or 18-inch wheels. this isn't just our opinion, but that of many industry insiders. The 12- or 13-inch rotors usually chosen by the road racing crowd fit in these wheels just fine, and don't need the additional clearance given by a 19-inch or larger wheel. Consistent with that, BFGoodrich doesn't even make their sticky road race R1 tires for any wheel larger than 18 inches in diameter. So why does NASCAR still use 15-inch wheels ? The rules mandate these 15-inch wheels and have for many years; knowledgeable fans speculate that this rule won't change. It can be argued, however, that oval track cars use this tall sidewall as a part of their tunable suspension. Since their quickness is defined by how they can plant power out of the turns, tire pressure can be used to improve that. That brings us to ask why new Corvettes and Vipers use such large wheels. The simple answer to that is because they look cool. There is no advantage to these larger wheels except their looks. The laws of physics would suggest that using a smaller wheel while still clearing the brakes would make the car faster. .
The Following User Says Thank You to Steve C. For This Useful Post: | ||
I ran 275/50/15's many many years ago in a BFG drag radial. Late 80's??
They worked okay from what I remember, but back then I was using them on mild HP applications. As HP increased over the years I found myself going to the taller 275/60's drag radials as I had much better luck getting them to work at the track, plus it fit quite a few of the radial racing classes they had at the time. The taller side wall allowed some flex, the radials do wrinkle quite a bit, which helped absorb the shock a bit, and traction. I still do have a couple cars here, with less power, that simply don't like the taller tires. They just don't have enough rear gear in them for starters, and a 28" tire just hurts it at the track. My bird is a prime example. Not enough HP and not enough rear gear. Too long to explain here but I've been round and round with that car. I'm going to buy some 26 inch tires to run on a couple other cars here simply just to help them out with gearing and they will find their way on the bird for some track time. Going from your 27" tire down to a 26" at the track, you'll probably see a 200-300 rpm difference through the traps. |
I think the 255/60/15 M/T is the best choice for the OP needs and wants. The only time a bigger tire may be wanted or needed would be if he raced at a much lower DA..but even then many are running this tire at low ets and 60fts.
I believe you are likely correct!
I would run whichever tire looks better. Either of those tires can be made to work. I've run both tires into the nines at close to 140mph.The shorter tire should be slightly faster at the track and the taller tire might be slightly faster from a dead stop on the street. I didn't care at all for the looks of the taller tire on my 80 TA so I went with the 255's.
The Following User Says Thank You to PAUL K For This Useful Post: | ||
Hey Dan, since the tire sits up in the wheel well I don't think it makes it look too big and as we talked about when I looked into this previously I found I got better traction with the taller tire. If you want I'm open to have you try mine on your car before you invest money.
Here's a pic of Dave (torqhead) and I racing at Bandimere. The tire sizes are well depicted here. I think Dave runs a 225 front tire and a 275/60 rear so the difference is more obvious. I've had alot of guys tell me they dont think I run enough gear. I think the trap RPM's are 5000'ish. This was another reason I was considering the 275/50's.. I'm not convinced that I "need" them yet, however.... I really wish I could try a set without having to drop a grand to do it.
************************************* 1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude Last edited by 68lemans462; 03-30-2021 at 02:45 PM. |
The Following User Says Thank You to 68lemans462 For This Useful Post: | ||
Totally do the 275-60 MT not the 50 , you got a 3.42 with a 455 more than enough gear for that tire. I went from 255 60 MT SS DRs to 275 60 MT SS DRs on my 7.4/ 11 sec CAT and it was a more consistent launch with 1.6 60 fts , 10" stall and 3.64 gear 3750# . I was swapping my Cat 5x5 15x8 Chev rallys to our LWB 74 C10 454 to run it at track and if track prep was very good it would hook good but have since went to a permanent 295 55 MT SS DR's combo on the old 15x8.5 slots on the C10 and that Long bed is a real bracket winner these days very consistent, truck runs 8.3's / 13.1's with 1.8 60's and its just a 12" stall and 3.07 gear 4400#. I Love the MT SS radials and I will never buy regular slicks again as far as I care. Runs quicker than slicks and drives 10x better feels safer and is safer. My old 12.6 Cutty wagon Pont 455 4250# 3.08 gear combo went 12.6 on slicks and 12.5 on 235/60 15 OLD MT SS DR's
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.3 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg Last edited by PONTIAC LARRY; 03-30-2021 at 03:00 PM. |
Hopefully with better shock adjustments and a smarter driver/mechanic, I can remain consistent with the 26" rear. For street I throw in a twist style spring spacer to give a little lift to the front, especially when 2 people in the car. Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
Not sure if it's an option for you, now when I go to the track I throw on some smaller M/T drag radials.... They've handled everything I'm willing to throw at it so far. I'm hoping to stiffen up the chassis a bit in the near future.... Or take some stroke out. |
I run 275/60 Hoosier DR’ s on my 68 that is lowered 2”. With 27” tall 215/75/15’s on the front the car has a nice level stance. The 275’s tuck up in the wheel well aren’t really noticed at a glance unless you get down and look. They are just under 27-3/4” tall actual mounted size so not much difference in height from 255 Mickeys but over 1” more tread width.
275/60 Mickeys are over 28” tall in actual size plus the sidewalk width is wider than the Hoosiers with the same tread width. To fit them I’d have to “Joe Dirt” the back of the car, not gonna happen since I think the 68-69 A bodies look much cooler with the tail down.
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
275/60 MT's out back and their 28" front runners
Stock ride height with stock springs from Coil Spring Specialties. |
Same tires stock wheels
again, a 275/60 is only .5" taller than the 255/60 & is not that much of a difference to look "stupid" or joe dirt as you said. thats all my comment was about. if you dont want to run 275/60 thats fine, but the math is still correct & they are not much different in height. & 235/60 front to 255/60 rear is almost 1.5" difference... a half inch doesnt change that off set much at all. Last edited by 78w72; 03-31-2021 at 09:39 AM. |
Frank
Poncho Huggen, Gear Snatchen, Posi Piro. |
#38
I'm with you on the opinion of appearance and stance, very much in line with mine, all the while looking for an acceptable level of traction. I think the 26.30" or 26.42" will appear small as far as height goes and will also have issues hooking, I like the profile as is. Uber cool pic! Frank
#39
Also noted within that information I posted for interest is the subject of sidewall deflection, oven overlooked for the road feel not just the traction issue here.
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 03-31-2021 at 11:19 AM. |
#40
& looking at FJ's gto pics with 275/60 on the rear im not seeing "joe dirt" at all... looks great IMO. all depends on the suspension & stance of the car & of course personal preference. |
