It looks like Ames has new motor mounts available for 1964-74 A-body cars.
Part number N226A is for reproduction mount that is supposed to be thicker metal .150 thick compared to the Anchor .115 thick metal and proprietary rubber. Part number N242A for Torq lok mounts. |
The Following User Says Thank You to 462gto For This Useful Post: | ||
None for the longer 455 frame mount?
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
I was pleased to see the addition to the catalogue, too. I'm probably going to buy the Torq Lok mounts for my '66 build pretty soon.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
![]() Quote:
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet Th400 gone. Tkx close ratio with .64 of 66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque ![]() ![]() |
Im gonna bite when my spare 455 is done.
I just ordered a set of the Torq Lok mounts for my 67 LeMans and will see if they hold up as the ones that were in there were broken. The polyurethane mounts look like they are getting them from Butler. The problem with the polyurethane mounts is if they are too close to a heat source the rubber will degrade and fail. Not a good choice for RA/HO exhaust manifolds or if your header tube is close to the motor mount.
Tim Corcoran Last edited by Tim Corcoran; 04-24-2021 at 06:06 PM. |
