Old 04-24-2021, 01:29 PM
KGTO's Avatar
KGTO KGTO is offline
Default Rear antenna cable and wire routing
Do the cable and power leads follow the same path as the rear speaker wire?
They must run up the firewall behind the firewall pad like the speaker wire too.
I'm assuming the routing would follow the speaker wire since the floorplan has a path.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 04-25-2021, 07:11 AM
Jeff Hamlin's Avatar
Almost all the accessories such as Rear Speaker, Reverb, Defogger, Etc had the leads run along the PS footwell.
Not along with the Ribbon Harness and/or on the base of the floor.
These will go around and along the rear seat base to the Factory shield that protects the leads from being pinched under the seat frame.
I ran my Trunk Release Hose in this route but chose to move the power leads for my Rear Speaker and Defogger to the Trans tunnel side,
but should have stayed to the outside per factory layout for easier repair/access if needed.
Old 04-25-2021, 11:33 AM
KGTO's Avatar
Thanks! I wish the pictures in my assembly manual were that clear. When I originally disassembled the car (which had never been apart) the rear spear wire ran along the passenger side floor following the indents in the floor, which I always assumed was for this purpose. It was covered with a tan fiber insulation that was sticky, somewhat similar to the tar paper insulation
1964 421 GP-Sold
Old 10-15-2024, 07:11 PM
SD421's Avatar
SD421 SD421 is offline
Can I add another question?
Once the antenna/speaker wiring meet the kick panel; does it go under then up behind it?
And does the factory plastic strap screw attach under the dash?
I have pics here.
Thanks,
Don
ID:	641287   Click image for larger version
1966 GTO
1966 421-10.1-1 comp-Race Tec 23cc Pistons
KRE Tri-Power
KRE 65cc Aluminum Heads
XE274 cam by Comp Cams
DUR 230 Int 236 Exh @.050 - 110 LSA
LIFT .491" Int .491" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 10-15-2024, 09:35 PM
Scott Thelander's Avatar
the wiring goes behind the heater box
Old 10-16-2024, 05:18 AM
Exclamation Install info;
If you look at this sheet you'll see two wire routing layouts.
Factory and Field.
To answer your question yes the wires are run up behind the kick.
As you see they used tape to hold everything in place, No clips.
I use black Gaffers tape, it is some of the best tape out there for this type of thing.
I like the field route that keeps the wires forward above the glove box,
it makes life easy.
Old 10-24-2024, 11:18 PM
SD421's Avatar
Factory and Field.
it makes life easy.
Yes! Thank you Jeff!
1966 GTO
KRE Tri-Power
