Old 05-04-2021, 07:16 PM
BLUE TA's Avatar
BLUE TA BLUE TA is offline
Default forged piston prices
hi guys, Im going to build a 73 455 .030 over. been looking at prices and Icon seems to be the most reasonable. I was shocked to see auto-tec 1016.00 at shannons engineering. the Icons are 700.00 with rings at CE. I dont see sealed powers anymore. the 2359 030 doesnt seem to be available. what have you guys seen? thanks, BLUE TA
The Following 2 Users Say Thank You to BLUE TA For This Useful Post:
Old 05-04-2021, 07:34 PM
Mike Davis's Avatar
SP 2369 has been discontinued. ICON, DSS, ROSS or JE....
I would check with KRE or Butler.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
Old 05-04-2021, 07:43 PM
For my money the J&E pistons are my pick!
Yup there like 100 bucks each, but they’re aloy allows them to go in with only ,003” clearance so the skirts last longer, rings last longer and the motor is silent on cold start ups!
Old 05-04-2021, 07:51 PM
tom s tom s is offline
Might check with Paul K on this site.He is a Autotec dealer.My last 3 engine he helped me with.Tom
Old 05-04-2021, 07:55 PM
BLUE TA's Avatar
thanks for the info guys. BLUE TA
Old 05-04-2021, 08:17 PM
scott70's Avatar
scott70 scott70 is online now
XX2
The Following User Says Thank You to scott70 For This Useful Post:
Old 05-04-2021, 08:41 PM
TransAm400 TransAm400 is offline
Yeah I would call and check on the Autotec’s. I paid alot less than that last year.
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Old 05-05-2021, 12:40 AM
i82much's Avatar
i82much i82much is offline
i thought most forged pistons were either 2618 or 4032, with 4032 allowing tighter clearances. is there something else that J&E uses? any reason why a 4032 from another outfit wouldn’t have the same clearance requirements as J&E?
Old 05-05-2021, 12:47 AM
i82much's Avatar
would these work?
https://www.summitracing.com/parts/d...0/make/pontiac
Old 05-05-2021, 09:14 AM
PontiacJim1959 PontiacJim1959 is offline
Check Spotts Performance. If the site is current, some good prices.
http://www.spottsperformance.com/Pistons
The Following 2 Users Say Thank You to PontiacJim1959 For This Useful Post:
Old 05-05-2021, 09:27 AM
mgarblik mgarblik is offline
There are some other factors that play into the manufacturer's piston to wall recommendations. Alloy is a major factor. Also the amount of cam shape ground into the skirts, the size and style of the expansion holes, the position of the ring pack and the ring dimensions. Finally, the length and contact area of the skirts. The BME web site has a lengthy discussion of the advantages and disadvantages of 2618 vs 4032 alloy. Bill Miller has a engineering degree with specialties in metallurgy, so I am confident in his views. The Readers Digest version is 2618 is more ductile and crack resistant, far superior in drastic pressure rise applications or detonation prone environments. Such as blown, high loads of nitrous and other very high HP applications. It does require more clearance than 4032. 4032 is a nice option for performance street, and mid-level racing applications. Quiet and easy on cylinder walls. In our Pontiac engines I read this as about 700-800 HP NA engines. Over that, or with a big power adder, I would tend to move into the 2618 alloy. FWIW.
The Following 2 Users Say Thank You to mgarblik For This Useful Post:
Old 05-05-2021, 11:54 AM
i82much's Avatar
Very good info, thanks. I have 2618's in a mild 505 and wish I'd gone 4032, but didn't know there was a difference and thought any "forged piston" would be fine. Not a big problem but I can tell from the noise on cold starts that the 2618's will wear out quicker than something that can run less clearance.
Old 05-05-2021, 02:12 PM
BLUE TA's Avatar
Thumbs up
hi, thanks for all the knowledge and thoughts. BLUE TA
Old 05-05-2021, 03:46 PM
Lee's Avatar
Lee Lee is offline
I don't know how much of a discount I actually get (I have an account), but I bought a set of custom dished AutoTec pistons a few months ago. With rings and shipping, they were MUCH less than $1,000!
'73 T/A (sold). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 317rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 05-05-2021, 04:47 PM
BLUE TA's Avatar
just checked again, 1016.00 so I called and the voice mail box was full couldnt leave a message. ????? it must be a mistake. or extreme covid inflation. BLUE TA
Old 05-06-2021, 03:48 PM
GoatZillaRacing's Avatar
GoatZillaRacing GoatZillaRacing is offline
JE SRP Pistons $569 https://pontiacspeedshop.com/srp-pistons-1/
Randy Repp
1964 GTO "GoatZilla"
1964 GTO "Injunuity" A/FX Nostalgia Super Stock
220" Rear Engine Pontiac Powered Dragster
https://www.facebook.com/PontiacSpeedShop/
https://www.facebook.com/GoatZillaRacing/
https://www.facebook.com/groups/RebuildExcitement/
https://www.facebook.com/Call1844RacersRV/
https://www.facebook.com/groups/INJUNWARS/
Old 05-06-2021, 04:32 PM
BLUE TA's Avatar
thanks goatzilla, looks like 700.00 plus pistons and rings. BLUE TA
Old 05-06-2021, 04:51 PM
Mike Davis's Avatar
Originally Posted by GoatZillaRacing View Post
Good deal and a good guy to deal with!
421 CID
Old 05-06-2021, 06:35 PM
Custom dished for an .030 400 is what I'm currently after. AutoTec 4032 with metric ring pack.
Was very impressed with previous AutoTec 455 pistons that I purchased for another project. Will call Paul K, tomorrow, don't do FakeBook!
Old 05-07-2021, 01:09 AM
turbo69bird's Avatar
Run JEs in my turbo car. Been together at least 11 years probably more now without even changing a spark plug. I used to sell parts for ATVs at the race tracks and certain guys were destroying wiseco pistons regularly. I watched them for a bit and realized these guys would come out late for the LCQ fire up and rip down to the start line. I realized the looser tolerances required for expansion were really loose on cold start and these guys were beating the piston in the bore cold .
So I swapped them to a WSM watercraft piston w tighter tolerances .gold coated the top and polymoly on the sides these guys went from
Two months on a piston to 2 years! Shot myself in the foot couldn’t sell anymore
Pistons or top end kits. �� anyway if your running loose tolerances make sure you get that piston up to temp before beating that engine at all
My JE pistons are off the shelf nothing special no coatings
Oh yeah don’t do Fakebook or shhhitter either �� that’s as bad as taking a lonely and posting it there.
960 HP @ 11 psi, 9.70 at 146.
