I've never messed with AC before. But, I did replace my old system on my 72 Lemans and it came out nice. It was from Old Air and was basically a direct fit replacement. I hade hoses crimped at a parts house. You can do it. And say so with pride!
Just want to let you know so you can think about your project timing.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
I ordered mine from Summit Racing on 5/3, and got it yesterday on 5/7.
Lol, that's good to know! I ordered mine through OPGI. If I don't get my VA kit in the next few weeks, I'm going to cancel the order and buy elsewhere.
I've been ordering a lot of other parts through Summit over the past few weeks, and I have to say their order processing and shipping speed has been incredible.
I've put about 5 Vintage Air units in GTO's and Firebirds over the years. I'd say you'll easily spend 20 hours doing. I personally won't do one for less than $1500 labor
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
EDIT: Break the kit up by evap kit, condensor kit, and hose kit, all are in stock. The 'full' kits are backordered. .
When I checked shops most everyone quoted 30 hours for full install.... and depending if you work with fender on or off will add even more time.
Lotta work. Had help on mine and it took a lot of time. |
I'm putting a surfeit kit into my 66 Lemans right now and I think it would take a experience tradesman around a day and a half to 2 days.
Don't want to hijack Rocktimus' thread, but on the topic of VA installation, although the SureFit kits do not come with an electric pusher fan for the condenser, is that something that I/we should plan on buying and installing as well? I also bought a 140A alternator.
OE fan or any electric radiator fan is fine. There's no need for a separate fan for the condenser.
Great, thanks. One less thing to purchase!
Also, as an aside, my SureFit kit finally arrived in the mail yesterday, which is a relief.
On the same note, because Im considering buying electric fans. On the fence.
How much will adding the condenser set cooling back? Mine has been pretty good since I put in the high volume pulleys with the mechanical fan.
Condenser does block some air flow, but I would say it may impact temps by at most 5 degrees or so.
Remember, OE had AC from the factory, so this isn't something that's 'abnormal'. Also keep in mind the newer cores are more efficient, too. .
I installed the surefit kit in my 69 LeMans over the winter. I would say 20-25 hours is accurate. I liked the kit and think the install went well. My car was an original air car but I smoothed the fire wall years ago so I did not need the firewall plate. First time my car has had heat or air since the late 80's and I love it.
1969 LeMans..Liberty Blue 2001 WS6..Sunset Orange 1973 Pro Street Firebird..Lucerne Blue |
I'll add another 2 quotes I got for my 69 GTO, both respected and experienced Vintage install shops said expect around 25 hours @ $125hr. Doing the duo heater and ac requires the dash to come out I guess so that's a big part of it.
If you do this and need dash restoration etc, might wanna plan that into this while it's out. That's why I think I'll wait a couple years and do both at once.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
Yeah, dash removal doesn't apply to my '66 GTO, either. Sounds like it depends on the car model and year.
#38
I did not remove the dash on my 69 LeMans. It was a little tight behind the guage cluster but I didn't have to remove anything.
#39
I've had the VA Sure Fit for my 69 Bird on the shelf for over a month and plan to tackle soon so I may pick your brain. Did you remove the p-side fender? Also, did it make a difference in your stop and go engine temps? Electric or mechanical cooling fan.
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
