I'll add another 2 quotes I got for my 69 GTO, both respected and experienced Vintage install shops said expect around 25 hours @ $125hr. Doing the duo heater and ac requires the dash to come out I guess so that's a big part of it.
If you do this and need dash restoration etc, might wanna plan that into this while it's out. That's why I think I'll wait a couple years and do both at once.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct @ 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10", Rock Valley SS Tank, Dual 450s, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" & Borla Pro XS 3", Alum Rad & Dual Fans, 12:1 Box, UMI Arms & Viking Berz Fr + Rear CO Shocks, Hella UP5.0 Vac Pump, 12 Bolt, 3.73, 33 Spline |
