Old 12-04-2021, 09:18 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
True piece of art! I wish I could justify buying one. I want one just to set in my shop!
  #342
Old 12-04-2021, 11:14 AM
mgarblik mgarblik is offline
That billet beauty is the wallpaper on my computer screen now! Functional art. Beautiful! Can hardly wait for the casting.
  #343
Old 12-04-2021, 04:28 PM
3fastgtos 3fastgtos is offline
We could get into a bidding war on that billet intake.
  #344
Old 12-04-2021, 05:00 PM
Sirrotica's Avatar
Originally Posted by 242177P View Post
I'm shocked you didn't recognize it as something David E. Davis Jr once wrote.
"That’s one small step for a man, one giant leap for mankind".
-242177P (circa December 2021)
Probably because I don't pay much attention to Autoweek, or Motortrend, and there weren't quotes around the sentence, denoting it came from another source.
Actually until I read his obituary today, I had never heard of him, I must lead a sheltered life, huh?
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
  #345
Old 12-05-2021, 01:41 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by 3fastgtos View Post
... We could get into a bidding war on that billet intake...
At some point in time I'll be kicking myself for not bidding!
  #346
Old 12-05-2021, 10:51 AM
He has the software, tool path, and the CNC machine. All that's required is a big chunk of aluminum and a bunch of $$$, and I bet he would carve out a couple more! What a beautiful piece of Pontiac candy.
  #347
Old 12-05-2021, 01:54 PM
tom s tom s is online now
Started as a 200 lb block!Ended up weighing 18 lb.Tom
  #348
Old 12-05-2021, 08:06 PM
blueghoast's Avatar
WOW Tom, Can't thank you enough for getting this rolling.
What would we ever do without you.
Thank you Sir
GT
  #349
Old 12-05-2021, 08:22 PM
Without John Cogger and Jon Schmidt it would not have got done.It would have been twice as much to just get it to the pattern stage without them im sure.Tom
  #350
Old 12-05-2021, 11:35 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
To a poor ol country boy, it's the difference between dreaming and owning.
If I hit the powerball, I'll have the billet edition...
Much thanks to all involved !
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
  #351
Old 12-06-2021, 01:03 AM
scott70's Avatar
scott70 scott70 is offline
How long did it take to whittle that out? Shes a beauty. Its like an aluminum version of carmen electra.
  #352
Old 12-06-2021, 11:09 AM
Maybe John can tell how many hours of CNC time.Tom
  #353
Old 12-06-2021, 09:08 PM
61-63 61-63 is offline
I just clicked on this thread again after all of these posts starting after those pictures of the billet intake were posted. Absolutely Gorgeous!!! I can't wait until my casting gets here and I get a setup on it!
  #354
Old 12-07-2021, 12:26 AM
Darren 639's Avatar
Darren 639 Darren 639 is offline
Wait we are not getting the billet on one?
  #355
Old 12-07-2021, 06:41 AM
I am assuming the casting will be shaped like the billet cnc but only prettier being a casting.
  #356
Old 12-07-2021, 12:20 PM
darbikrash darbikrash is offline
The casting is based off the identical data base the billet was machined from. The billet does not have the water cross over, as it would be nearly impossible to machine from solid billet. The billet is intended to be used with a separate water cross over such as the one from KRE. I don't know how many hours are in the billet, I am truly afraid to add them up.
Both early and late model castings have the integral water cross over, just as the factory intake did. Our castings are identical to the factory units in every way even down to the casting numbers.
The production castings will have a high quality "as-cast" surfaces except for the carb flanges, cylinder head flanges, and thermostat regions which will all be CNC machined to net size from the raw casting. Most casting projects use T356 aluminum, we are using a higher grade aluminum type 808-F for better performance and much better appearance qualities.
We have seen examples of automotive castings from the foundry we are using here in Southern CA, and they are every bit as good (or better) than anything Edelbrock has cast.
1964 Catalina 2+2 4sp, 421 Tri-power
1965 GTO, Roadster Shop chassis, 461, Old Faithful cam, KRE heads 305 CFM,
Holley EFI, DIS ignition.
1969 GTO 467, Edelbrock 325 CFM, Terminator EFI
1969 Firebird Convertible
The Following 2 Users Say Thank You to darbikrash For This Useful Post:
  #357
Old 12-07-2021, 12:28 PM
They make the TD performance casting for the HiPo Buick guys.Tom
  #358
Old 12-07-2021, 12:58 PM
Keith Seymore's Avatar
Originally Posted by Darren 639 View Post
Please just promise to dump my ashes in my back tire and then do burnouts thank you. Lol.
Had a friend that we dumped his ashes down the carburetor of his big block Chevy Blazer.
K
'63 LeMans Convertible
'63 Grand Prix
  #359
Old 12-07-2021, 01:03 PM
Mike Davis's Avatar
I am glad this is getting closer. Also that it has a factory part number on it which will make it easier for some Nostalgia classes that require a factory style intake.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135
66 GTO (Retired race car)
421 CID
66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles
  #360
Old 12-08-2021, 08:47 AM
sdbob sdbob is offline
Thank you guys for your work and stick to the goal .Amazing. I remember back in 67 going into Pontiac dealer and ordering first an 886 then a 068 cam. I think sometimes that maybe the bathtub was in the parts book then? Just a dream.
