Old 11-11-2021, 03:37 PM
tc's Avatar
tc tc is offline
He did not mention heat and I did not ask him, this was a few years ago.
Your car should be whole lot of fun!
Old 11-11-2021, 04:50 PM
Scott Stoneburg's Avatar
Thanks, I cant wait to get it completed
Old 11-12-2021, 10:27 PM
blueghoast's Avatar
What were the dyno numbers?
GT
Old 11-13-2021, 05:47 AM
GT
794 HP @ 6700 rpm
697 LB-FT @ 5100 rpm
Old 11-15-2021, 12:59 AM
blueghoast's Avatar
Originally Posted by Scott Stoneburg View Post
794 HP @ 6700 rpm
WOW Impressive Thanks.
GT
Old 11-15-2021, 08:19 PM
shaker455's Avatar
794 HP @ 6700 rpm
AWSOME SCOTT!!!!!
Old 11-15-2021, 09:12 PM
Originally Posted by shaker455 View Post
AWSOME SCOTT!!!!!
Thanks Jeff, still using the 1050 you built for me. I picked up a 1250 Pro Systems, but I'm holding off putting it on until i have it running and driving smooth. Then I'll switch over
Old 12-19-2021, 11:21 AM
napster's Avatar
napster napster is offline
Very impressive numbers!!! Have fun and good luck it.
Old 12-19-2021, 04:39 PM
ta man ta man is offline
I've been tempted to put high quality flex couplers on my exhaust to raise up just behind the collectors. Yours looks great!
Old 12-19-2021, 06:40 PM
The high end flex couplers will probably work, I've seen them used in turbo applications. And Heavy trucks. ( Semi-truck) . You will just need to add exhaust hangers to ensure the flex coupling hold the pipes in the place you need them to be in. As it stands now I have only 2 hangers installed 1 at the rear of the muffler and 1 near the rear of the tail pipe It looks like my plan to make it to the track before the end of the year has fizzled out. I ran into several unexpected repairs and they have dragged out. The new split Mono leaf springs and adjustable shocks were not planned or really in the short term budget...lol.. and now rebuilding the steering column due to completely worn out bushings and steering coupler.
Old 12-19-2021, 06:55 PM
David Holmberg's Avatar
Very impressive Scott, can't wait to see it run!
Old 02-24-2022, 02:23 PM
Made it back to the track last night ( Showtime Dragstrip, formerly known as Sunshine Dragstrip) I only got 2 passes. 1st pass was only meant to be a "blow the cobwebs out" pass. I wasn't sure it would hook as the track has a questionable reputation. Left at 1900 and shifted at 6500.
60' - 1.442
330' - 4.037
660' - 6.245
MPH- 111.25
Second pass I couldn't do a proper burn out as there was no water in the burn out box, It blew the tires off when I left. Pulling a 60' of 1.70. it rolled the alternator belt on that pass so I didn't make anymore.
Old 02-24-2022, 02:35 PM
tom s tom s is offline
Scott,did you put a deep grove pulley on the alt?They are pretty EZ to find.Tom
Old 02-24-2022, 03:14 PM
I will be switching the pulley this week. I have a larger pulley with a deep grove. I assume by the way it has happened it has happened everytime I have turned it past 6700. So slowing down the belt speed could help too
Old 02-24-2022, 04:47 PM
Skip Fix Skip Fix is online now
I found on the IA/Camaro with a large alternator pulley and electric fans ti would not keep the battery up enough on my car so I used a deep small pulley.
Old 02-24-2022, 06:00 PM
I took the larger pulley off a long time ago because the alternator didn't start charging till about 1800 rpm. But, thinking about it now it doesn't really stay at that rpm unless idling like at a light or something so I should be ok. But while on the subject. Where did you get a deep groove smaller pulley?
Old 02-24-2022, 06:14 PM
I think RARE has an aluminum one.I want to think I had a rebuilt alt that had a deep one I took off also.
  #38
Old 02-24-2022, 06:15 PM
try this.
https://www.ebay.com/itm/19310393853...AAAOSwH1VaqrEc
  #39
Old 02-24-2022, 09:53 PM
Thanks Tom. I'll try that one
  #40
Old 02-25-2022, 01:24 PM
grandville455's Avatar
60' - 1.442
330' - 4.037
660' - 6.245
MPH- 111.25
Nice, when u going back Scott? U didn’t run it out the back? Or only 1/8 mile track?
Darby
M/T 275/60 ET SS Drag Radial
