Old 10-21-2021, 01:18 PM
JSPONT's Avatar
JSPONT JSPONT is offline
Originally Posted by firechicken View Post
What cylinder heads/chamber?
KRE Dports 320cnc port. had ross pistons made
  #262
Old 11-28-2021, 07:31 PM
ErikW's Avatar
ErikW ErikW is offline
Default Progress
Finally put some color on the Bandit today. 4 coats of Boulevard Black and 4 coats of clear. Now for cut, buff and graphics.
ID:	578757   Click image for larger version
ID:	578758   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #263
Old 11-28-2021, 10:39 PM
73 TRANSAM 73 TRANSAM is offline
Very nice TA! GL with ur quest to a low 8 second pass or better.
  #264
Old 12-06-2021, 10:56 PM
David Holmberg's Avatar
Awesome build Erik!
  #265
Old 12-07-2021, 02:57 PM
ErikW's Avatar
Thanks guys
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #266
Old 01-02-2022, 10:18 PM
ErikW's Avatar
Default More Progress
So, while I'm cutting and buffing out the paint on the Bandit, Nick is fabbing up some cool air ducts for the turbo compressor inlets, They utilize the existing cut-outs in the front bumper.
ID:	581278   Click image for larger version
ID:	581279   Click image for larger version
ID:	581280   Click image for larger version
ID:	581281   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #267
Old 01-02-2022, 10:26 PM
ErikW's Avatar
Default More Pics
I'm also adding a temperature/humidity sensor from a Mack truck air intake so I can monitor weather conditions. Utilizing Holley's software I can add a math channel to my tune file and have it spit out real time density altitude based on this sensors readings and my input of track elevation. Bandit will be it's own weather station. Pretty cool!
ID:	581283   Click image for larger version
ID:	581284   Click image for larger version
ID:	581285   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
The Following User Says Thank You to ErikW For This Useful Post:
  #268
Old 01-06-2022, 07:18 PM
R 70 Judge's Avatar
Very cool. Nice fabrication. I wonder if they will be worth anything ET wise?
James
1970 Trans Am
  #269
Old 01-18-2022, 03:08 PM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is online now
What does your car weigh? Killer work guys!
69 Firebird - Angry Bird
455 with 84mm Torqstorm
  #270
Old 01-19-2022, 01:18 PM
ErikW's Avatar
3460 or so with driver.
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #271
Old 06-20-2022, 12:22 AM
R 70 Judge's Avatar
Erik, do you mind posting some info about the turbos? I read 78/75 but didn’t see much else. I’d appreciate it. I may be jumping off the deep end and doing this soon. Thanks
James
1970 Trans Am
  #272
Old 06-21-2022, 06:18 PM
What did you pay for your Turbos?
Hope you have enough cash to purchase another set.
I did the air scoops "down low", (copying the Olds 442 1966 & 1967 Ram Air cars, but I had the air feeding a circular Ram Air "Box".
https://www.ramairbox.com/ The air cleaner had a filter.
I was amazed with how much road trash the scoops collected and transferred to the Air Box. A cup-full at times.
In your case I see no filtering system prior to the Turbocharger compressor blades.
Maybe you have some screening that was not visible in the pictures.
Hate to see a new set of Turbos trashed and needing a rebuild minimum because you killed your turbos.
Big Chief got his turbos for free from Precision Turbos (so if the Oklahoma grit kills them) he can get another set.
Food for thought.
  #273
Old 06-24-2022, 10:46 PM
ErikW's Avatar
Getting ready to update this thread. I have tons of pics to upload. The turbos are VS racing 78/75 T4 units https://turbo4less.com/product/vsr-n...n-7875-billet/
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #274
Old 06-24-2022, 10:56 PM
ErikW's Avatar
Default Back to work on the Bandit
Sooo, The car has been down for a good part of the year since Drag Week 2021 and our lifter demise. Upon tear down and inspection of the block we elected to machine up a new block as we had found a small crack on the parting line of one of the cylinders that experienced a little interference with the piston and needle bearings from the lifter exploding. Thankfully all pistons checked out OK. So while the engine was back out of the car, Nick decided to modify the front frame to allow oil pan removal. He jigged up the lower control arms, cut out the frame x-member and fabbed up a new x-member and forward attaching points for the lower a-arms. Now we can drop out the center and remove the oil pan for inspection.
ID:	593254   Click image for larger version
ID:	593255   Click image for larger version
ID:	593256   Click image for larger version
ID:	593257   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #275
Old 06-24-2022, 11:01 PM
ErikW's Avatar
Default More Pics
So during Drag Week 2021 after running an 8.500 at Norwalk we hit the road and the exhaust lifter on cylinder 5 decided it was through with life and came apart on the road to the next track. That ended our Drag Week abruptly.
ID:	593259   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #276
Old 06-24-2022, 11:09 PM
ErikW's Avatar
Default More progress
Nick decided no more drag and drives for now and we went about turning the car into a full time race machine. So, out with the heavy ass 4L80e and I built up a pretty stout TH400 for the car with aluminum forward and direct drums, 36 element pro mod sprag and 300M input and intermediate shafts. We ordered a new QA1 Carbon Fiber driveshaft also. While running the 4L80 we had problems starving the trans during hard acceleration (2.2g's) so Nick fabbed up a rear sump oil pickup for the TH400. We were going to do this for the 4L80e also.
ID:	593261   Click image for larger version
ID:	593262   Click image for larger version
ID:	593263   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #277
Old 06-24-2022, 11:14 PM
ErikW's Avatar
Getting the motor back together. Nick used a cool website called send-cut-send to make new coil brackets. You draw up what you want in Autocad and send them the file and tell them what material you want the part made out of and they laser or waterjet cut out what you need and send it to you. Saves a bunch of fab time.
ID:	593265   Click image for larger version
ID:	593266   Click image for larger version
ID:	593267   Click image for larger version
ID:	593268   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #278
Old 06-24-2022, 11:20 PM
ErikW's Avatar
Default She's officially a Bandit now
I had painted the car over Thanksgiving of 2021 and it has been sitting ever since. I finally got some ambition and cut and buffed the car and Nick put all of the graphics (Phoenix Graphics) on her. Now it looks badass!
ID:	593270   Click image for larger version
ID:	593271   Click image for larger version
ID:	593272   Click image for larger version
ID:	593273   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #279
Old 06-24-2022, 11:28 PM
ErikW's Avatar
Default Engine install
While it was apart we sent out a lot of the aluminum components that Nick had made to be black anodized. Previously most were just painted black. Pulleys, crank sensor bracket, timing cover, front motor plate coil brackets, valve covers, valley pan, fuel rails etc. Nick also installed a burst panel into the plenum of the intake while it was down.
ID:	593275   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
  #280
Old 06-24-2022, 11:33 PM
ErikW's Avatar
Default More stuff
Thought this was pretty cool. Nick machined the heads to accept 12AN ORB fittings in the intake side water ports . Now we can use a more low profile fitting for the water hoses. It's the little stuff. LOL
ID:	593277   Click image for larger version
1964 GTO
9.76 @ 137mph
2009 G8 GT
