Old 01-18-2022, 11:48 PM
Don't get me wrong, I understand you're building something to get after it with... I wish you the best and hope you prove everyone wrong..
  #102
Old 01-18-2022, 11:51 PM
Originally Posted by John Langer View Post
My 577 runs at BB weight minus 175 for being a Pontiac. If someone would want to try to duplicate my motor, it would be $85k+. That doesnt include any R&D. I have been running the same style castings since 2007. It takes more then a ton of hp to win races, you need the total package, trans, gearing, chassis etc.
I get...I wasn't trying to put you down. I knew you were in a grey area on weight...just wasn't sure what it was, that why I said "I believe"..
No one doubts the money and dedication you have..
I'm also aware it takes more than hp..
  #103
Old 01-18-2022, 11:52 PM
John Langer's Avatar
John Langer John Langer is offline
Didnt think i was being put down, just stating the obvious...
  #104
Old 01-19-2022, 12:37 AM
Stan Weiss's Avatar
Originally Posted by opeliac View Post
Ron Rhodes' car is the most impressive car in all of drag racing...I'm not talking about it being the baddest of all time...I'm talking about it being a competitive combo...
Look what Langer does with his BES N/A Pontiac...Turn Tony loose with billet parts and an open checkbook and i'd say it would be fast with twins...Would it be Hemi fast? NO, it wouldnt be...But, even you guys run with rules...
But, since you asked about the Pontiac competing with Ron's car under the exact same weight, ci, and tire...I dont think the Hemi would beat Ron either...
The HP that Ron Rhodes has is only half of it. The other half is the engine tuning and chassis tuning by Ron Rhodes and crew.
I believe if BES was given the money. They could build a Pontiac that at the same ci as Ron Rhodes engine would make the came HP.
Stan
Pontiac Pump Gas List
  #105
Old 01-19-2022, 12:54 AM
Engines are just pieces of iron and aluminum, and in some cases billet aluminum.
Engine does not know it is a Pontiac or a chebby.
Tony B is a very talented Guy who know a lot about making fast cars and excellent engines.
ALL FACTS.
PERIOD.
  #106
Old 01-19-2022, 01:10 AM
Stan
Same HP doesn't mean same acceleration rate..
  #107
ALL FACTS.
PERIOD.
Agreed, they don't know but they do have limitations based on parameters..
  #108
Old 01-19-2022, 01:43 AM
Stan
Tony has already built Pontiac motors the same CID as Rons that make more power. But not set up for spray. You would never get that pontiac motor in a car and weigh within 200-250 pounds of Rons car, unless it was a tube chassis car. If you did get in a paper weight, it would be so dam nose heavy, good luck getting it to work. My car is pretty light. His car with driver race ready weighs less then mine without a driver...
  #109
Old 01-19-2022, 01:52 AM
So ron runs an iron block I take it? Is there a penalty for a lightened block? Not that an IA2 ( 250+lbs) could get down to the sbc weight...around 180lbs or so I think
  #110
Old 01-19-2022, 01:57 AM
Also, being in the know, do you think that is the limiting factor? Weight? You said, a Pontiac made more power NA then Ron but was it a purpose built engine like Rons? That does come into play... Na vs PA built engine..as I know you are aware..
  #111
Old 01-19-2022, 02:15 AM
It's not my business to get into the details of Rons stuff. It is relatively easy to make 2 horse per cube with a Pontiac for an NA combination. As an example, Lil Jacks motor made more on nuts then Cagles 582 BBC. Both set up for spray. Cagle has been much faster with the same jet. Some motors have intrinsic advantages over others...
The Following User Says Thank You to John Langer For This Useful Post:
  #112
Old 01-19-2022, 02:17 AM
Its not just the block, the crank is heavier, rods longer, pistons bigger, heads heavier, push rods longer, intake heavier, balancer heavier etc.
  #113
Old 01-19-2022, 02:25 AM
I get it... so based on your previous post, is Cagle faster just due to weight.... I doubt it. Obviously it's the total package but where does LJ fall short? Is it simply time and development? With 32 kids, I'm sure he doesn't have the time to devote...or the over all engine parameters...the intrinsic advantages as you say
  #114
Old 01-19-2022, 09:01 PM
J.C.you's Avatar
J.C.you J.C.you is offline
Anyone have the scoop on what is planned for the Youman Pontiac motor
1966 GTO dragcar
1966 GTO Ragtop
1969 GTO Judge RA lll, auto
1970 GP SSJ
Factory stock oval track car
  #115
Old 01-19-2022, 09:36 PM
GTOGEORGE's Avatar
I think Tommy was planning on putting his Warp 6 Pontiac engine into his 64 GTO if i recall!
GTO George
  #116
Old 01-20-2022, 10:32 PM
J.C.you's Avatar
GTO George
Nice hate to see a 4000 Hp poncho motor not put to use��
1966 GTO dragcar
1966 GTO Ragtop
1970 GP SSJ
  #117
Old 01-21-2022, 12:58 PM
GTOGEORGE's Avatar
It is the highest hp Pontiac out there……except maybe the boss birds engine!
GTO George
  #118
Old 01-23-2022, 05:00 PM
pont406's Avatar
pont406 pont406 is offline
Question? are these Proline 481X and hemi motors close to replicating a factory GM or Mopar design as far as head chambers, valve layout, bore spacing, and other parts location parameters? or are they clean slate redesigned setups, (kind of like the LS was for the SBC V8 GM lineup)?
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
  #119
Old 01-23-2022, 06:34 PM
mgarblik mgarblik is online now
The 481X and Hemi don't look anything like a modern hemi, an old school hemi, or BBC IMO. I am sure some of the best features of many different engines finds it's way into the design, but they look like unique, purpose built, billet drag racing engines to me. A long, long way from any production engine. When we raced the Boss Bird, most of the well funded teams we ran against had billet blocks and heads, Alan Johnson, Brad Anderson Hemi's, mostly. Their biggest advantage against our production based Pontiac engine was ease of at the track parts replacement. The deep block offered easy access to all the main bearings for replacement. The Pontiac valley cover with it's two fasteners was always a concern to seal. These billet engines are designed for service. We could run right with them though, including our #1 qualifying spot at the NHRA Hot Rod Reunion. Here is a link to some information on the hemi and 481X from Proline. Looks like a used hemi is about 75K and a used 481X around 60K. Bring your checkbook.
https://www.prolineracing.net/produc...stage-4-engine
To try and answer your parameter questions a little better, the 481X uses a BBC bore center, not sure about the hemi. Here is a little more info from another source on the 481X .
" Running a high horsepower mill on an engine dyno is an abusive task for any dynamometer, and every dyno has a limit to how much torque and horsepower it is capable of keeping loaded. So as a means to preserve their high dollar investment, when most engine builders connect a freshly assembled 3,000 horsepower mill to the engine dyno — prior to shipping it out to the customer — the engine is generally tested at a fairly conservative power output which is often nowhere close to its peak potential, or even near the same level that the customer will be pushing it to in many cases.
To better stress-test their engines at a higher horsepower, to be fair to the customer, Steve Morris resorted to designing and building his shop’s engine dynamometer himself. While Steve states that this specific 525ci 481X engine is capable of holding itself together at 90 psi, not even the SME dyno would survive a max power pull with this engine. So this 481X was instead tested to between 40 and 50 psi of boost, which is still much higher than most dyno cell operators would dare to go.
The Build
481X Billet Block Pistons
AJPE’s billet 481X engine block and SME’s custom spec Diamond pistons.
As stated earlier, AJPE’s 481X engine platform is a hybrid between the big-block Chevy and Hemi architecture. It retains the big-block’s 4.84-inch bore spacing, but utilizes mostly Hemi patterned auxiliary components. And AJPE teasingly calls this combination the “Anti-Hemi.”
Additionally, many of the parts used in this all-billet build are designed in-house by the team at Steve Morris Engines. Including the custom SME designed billet intake manifold, 90mm twin throttle body setup with a tight radius “Ram’s Horn” intake elbow (for better clearance), SME valve covers, front motor plate, balancer, crank trigger pickup, and cam sync design!
The top end includes AJPE’s lightest “stage four” 6061-T651 billet cylinder heads, weighing just 36.6 pounds each! The heads also feature 73cc combustion chambers, 50 degree valve seat angles, Trend 1/2-inch intake and 9/16-inch exhaust pushrods, 0.937-inch Jesel lifters, and a custom grind SME camshaft to time the 2.450-inch intake and 1.920-inch exhaust valve events.
Steve Morris Engines - 481X Billet Block
AJPE’s billet 481X engine and “stage 4” cylinder heads, with a custom SME billet intake manifold.
Internal lubrication is handled by a five-stage Peterson dry sump oiling system, and fueling is accomplished using an Aeromotive front mount fuel pump feeding a set of Atomizer injectors — which are both powered through a single SME belt drive assembly.
Boost pressure is forced through the 481X using two Pro Mod-spec 102mm Precision turbochargers, while boost control is managed through a pair of Turbosmart wastegates and blowoff valves. But Steve says they will most likely be downsizing the turbos to better suit Tuttle’s needs before sending it out to him.
Holding all of that boost within the cylinders is achieved through the use of SME’s custom spec Diamond pistons, while a set of MGP connecting rods handle the torsional and tensile forces, and a 4.150-inch billet Bryant crankshaft keeps it all in rotation. And engine management for this project is controlled through a FuelTech FT600 EFI system, and Steve was just recently trained by FuelTech’s own Luis De Leon when he paid the SME shop a visit.
Steve Morris (left) and Luis De Leon (right)"
  #120
Old 01-23-2022, 07:06 PM
David Holmberg's Avatar
Monza is selling his fresh 481x for $55k, like Mike said "Bring your checkbook".
