adjustable rear upper control arms. which year do i need?
I put a 71 buick 8.5 in my 67 gto a few years back. Need to correct my pinion angle ,and wondered if it mattered if I used the early arms {longer } or the later arms {shorter}.
I would think the longer arm shortened would be better as long as there is enough adjustment. haven't decided a brand at this point. Experiences or opinions? thanks Tim |
You will need the 64-67 arms. The ears on the housing are in the same place, you need the control arms for the chassis used.
I would look at either BMR or UMI.
66 GTO Nostalgia Super Stock/Street Legal Car 421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99 Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
thats exaxctly what I wasnt sure about, since the old rear is long gone. thanks
https://www.umiperformance.com/home/...s-roto-joints/
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
I like the Spohn Del Spheres with two rubber bushings in the rear end.
