Old 02-10-2022, 05:07 PM
quicksilver97ta's Avatar
Default What happened here?
Brand new blower motor installed with original squirrel cage. Probably has less than 20 hours on it. Started making a lot of noise so I reluctantly pulled it out and found that the center section of the squirrel cage spins freely. This is on my 70 LeMans.
Old 02-10-2022, 05:21 PM
25stevem's Avatar
25stevem 25stevem is offline
I never looked closely at those things, is that center section a press fit that is now loose perhaps?
I do stuff for reasons.
Old 02-10-2022, 05:56 PM
Yes.
Old 02-10-2022, 05:58 PM
I would tack it but the wheel is steel and this center part appears to be aluminum, definitely not steel.
Old 02-10-2022, 06:23 PM
Okay put it in my little 12-ton press with the appropriate size sockets and pressed it back to a non slip fit. ��
And that was after calling around and looking for one without any luck.
Old 02-11-2022, 10:06 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
with it now in a non-slip fit the only other thing I might would do would be the famous JB weld. or run it till is gives up....then maybe make some serrations in the steel and re-squash your allum center
Old 02-11-2022, 11:24 AM
I considered using some epoxy but it seemed to crimp down really well by using the press. It will probably hang on another 50 years before it needs attention again or whenever this new motor dies.
And by the way, I was able to access the blower motor by slipping the inner fender down enough to reach it. Really really happy I did not cut the inner fender. And this is an AC car too!
The Following User Says Thank You to quicksilver97ta For This Useful Post:
Old 02-11-2022, 09:05 PM
Schurkey Schurkey is offline
With luck, the restored press-fit will be good "forever".
If it was me, I'd have drizzled a couple of drops of Loctite 271 in between the two pieces before squeezing 'em. Probably not really needed, though.
