#81
Second...Is it possible that the cast blocks are living on borrowed time at those levels, where the billet will add some insurance? Third...Is it possible that the billet blocks are able to add strength in the bore areas, that will enable higher boost levels? Fourth...Which can be repaired easier, a cast block or a billet block? |
#82
Do you think that is because of the skirted mains?
#83
#84
honestly?not At all, but I bet they don't have the cap walk of a non skirted block..would u agree,?
#86
Maybe Billy can tell us how much cap walk they have in SickGoat's engine. |
#87
We ran the Boss Bird non-skirted solid cast aluminum AllPontiac block somewhere north of 3000 hp and it was pretty impressive. But there's a practical limit out there somewhere and if a person was going to spring for the $$ of a billet block, going skirted would seem to be an obvious move to raise the limits.
JMHO, Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
| The Following User Says Thank You to Elarson For This Useful Post: | ||
#88
At my little hp level with an IA2, I had cap walk... I ran the same mains for 12 runs... after that it was done.. that was roughly 2k hp...
So if I wanted durability, why would I buy a non skirted block? If I can get ahold of the tune on current blocks with no skirts, why do I need a billet version of the same...?? My point is this, I can run a car and changed out bearing all day long.. did that in the beginning with rod bearings to find the tune.( doubt you know what I mean there) if you do, let me know .. it's called reading a dead soft bearing... You're over you head bud... best u can do is go away..kre uses the customer as a test mule... they are douchbags... |
#89
Not being an ass Eric, u guys set the bar! Just curious if u think a skirted block would have helped at u level? I know it would have helped us at out at our little level compared you you guys.. |
#90
Lol...in the middle of this, that made me giggle like a middle schooler...
Thanks Paul... |
#91
But hell, maybe I’m just over my head. |
#92
Here we are again with the dumbass kre block |
#94
As for any smart a$$ comments. I’ll try a little harder now to achieve my goals. Thank you |
#95
I get the fact that you have bad blood with them, and I don’t blame you at all. You can attack me all you want, and it will only make me smile and try a little harder to throw it right back in your face. |
#96
Again, wish u the best, I'm far the smartest here but I would be glad to help u out If can. If u have Travis Q on ur side, ur golden.. |
#97
| The Following User Says Thank You to mgarblik For This Useful Post: | ||
#100
You guys set the bar for hp and durability! God knows, nitro will find the weak link... |
