Old 02-12-2022, 01:01 AM
Gach's Avatar
Gach Gach is offline
Default Rich Guido wins his Class !
Congrats Rich. Wins with average 8.70-8.90 ET if I understand what announcer said correctly now he’s only got 3200 mile ride back home.
https://youtu.be/fCd_7vT3BX4
The Following User Says Thank You to Gach For This Useful Post:
Old 02-12-2022, 01:26 AM
Scott65's Avatar
Scott65 Scott65 is offline
Truly impressive. Congrats to Rich
'65 Tempest 467 3650# [email protected]
Old 02-12-2022, 07:25 AM
25stevem's Avatar
25stevem 25stevem is offline
Very amazing accomplishment and he deserves every accolade that can be given!!!
I do stuff for reasons.
Old 02-12-2022, 09:43 AM
Sounds great. What was the payout?!
Old 02-12-2022, 09:50 AM
chuckies76ta's Avatar
Starts around 2:48 in video. Congratulation goes out to Richard and his Team. What a thrill having your Dad with you.. Thanks for posting Video Gach.
950 Quickfuel.
Old 02-12-2022, 01:48 PM
JLMounce JLMounce is offline
Isn't this car a traditional Pontiac block as well? (not IA, KRE etc.)
Really impressive, especially when you factor in the drive to and from.
-Jason
1969 Pontiac Firebird
Old 02-12-2022, 02:10 PM
It’s an IA2 block. Probably around 1500 hp Car is around 4000 lbs. And Standard.
950 Quickfuel.
Old 02-12-2022, 02:43 PM
I must have been thinking about a different car. Either way, highly impressive.
-Jason
Old 02-12-2022, 02:58 PM
Yes I realized that, and it sure is impressive .
950 Quickfuel.
Old 02-12-2022, 04:42 PM
Gach's Avatar
Yes, with E-heads. I know a little about the cam, solid roller. Here’s what’s impressive to me, you hear so many different opinions on solid roller cams not lasting on street, just trying to make people think about this. He’s driving 3200 mile back home. Allot have jumped on the hyd roller cam thing. Look at all the issues they’ve had with hyd roller set up. His build makes you think.
Old 02-12-2022, 08:02 PM
ponjohn's Avatar
ponjohn ponjohn is offline
He went 164 at 4025 lbs. 1370 -ish hp.
Getting 17 mpg.
Old 02-12-2022, 08:45 PM
Gach's Avatar
I’m curious as to what gear he’s running. The GeForce trans is the key to 17 miles per gal. at one time he said 14 miles per gal. Must of made some changes. It allows him to cruise 60 mph at 1700 rpms. It’s 5 speed trans, I think he only uses 4 speeds when racing.. Made mistake 3400 miles back to Canada. He must be home by now probably in the pool, with a cold one..LOL yes very cool his dad was with him the whole.
Old 02-12-2022, 08:47 PM
wolf's Avatar
wolf wolf is offline
Rich also won the "most outrageous pass" award, I'm guessing for the 8.77 while banging an H pattern (it's a faceplated T56 6 speed). He's truly a legend on the drag and drive race scene. Bad ass car, bad ass driver/owner/builder.
Old 02-12-2022, 09:06 PM
Gach's Avatar
Humm ? Guy doing video keep saying GeForce and got Rich to repeat and comment leading me to believe it’s 5 speed GeForce. Clutchlees only using clutch to launch, in one of the videos he appeared, to be shifting not using clutch, but hey I could be wrong. Hard to really tell by video. Just wondering why the push GeForce trans so much in all videos.
Old 02-12-2022, 09:16 PM
Mr_GTO's Avatar
Mr_GTO Mr_GTO is offline
They raced 2x in my area. I saw a few cars on the road heading back to Bradenton yesterday I didn't see his and I'm sorry I did. I did post a thread in the Lobby about my seeing a few guys that were racing a 86 Trans Am. You'd probably recognize the names.
Old 02-12-2022, 09:44 PM
I've given serious thought to a street solid roller. It's not the mileage that scares me, it's the idle time.
-Jason
Old 02-12-2022, 11:03 PM
ta man ta man is online now
Rear is 3.50 the 6 speed T56 magnum is faceplated 1-4 so technically it can be shifted without the clutch you just have to find a way to unload it, like bouncing off the rev limiter for example.
Straight from the man himself
Old 02-13-2022, 12:22 AM
Gach's Avatar
Right from Horses mouth, don’t get any better then that. 3.50 gear noice.
Old 02-13-2022, 12:43 AM
Gach's Avatar
I’ll bet Rich has allot of idle time driving 3400 miles. The most important thing about a solid roller is keeping up with the lash. Specially if your running aluminum heads, because aluminum heads expands , adjusting valve lash cold, you always want to be .002 tighter on the lash it’s the opposite with iron heads.
Think I’ve had one Chevy after 10,000 mile wipe out a roller, because he never keep on top of the lash. He complained to me that it was noisy.
Old 02-13-2022, 01:17 AM
wolf's Avatar
It's a T56 Magnum built by G-Force, with G-Force innards. It's not clutchless (i.e. with split sliders), it's just faceplated on 1-4 gears. With a power interruption (like lifting), you can shift it without the clutch, but it's not a true clutchless transmission that will shift under power.
