#721
A Holley double pumper is also a fine carburetor but won’t get the fuel economy of a Quadrajet which is pretty important nowadays.
1964 Tempest Coupe LS3/4L70E/3.42 1964 Le Mans Convertible 421 HO/TH350/3.08 2002 WS6 Convertible LS1/4L60E/3.23 1966 VW Type 2 Single Cab Pickup 140hp 2276 1956 VW Type 2 Panel Van 36hp 1200 1957 VW Type 1 Beetle 180hp 2276 |
| The Following User Says Thank You to b-man For This Useful Post: | ||
#722
Thank you b man
#723
[http://forums.maxperformanceinc.com/...ghlight=Sniper url]http://forums.maxperformanceinc.com/forums/showthread.php?t=822906&highlight=Sniper[/url]
Will Rivera '69 Firebird, 400/461, 290 Eddy D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '69 LeMans Vert, XS 350, #47 heads, TH400, 10 Bolt 3.23 gears, work in progress ‘66 Lemans, 455, 310 KRE D-Ports, HR 236/245, TH400, GV OD, 12 bolt 3.73 gears - see it here: https://youtu.be/RP_s1wJKm_Y?si=K0NZxoTyaGcj8Dcb |
#724
No I have had two. One was a Christmas gift and one was gotten when I thought I was further along than I was. This has been quiet the journey.
#725
Shaker455 can’t hook me up with a quad but he can help me tune my double pumper (Brawler)
https://youtu.be/dNwfbQA-d4U That’s a neat video
#726
FWIW (believe me) I would only go with the Edelbrock port for the simple reason the ECM can be located inside the passenger compartment. Under hood automotive is a hell hole and any complex electronics are at risk. OEM's have pretty well-established supply chains and are able to keep counterfeit crap components out of the production. Not so sure about the aftermarket.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
| The Following User Says Thank You to MarkS57 For This Useful Post: | ||
#727
Carburetor building & modification services Servicing the Pontiac community over 25 years |
| The Following User Says Thank You to shaker455 For This Useful Post: | ||
#728
Yeah it wasn’t that he couldn’t, it was my intake. I agree about the Edelbrock Pro Flo. I know your mileage may vary but after I got it running and looked at the wires (that I planned to put in a loom) and got to thinking about troubleshooting on the side of the road I thought of the old KISS acronym and Air/Fuel/Spark. As long as you got all 3 should run. One bad splice on that thing and here comes the ohm meter.
#729
Before you install that carb, spray it with Sharkhide coating otherwise you'll be surprised how quickly the polished look disappears. Tape off the entire top, sight glasses on the bowls and all openings. Wipr down with lacquer thinner first to remove any oil. I spray linkage and all with a light coat. It's the only thing I've found that maintains the polished appearance. doesn't yellow and is fuel resistant.
https://www.amazon.com/Sharkhide-Aer...5594404&sr=8-4
Triple Black 1971 GTO |
#730
I would reco using wax and grease remover instead of lacquer thinner. I love lacquer thinner. But it eats about anything! I screwed up years ago. I use Eagle mag wheel cleaner for aluminum parts. It has acid and works great. Works really well on my Centerline wheels. I started using it to clean my intake manifold as well. Didn't think about it getting on my Holley carb. It ate some of the coating away. DOH! https://www.amazon.com/Valvoline-E30.../dp/B00J4RN7RS |
#731
But I guess some find that daunting and become overwhelmed. Doubt you would have had an issue where it would leave you stranded, many run them for many miles with no failures. Shoot, the old Commander system from the 90s is still in use today with no issues, and Holley still supports it. .
#732
#733
You realize it does take a little time to learn, you have to let it run and drive it some.
If the tune isn't good, and you are impatient, you can use a tuner, it's all over the phone/internet, and there not that expensive. There are others on here that have the same setup, and could even give you a baseline tune. If you need help with that, call me. 'Splices' usually work or don't. It's still not a lot of wires to give a tug on to figure out if it's 'bad'. Holley forums are not very good depending on where you post and who responds. 99% of all issues are user-caused, and then they blame the system. You get much better support if you email Holley. They will respond, get your phone number, and call you back pretty quick. Screw trying to call the support number. Once it's installed properly and running, you will never have to touch it again (for the most part). Just get over the initial hump and it's going to be the best experience, especially from a maintenance & reliability perspective. The best things never come easy. I have a tune on-hand you can use that would be very close if not right-on. You have my personal email, just ask. .
#734
So you're blaming the EFI, for what likely is an install issue, or issue on the engine itself. If it's popping out the throttle body on shut down there's several issues that can point to that. Timing issues, poorly adjusted valvetrain, lean conditions and vacuum leaks contribute to this. Do whatever you want, but it's pretty clear you gave up on this deal before you even started. Which at that point why'd you even install it? You took several hundred bucks off resale value going from new in box, never installed to installed and removed. Your wallet though.
#735
Can the answer be as simple as I wasn’t sure about it in the first place and then I just didn’t trust it. As far as installs go I did everything I am capable of doing without paying a pro. I can tune a carb, I am just afraid of it I guess. My nephew who is normally great at these things even said he didn’t know what to think and he is from the whiz bang generation. I am getting kinda close to the point of driving this car regular and fear is a big factor. I trust carbs, maybe I’m crazy but I don’t want to drive to Tampa in August on our vacation in something I am paranoid is gonna crap out. In my heart of hearts I know it probably wouldn’t but I just don’t have the warm fuzzy and that is important to me. I sold it, it’s shipping tomorrow, my carb comes today and hopefully I can drive it as soon as my seat comes back.
#736
You can say, that, but you didn't. You installed it, even posted a video that it worked, then blamed the mess of wiring as to why you were removing it. You even posted it for sale on Facebook stating precisely that. Nothing about you being uncomfortable with it, only that you didn't like the mess of wires. The for sale picture focusing on your mess of wires was a nice touch to.
https://www.facebook.com/groups/Rebu...61475627361975 You're blaming the product when you should be blaming yourself, which is kind of a constant in this thread. That may be why it gets heated at times and has a pretty poor rating. Instead of posting that Pros and Cons thread where everyone came out to help you, you could have just posted here that you wanted a carb instead. Nobody would have faulted you for that.
#737
It's your car, do what you want and feel comfortable with, what makes YOU happy. Buddy of mine is building an old school roadster, all by hand, and is going out of his way to use parts that are period correct. Not because they're the best, they aren't, but because that's what he wants, and, to him, they're cool. That's what hot rodding is all about. .
#738
#739
Sometimes you just need to step away, take a break, and rethink things too. Especially when you get frustrated.
I will say this though, there is NOTHING painless about a Painless harness. It will challenge you for sure. I did an AAW harness, and to hide it all and make it look good took many days. .
#740
| The Following User Says Thank You to 68WarDog For This Useful Post: | ||
