Old 02-26-2022, 08:04 PM
PunchT37's Avatar
PunchT37 PunchT37 is online now
I still think that RPM manifold is overkill for stock 093 heads.
Old 02-26-2022, 08:22 PM
25stevem's Avatar
25stevem 25stevem is offline
In full agreement with post 21 besides having real world on the road daily driver experience with it.
If that’s not enough for the OP then here are Edelbrocks own recommendations.
I do stuff for reasons.
Old 02-26-2022, 09:16 PM
61-63 61-63 is offline
Cardo post #2 and b-man post #15 and both correct IMO. An original AFB from the era of your car is the most reliable and trouble free four barrel route you can go. Holley or quadrajet carbs can be made to outperform an afb but can both be real PITA if not set up right in the first place and both take more expertise than does the afb to get set up. The same applies to the tripower setup with the added criticisms that it is the system most likely to get out of whack down the road, the carbs themselves have several engineering flaws, and sets have the most fuel connestions so are the most likely to catch fire. But trips ARE sexy as b-man says. If you want reliability and sex appeal both go with dual quad afbs on an offenhauser intake.
Old 02-26-2022, 09:20 PM
tom s tom s is offline
2 are ALWAYS better than one or three!Tom
Old 02-26-2022, 09:35 PM
77 TRASHCAN's Avatar
You could go the opposite of the "Coolness" of a tripower and use an O.E. cast iron Q-Jet intake with a real Q-Jet, then wait for all the Quadrajunk comments. Of course this "might" be the best performing combination...LOL
Shut it off
Shut it off
Old 02-27-2022, 10:01 AM
carbking's Avatar
carbking carbking is offline
I could not have said it better!!!
The fact you did not specify is YOUR desire:
(1) eye candy (tripower or dual AFB's)
(2) street performance with a basically stock engine (single AFB, dual AFB, Q-Jet)
(3) win the bench "my engine makes more HP than your engine" race (dual AFB, Holley, Q-Jet)
Footnote: All AFB references above are to genuine Carter AFB's.
Once you have answered the above question to YOUR satisfaction, the choice of an intake manifold becomes fairly obvious.
Jon.
Old 02-27-2022, 04:28 PM
1bad65's Avatar
1bad65 1bad65 is offline
Jon.
Jon, you're absolutely right, I should have been more specific. My 65 build is going to be a weekend cruiser which fits # (2) street performance with a basically stock engine (single AFB, dual AFB, Q-Jet). Thanks.
Paul
Old 02-27-2022, 04:30 PM
1bad65's Avatar
Agreed. Thanks.
Old 02-27-2022, 06:12 PM
gtospieg gtospieg is offline
What manifold or manifolds do you currently own? If you own a stock 65 4bbl intake that should help make the decision a little easier.
Old 02-27-2022, 06:42 PM
carbking's Avatar
The first criteria in making a happy customer is to listen to the customer!
Jon.
Old 02-27-2022, 09:34 PM
1bad65's Avatar
I have an Edelbrock Performer, a 69 iron 4bbl intake and a 66 Tripower intake. I think I'm going to use the 69 intake for now and once the car is out of the shop (Body & Paint), I'll install the tri-power.
Old 02-27-2022, 10:50 PM
Do you have a proven QJ for the 69 intake?Tom
Old 02-27-2022, 11:34 PM
1bad65's Avatar
No I don’t.
Old 02-27-2022, 11:36 PM
1bad65's Avatar
No I don’t, I’ll need to start looking for one.
Old 02-28-2022, 11:33 AM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Stick with the Performer RPM and the 650 Holley. The 650 is not too small at all. Its about the perfect size. Ive done a lot of dragstrip testing with different sized carbs and different sized motors and was shocked to find that going smaller on the carb than conventional thinking implies, resulted in quicker ET,s. BTW my testing proved to me without a doubt that a properly sized Holley 4150 was always quicker than a Q-jet. Several other racers that I know came to the same conclusion. They just don't post here.
Old 02-28-2022, 02:16 PM
25stevem's Avatar
He does not have a Performer rpm to stick with as is recommended in post 35, he has a Performer and a iron intake .
Old 02-28-2022, 04:38 PM
1bad65's Avatar
Confirmed. Thanks,
  #38
Old 02-28-2022, 04:39 PM
1bad65's Avatar
I don't have a Performed RPM, I have a Performer. Thanks.
  #39
Old 02-28-2022, 05:56 PM
The regular Performer worked great on a 400 I was testing back in 90,s. It was a 79 T/A with a 400 and ran the quickest time with a Performer and a Holley 600 DP. It ran a 14.2 with the factory intake and Q-jet. Changing to a Performer and a 600 DP it went 13.8. I tried a 800 DP and the car slowed to 14.0.
They say the Performer doesn't work on 455,s. I don't know because I never tested one on a 455 but I can say for sure they work great on a 400 which is basically the same as a 389.
  #40
Old 02-28-2022, 07:38 PM
TxSportCoupe's Avatar
TxSportCoupe TxSportCoupe is offline
Performer for the street. Has better bottom end torque than RPM. Less weight and better heat dissipation than Iron. Holley Street HP 750 on a 1” phenolic wood spacer. No choke. Mechanical secondary. You’ll have to feather the throttle to keep it alive for the first 20 seconds. Guarantee you’ll be in the zone on air fuel mixture out of the box and it will be snappy and not run out of fuel on the back end of a hard run. New polished aluminum body helps keep fuel from flashing over and vapor locking. Looks and runs fantastic. Best all around combo I’ve come up with in 40 years.
