Old 03-27-2022, 10:35 AM
bobzdar bobzdar is offline
So when was the 744 used? I thought that was the d-port ram air manual trans cam and 068 was the auto... Or was that just certain years? Clear as mud, per usual.
The crashes people remember, but drivers remember the near misses.
  #42
Old 03-27-2022, 01:20 PM
rdl's Avatar
rdl rdl is offline
As I understand it, in ‘69 the 744 was a GTO only item (I’m not even sure it was for the entire model year). Someone else here will certainly know.
'69 R/A III Firebird Convertible
14.0s @ 100.8mph AMA/OEM/OER
  #43
Old 03-27-2022, 01:42 PM
SD455DJ SD455DJ is offline
From what I understand (certainly could be wrong), the 744 cam was offered very early in RAIII availability then removed from production RAIII engines (GTO) due to cold weather drivability (?) and valvetrain noise/issues. The cam was gone from production engines well before the Judge was unveiled in Jan. '69. Remember, this was the early Ram Air cam in late 66, 67, & 68 (before the RAII) along with mandatory 3.90 gears (Firebird 400's)/4.33 gears (GTO) and HD cooling.
Dennis
