#81
And I'm jealous of your garage that will have the 2-post lift. I have a scissors lift I hate and I'm selling it. Besides that, I only have an 8 foot ceiling.
Clearance is even less because of the garage door opener unit. That will be replace with a wall mount opener that attaches to the torsion bar. Lift Master is one brand: https://www.liftmaster.com/8500-wall...openers/p/8500 A friend of mine has 2 of these unit, for his garage. Nice thing is you can raise the doors separately with one external keypad.... with separate codes. To close them, all you need to do is press Enter for them to close.... no code needed. Codes are only needed to open them.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
The Following User Says Thank You to GT182 For This Useful Post: | ||
#82
![]() Quote:
Thanks! Pat |
#83
There was a rattle in the drivers door, only with the window up, and the driver side armrest was showing it’s age. So after pulling the armrest, cranks, and door panel off to find a broken rear door glass track (clearly the source of the rattle) I remove the vinyl from the armrest and replace the foam. It required steaming the original vinyl to stretch it back into shape before recovering the new foam with it.
Takes a little more work to keep this Survivor GTO as original as possible but it’s worth it. Thanks Pat ![]() ![]() ![]() ![]() ![]() ![]() |
The Following User Says Thank You to keepat For This Useful Post: | ||
#84
Clearly the right guy has that car.
Greg Reid Palmetto, Georgia |
The Following User Says Thank You to Greg Reid For This Useful Post: | ||
#85
Agreed. Similar to the gent who posts here with the original gold '67 that he got from the original owner. The right 'new' owners doing their cars proud. Helps make up for guys like that guy who was here a few years back who found a triple black 4 speed tripower '66 survivor and turned it into an LS powered restomod and parted the original drivetrain.
Jeff |
The Following User Says Thank You to geeteeohguy For This Useful Post: | ||
#86
Just trying to make up for all those crazy things I did to my first GTO and I was a teenager;-)
Thanks Pat |
#87
I put the all original Survivor GTO on the scales. It is a 4-speed, 4-barrel car, with power brakes and steering. The car has extra under coating installed by the first owner. 1/2 tank of fuel, spare tire and jack in the trunk. She weighed in at 3599 lbs!
Thanks Pat ![]() ![]() ![]() ![]() ![]() |
#88
Cleaning 55 years of road grime and bug guts out of the 350 +/- grill openings on the drivers side grill, Not fun! I used spray nine and a bunch of Q-tips along with some foam brushes. Then using a foam brush I treated the plastic with Mothers back to black plastic restorer. The original emblems are in excellent condition just needed a good cleaning. A lot of work to preserve an original grill, but I think the results were worth it.
Thanks Pat ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#89
Nice work!
The Following User Says Thank You to bdk1976 For This Useful Post: | ||
#90
I said it before, and I'll say it again: that car got the right new caretaker! Excellent work on a stunning car.
Jeff |
#91
![]() Quote:
Pat |
#92
Moved the Pontiac’s (and my sons car) over to the new shop this weekend. Nice to start using the new shop after spending six months remodeling it;-)
Thanks Pat ![]() ![]() ![]() |
#93
Nice!
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
The Following User Says Thank You to keith k For This Useful Post: | ||
#94
Trying to figure out what I am more jealous of, the cars or shop???
#95
I like the emblems on the cabinet doors. Nice touch.
![]() 1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
#96
I thought it was a cool way to label the cabinets. There an alphabetical order and the tool lockers I used engine displacements from Ford Dodge and Pontiac.
Thank You! Pat ![]() |
#97
The car is looking amazing! What is in the shop under the cover with the big spoiler??
#98
#99
Damn that is awesome. Is that the modern bullitt build? That is an amazing build. One of the best I’ve ever seen.
The Following User Says Thank You to 1965gp For This Useful Post: | ||
#100
![]() Quote:
Thank You!! Pat ![]() |
