#1961
3.89 rear gear with a 33.5" tire.
![]() 2023 Best ET Slip 60’ 1.224 330 3.186 1/8 4.784 MPH 152.07 1000 6.175 ET 7.347 MPH 189.92 Weight 3650 YouTube Channel --> https://www.youtube.com/channel/UC21...rWwgFdfTRqShGQ FaceBook Group --> https://www.facebook.com/groups/220092308823847/ |
#1962
I would take a 2 barrel 389 in a Pontiac over a 1000hp LS.. |
#1963
A little pot stirring going on myself. I figured you would respond quicker, slowing down my man ! Yep, cross breeding sucks, it goes against the laws of nature.
| The Following User Says Thank You to Dragncar For This Useful Post: | ||
#1964
Don't badmouth all "crossbreeds". I've run Pontiac engines in:
'37 Buick '60 Ford Falcon '57 Chevy BelAir '57 Chevy wagon '59 GMC '83 Chevy Suburban ('Bandit' built by Wangers) Mini-rod puller- numerous V8 Pontiac engines, carbureted/injected/N/A/blown, gas/methanol Lakester- DOHC hemi Pontiac, blown methanol
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
| The Following User Says Thank You to Jack Gifford For This Useful Post: | ||
#1965
Getting back at them is always good.
I would like to build a 69C10 4x4 with a 455 myself. |
#1966
I have been involved with a couple of of Chevy Suburbans with 455 cid Pontiac engines.
Chassis is just a way to transmit the torque and power. Same deal with Tempest vs Lemans, vs GTO. Tom V.
#1967
Well... 2022 so far hasn't been positive so far due to parts delays and issues found during re-assembly. The heads are back out for a bit of welding on 2 intake ports "minor cracks that don't go through to the exhaust port" and to address the new valve seat installation issues noticed after head tear down and further inspection.
| The Following User Says Thank You to RAIV-Z For This Useful Post: | ||
#1968
PONTIACPOWA' TTF!!! |
| The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
#1969
"RAVEN YOUTUBE CHANNEL"
https://www.youtube.com/channel/UC21...TRqShGQ/videos |
#1970
perform perfectly. Would love to find a clean Suburban and do one for myself. Tom V.
#1971
#1972
Link didn’t work. Just me?
You know me, "Safety Forst" 68 GTO-Verdoro/Black/Black, what else was available in ‘68? Has to be longest resto in history. 69 GTO Vert-Liberty/Blue/White Top, 4spd, match #’s 68 Mustang FB-Green/Black (Bullitt) |
#1973
| The Following User Says Thank You to Stuart For This Useful Post: | ||
#1974
#1975
What I do at the track when not racing.
#1976
Heads are at Marcella Manifolds to be welded up and refreshed for hopefully a successful 2023 season.
| The Following 2 Users Say Thank You to RAIV-Z For This Useful Post: | ||
#1977
What ETs are you hoping for this year? Didn't know if you had a certain goal in mind. It's pretty damn good for 3600+ lbs.
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.45 @ 88.1 mph on slippery street tires.Bad 2.19 60ft.Owned since 86' |
#1978
Thanks! I'd like to run anywhere in the 6's with most of what I have now and then determine next steps.
#1979
We'll (John) be welding up all 8 cylinder walls so we can increase the boost in 2023. Drive train upgrades will also need to be considered.
#1980
That's a lot of work. Sometimes it pays to be conservative with a high end boost head. It pays dividends with low maintenance and longevity verses little additional power.
