Old 04-29-2022, 12:44 PM
Originally Posted by 64speed View Post
I do have a slight amount of the dreaded roller lifter tic but not enough to justify trying to mess with how my builder set them up.
It might just need adjustment.
  #862
Old 04-29-2022, 01:33 PM
ZeGermanHam's Avatar
Congrats! I think the exhaust tips look very nice. Car sounds great, although I'm not totally surprised that it's on the loud side. You have a serious engine under the hood. Regardless how how loud it is from the outside, perhaps a bigger factor will be how loud it is from inside the car while driving. If you don't have excessive exhaust volume or drone inside the cabin when driving, that should make it more reasonable to live with. The neighbors can deal.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
  #863
Old 04-29-2022, 02:26 PM
64speed's Avatar
64speed 64speed is offline
37 trouble free miles other than a small power steering leak I think I found
The Following User Says Thank You to 64speed For This Useful Post:
  #864
Old 04-29-2022, 03:12 PM
grivera's Avatar
grivera grivera is offline
It sounds great. What RPM is idle at and what brand lifters? Also, what oil viscosity?
Will Rivera
  #865
Old 04-29-2022, 08:07 PM
64speed's Avatar
61 miles break down free. I do want to be proactive about one potential problem. After about 20 mins idling in 75-80 degree weather the temp gets up to around 200. I can potentially see this being a problem in SC when it gets to be 90 everyday. Tips and tricks now?
  #866
Old 04-29-2022, 08:08 PM
64speed's Avatar
Idle is at 850 and the lifters are Lunati. Little noise but not much.
  #867
Old 04-30-2022, 06:49 AM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
My Comp rollers quieted down a bunch when I went from 1/2 turn past zero lash to 1 turn past. Glad to see that you're getting some seat time! Mine has been down about two years now.
  #868
Old 04-30-2022, 01:25 PM
64speed's Avatar
https://youtube.com/shorts/7j0JPkItDAQ?feature=share
Running down the road
  #869
Old 04-30-2022, 03:59 PM
grivera's Avatar
Your AC condenser will inhibit air flow at idle. And now is a good time to check if it overheats with AC on and the condenser being an additional heat source for the radiator.
Check the cooling section for tips and tricks. Vacuum advance and timing, minimum clearance on water pump divider plate, factory clutch fan, air burped out of system, make sure all baffles and factory components in place. If it cools down at speed then it points to an air flow problem…
Will Rivera
  #870
Old 04-30-2022, 04:34 PM
64speed's Avatar
https://youtu.be/vsa4mUvYTEs
Coming home after cleanup
  #871
Old 04-30-2022, 08:01 PM
Gach's Avatar
Gach Gach is offline
Love it, what a nice feeling that must be, finally get to this point. Nice !
Old 04-30-2022, 08:13 PM
Car came out great David.
Congratulations on a job very well done.
  #873
Old 04-30-2022, 09:02 PM
64speed's Avatar
Thanks!!! Still got a long way to go with interior. It’s LOUD inside haha. I need sound deadener and carpet etc. I have all the interior pieces except carpet but it’s gonna be a while till I have the money to do it.
  #874
Old 04-30-2022, 09:29 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Looks good. Just a side note, you should probably limit your extended idle time, Hard on camshafts. Yes even with rollers.
64 Lemans hardtop
4spd, buckets
  #875
Old 05-01-2022, 08:29 AM
grivera's Avatar
Looks and sounds great. For sound deadener you don't have to break the bank with high-priced name brand. Two boxes of this - total of $130 -will do your floor and probably enough for your doors. Then you can move on with carpet install.
https://www.amazon.com/Siless-mil-sq...1407971&sr=8-9
Will Rivera
  #876
Old 05-01-2022, 09:56 AM
64speed's Avatar
Thanks, I was wondering if anyone had used it!
  #877
Old 05-01-2022, 09:58 AM
64speed's Avatar
Has anyone replaced the seat tracks on a bench seat? Suddenly my passenger side doesn’t want to latch and nothing I do will latch it. I have access to a million bench seats I just don’t know about swapping the tracks.
  #878
Old 05-01-2022, 10:31 AM
68WarDog's Avatar
68WarDog 68WarDog is offline
David, I'm in NC and experience some of the same possible overheating issues in slow idling traffic..
I used the 19" Pontiac 7 blade Hayden heavy duty clutch fan, 160 fail safe thermostat, and I removed the ( reduced flow)6" underdrive aftermarket crank pulley and replaced it with the original ( high flow)8" crank pulley .Now 172- 183 slow traffic idling). Pontiac 470 10.4 compression, solid roller engine.
  #879
Old 05-01-2022, 10:35 AM
64speed's Avatar
Thank you
  #880
Old 05-01-2022, 12:33 PM
NeighborsComplaint's Avatar
Congrats on reaching this milestone and realizing your dream. At around 100 miles you should be ready for your for first fill-up.
Triple Black 1971 GTO
